Thanks for your quick reply!
Here is some code that reproduces the problem. I tried to reduce the number of lines as much as possible, but since this only happens in large 3D cases and I am using a ‘modified augmented Lagrangian’ method, the code is still a bit heavy. Nevertheless, lines 265–349 contain the Navier-Stokes loop with the CFL and k (time variable) update.
To respond to your suggestions, if I leave dt_expr = only outside the loop, then the values of k are not correct with the CFL, because I get much slower convergence (steady residual norm) and a very different k norm (increases little compared to when dt_expr = is in the loop).
The mesh: https://drive.google.com/file/d/1Z-lPthDMXNWDLOTaIFLggHgpx9x5-kmR/view?usp=drive_link
The code :
import sys
import petsc4py
petsc4py.init(sys.argv)
import time
from ufl import split, TestFunctions, TestFunction, derivative, grad, inner, dx, div, Measure, TrialFunction, sqrt, dot
import basix.ufl
from dolfinx.fem.petsc import apply_lifting, assemble_vector, set_bc, assemble_matrix, create_matrix, create_vector
from dolfinx.fem import Function, functionspace, Constant, dirichletbc, locate_dofs_topological, form
from dolfinx import mesh
from dolfinx.io.gmshio import read_from_msh
comm = MPI.COMM_WORLD
msh_file = "Mesh/Rectangle3D.msh"
mesh, cell_tags, facet_tags = read_from_msh(msh_file, MPI.COMM_WORLD, gdim=3)
tags = {}
tags["inlet"] = 1
tags["outlet"] = 2
tags["walls"] = 3
def alpha_initial2(x):
# Paramètres de la bande inclinée (à définir selon ton cas)
x_start = 1.45 # Début en x
x_end = 1.75 # Fin en x
y_start = 0.5 # Début en y
y_end = 1.0 # Fin en y
z_center = 0.75 # Centre en z
x_center = 1.6 # Centre en x pour l'inclinaison
m = 1 # pente tan(45°) = 1
d = 0.075 # Demi-épaisseur de la bande
# Initialiser alpha à 1 (fluide) partout
values = np.ones(x.shape[1])
# Définir la condition pour la bande inclinée
z_line = z_center + m * (x[0] - x_center) # Équation de la bande en z
mask = (
(x_start <= x[0]) & (x[0] <= x_end) & # Limite en x
(y_start <= x[1]) & (x[1] <= y_end) & # Limite en y
(np.abs(x[2] - z_line) <= d))
# Mettre alpha = 0 (solide) dans la bande
values[mask] = 0.0
return values
fdim = mesh.topology.dim-1
dx = Measure("dx", domain=mesh, metadata=metadata)
v_max_inlet = Constant(mesh, PETSc.ScalarType(5))
Re = 1000
rho_ = Constant(mesh, PETSc.ScalarType(1))
mu_ = Constant(mesh, PETSc.ScalarType(rho_*v_max_inlet*2/Re))
nu_ = Constant(mesh, PETSc.ScalarType(mu_/rho_))
########################## ELEMENT #############################################
V_element2 = basix.ufl.element("CG", mesh.basix_cell(), 2, shape = (mesh.topology.dim,))
V_element = basix.ufl.element("CG", mesh.basix_cell(), 1)
Bubble_element = basix.ufl.element("Bubble", mesh.basix_cell(), 4)
enriched_element = basix.ufl.enriched_element([V_element, Bubble_element])
Mini_element = basix.ufl.blocked_element(enriched_element, shape = (mesh.topology.dim,))
P_element = basix.ufl.element("CG", mesh.basix_cell(), 1)
U_element = basix.ufl.mixed_element([Mini_element, P_element])
U = functionspace(mesh, U_element);U_v = U.sub(0); U_p = U.sub(1)
if comm.rank ==0:
