How to do polar decomposition (RU decomposition) of the deformation gradient tensor in FEniCS?
In the below MWE, I have a unit cube. I have defined a displacement field U1 = Expression(("0.0","cos(theta) - sin(theta)","sin(theta) + cos(theta)"), theta = pi/3, degree=0). I projected it on a VectorFunctionSpace defined on the domain. Next, I define the deformation gradient tensor as F = Identity(3) + grad(disp). I want to do a polar decomposition as R,U = polar(F) where polar() is imported from scipy.linalg. This gives me the error
R,U = polar(F)
  File "/usr/lib/python3/dist-packages/scipy/linalg/_decomp_polar.py", line 100, in polar
    raise ValueError("`a` must be a 2-D array.")
ValueError: `a` must be a 2-D array.
Is there a way to do the polar decomposition of the deformation gradient tensor pointwise on the entire domain?
Here is the MWE:
from scipy.linalg import polar
               "eliminate_zeros": True, \
               "precompute_ip_const": True}
mesh = UnitCubeMesh(24, 16, 16)
T = TensorFunctionSpace(mesh, "Lagrange", 1)
# Mark boundary subdomians
left =  CompiledSubDomain("near(x[0], side) && on_boundary", side = 0.0)
right = CompiledSubDomain("near(x[0], side) && on_boundary", side = 1.0)
vtk1 = File("R_ref.pvd")
vtk2 = File("U_ref.pvd")
disp = project(U1, V)
R,U = polar(F)
R_ref = project(R, T)
U_ref = project(U, T)
R_ref.rename('R_ref','R_ref')
T_ref.rename('T_ref','T_ref')
vtk1<<R_ref
vtk2<<U_ref
Any suggestion or comments would be extremely helpful.
Thanks in advance!
F is a symbolic expression. It is not an array of values.
You would have to implement the polar decomposition in UFL. ie. take the logic from: scipy/scipy/linalg/_decomp_polar.py at v1.15.2 · scipy/scipy · GitHub
and implement it with ufl operators, similar to:
Calculating local eigenvalues and eigenvectors for use in weak form
(There are analytical formulas for svd of 2x2 matrices at): Singular value decomposition - Wikipedia
I am not sure I understand. So are you saying that we need to run a for loop over the vertices of a tetrahedral mesh, convert F (in the MWE I posted originally) into an array locally at each vertex, do the SVD, and then reconfigure it as a matrix.
I am sorry this is a trivial thing that I am not getting. Would it be possible to give me an MWE on how to do the SVD or RU decomposition of the deformation gradient tensor?
