Hi! In the below MWE, I have a boxmesh defined by mesh = BoxMesh(Point(0.0, 0.0, 0.0), Point(10.0, 0.1, 0.1), 100, 10, 10). On this mesh, I am solving the PDE \eta\frac{\partial\mathbf u}{\partial t} = (\text{CSA})\nabla.\mathbf{T}, where \mathbf{u}, t, \eta, CSA, and \mathbf{T} represent displacement, time, friction coefficient, cross section area, and the 1st Piola–Kirchoff stress tensor. I am applying a hyperelastic framework with a growth tensor and a strain energy density function. I solve for the displacement \mathbf{u} that minimizes the stress.
I need to impose a zero displacement DirichletBC on the vertices lying on cross section at the center of the beam (the cross section at the center is a rectangle with the corners located at (5.0, 0.0, 0.0), (5.0, 0.0, 0.1), (5.0, 0.1, 0.1), and (5.0, 0.1, 0.0)). I tried to locate the vertices of the tetrahedra that lies close to the center center = Point(5.0, 0.05, 0.05). But it returns only a point [1.9 0.04 0.08] which is far away from the defined center and also returns only one point. I need all vertices lying on the cross section at the center of the beam. I am not sure what I am doing wrong in the below MWE
import ufl as ufl
import matplotlib.patches as mpatches
# Creating Rectangular mesh #
L = 10.0
H = 0.1
W = 0.1
mesh = BoxMesh(Point(0.0, 0.0, 0.0), Point(10.0, W, H), 100, 10, 10)
# Defining the volume measure of the rectangle #
volume_markers = MeshFunction("size_t", mesh, mesh.topology().dim(), 0)
dv_custom = Measure("dx", domain=mesh, subdomain_data=volume_markers)
# Defining vector and scalar function spaces #
F_bact = VectorFunctionSpace(mesh, 'P', 1)
V_bact = VectorFunctionSpace(mesh, 'P', 1)
T_bact = TensorFunctionSpace(mesh, 'P', 1)
vtk1 = File("solutionbacteriagrowth.pvd")
vtk2 = File("sigmareference.pvd")
vtk3 = File("sigmadeformed.pvd")
vtk4 = File("velocity_time.pvd")
u = Function(V_bact)
u_n = Function(V_bact)
v = TestFunction(V_bact)
vel = Function(V_bact)
csa_second_moment = (H**4)/12
csa = H**2
NumStepg = 100
Time = 60
dt = Time/NumStepg
j = 0
eta = 5.0
r = 0.020
mu1 = 2500.0/csa_second_moment
nu1 = 0.4999
# Defining function to impose DBC on the cross section at center
center = Point(L/2, H/2, W/2)
# Find which tetrahedra point is located in
tree = mesh.bounding_box_tree()
cell, distance = tree.compute_closest_entity(center)
vertices = mesh.cells()[cell]
# Find the closest vertex in the cell
vertex_coordinates = mesh.coordinates()[vertices]
dist = 1e-1
closest = None
for i, v1 in enumerate(vertex_coordinates):
p_ = Point(v1)
dist_ = center.distance(p_)
print(v1)
if dist_ < dist:
dist = dist_
closest_local = i
closest_vertex = vertices[closest_local]
closestv = mesh.coordinates()[closest_vertex]
# Find dof corresponding to vertex
vtd_p = vertex_to_dof_map(F_bact)
dof_number = vtd_p[closest_vertex]
print(f"DOF number of closest vertex = {dof_number}")
print(f"closest vertex = {V_bact.tabulate_dof_coordinates()[closest_vertex]}")
class cm(SubDomain):
tol = 1E-14
return near(x[0], closestv[0], tol)
for T in np.linspace(0,Time,NumStepg):
d = mesh.geometry().dim()
I = Identity(d) # Identity tensor
Fg_theta = as_tensor([[exp(r*T),0.0, 0.0],[0.0,1.0,0.0],[0.0,0.0,1.0]])
Fe = variable(F*inv(Fg_theta))
C = variable(Fe.T*Fe)
J = det(Fe)
I1 = tr(C)
W = (mu1/2)*(I1 - 3) + ((nu1)*(mu1)/(1-(2*nu1)))*(J-1)**2 - mu1*(ln(J))
TT = det(Fg_theta)*diff(W,Fe)*(inv(Fg_theta).T)
sigma = (2/J)*((mu1/2)*(Fe*Fe.T - I) + (nu1*mu1*(J-1)*J*I)/(1-2*nu1))
PE = (eta)*dot(u,v)*dx_custom() + csa*dt*inner(sigma,grad(v))*dx_custom() - (eta)*dot(u_n, v)*dx_custom()
all_domains = MeshFunction("size_t", mesh, mesh.topology().dim() - 1, 1)
bcs1 = DirichletBC(V_bact.sub(0), Constant(0.0), cm(), method='pointwise')
bcs2 = DirichletBC(V_bact.sub(1), Constant(0.0), cm(), method='pointwise')
bcs3 = DirichletBC(V_bact.sub(2), Constant(0.0), cm(), method='pointwise')
bcs = [bcs1, bcs2, bcs3]
# Solve variational problem
solve(PE == 0, u , bcs,
solver_parameters={"newton_solver": {"relative_tolerance": 5e-9,
"absolute_tolerance": 5e-10,"maximum_iterations": 50}})
print(f"Number of iterations: {j}", flush=True)
print(f"Time = {T} mins", flush=True)
j += 1
vel.assign((u - u_n)/dt)
u_n.assign(u)
disp = project(u, V_bact)
disp.rename('disp','disp')
velocity = project(vel, V_bact)
velocity.rename("velocity","velocity")
vtk1<<(disp, T)
vtk4<<(velocity, T)
################ END ###############
In addition to the above problem, I also need to keep the cross-section constant with time across the length of the beam as it grows and deforms with time. I am not sure how to implement that.
Any suggestions would be greatly appreciated!
Thanks in advance!