print("Nb de DoFs ", U.dofmap.index_map.size_global)
w_v, w_p = TestFunctions(U)
uh = Function(U)
v, p = split(uh)
uh_prev = Function(U)
v_prev, p_prev = split(uh_prev)
T = functionspace(mesh, basix.ufl.element("DG", mesh.basix_cell(), 0))
k = Function(T)
A_element = basix.ufl.element("CG", mesh.basix_cell(), 1)
A = functionspace(mesh, A_element)
alpha = Function(A)
k_min = 0 # Valeur minimale de k
k_max = 10000 # Valeur maximale de k
q_ = 0.01
def kappa(alpha):
return k_max + (k_min - k_max) * alpha * (1. + q_) / (alpha + q_)
########################## BC #############################################
def inlet_velocity_expr(x):
values = np.zeros((mesh.topology.dim, x.shape[1]), dtype=PETSc.ScalarType)
values[0] = v_max_inlet # v_x = v_max_inlet, v_y = 0, v_z = 0
return values
V = U.sub(0).collapse()[0]
P = U.sub(1).collapse()[0]
inlet_velocity = Function(V)
inlet_velocity.interpolate(inlet_velocity_expr)
noslip_velocity = Function(V)
noslip_velocity.x.array[:] = 0.0
# Localisation des DOFs
dofs_inlet = locate_dofs_topological((U_v, V), fdim, facet_tags.find(tags["inlet"]))
dofs_outlet = locate_dofs_topological(U.sub(1), fdim, facet_tags.find(tags["outlet"]))
dofs_walls = locate_dofs_topological((U_v, V), fdim, facet_tags.find(tags["walls"]))
# Conditions de Dirichlet
bc_inlet = dirichletbc(inlet_velocity, dofs_inlet, U_v)
bc_outlet = dirichletbc(Constant(mesh, PETSc.ScalarType(0.0)), dofs_outlet, U_p)
bc_walls = dirichletbc(noslip_velocity, dofs_walls, U_v)
bcs = [bc_inlet, bc_walls]
uh.sub(0).interpolate(inlet_velocity_expr)
uh.sub(1).interpolate(lambda x: np.zeros(x.shape[1]))
uh.x.scatter_forward()
alpha.interpolate(alpha_initial2)
alpha.x.scatter_forward()
mu_T = 0
nu_T = 0
########################## Weak form #############################################
F_PV = (-div(v) * w_p * dx + nu_ * inner(grad(v),grad(w_v)) * dx + inner(grad(v)*v, w_v) * dx - p * div(w_v) * dx + inner(kappa(alpha) * v, w_v)*dx)
# Div-grad and Pressure matrix
gamma_ = 0.20
F_PV += gamma_*div(v)*div(w_v) *dx
Press = functionspace(mesh, P_element)
q_p, r_p = ufl.TrialFunction(Press), ufl.TestFunction(Press)
S_form = form(-1.0/(gamma_ + 1.0/Re) * q_p*r_p *dx)
Mp = assemble_matrix(S_form)
Mp.assemble()
Mp_norm = Mp.norm()
J_PV = 1* inner(v, w_v)/k *dx + F_PV
class NonlinearPDE_PseudoProblem:
def __init__(self, F, Jac, u, bc):
self.V = u.function_space
self.du = TrialFunction(self.V)
self.L = form(F)
self.a = form(derivative(Jac, u, self.du))
self.bc = bc
self._F, self._J = None, None
self.u = u
self.norm_res_l2 = 0
self.norm_res_inf = 0
def F(self, snes, x, F):
"""Assemble residual vector."""
x.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
x.copy(self.u.x.petsc_vec)
self.u.x.petsc_vec.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
with F.localForm() as f_local:
f_local.set(0.0)
assemble_vector(F, self.L)
apply_lifting(F, [self.a], bcs=[self.bc], x0=[x], alpha=-1.0)
F.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
set_bc(F, self.bc, x, -1.0)
self.norm_res_l2 = F.norm(PETSc.NormType.NORM_2)
self.norm_res_inf = F.norm(PETSc.NormType.NORM_INFINITY)
def J(self, snes, x, J, P):
"""Assemble Jacobian matrix."""
J.zeroEntries()
assemble_matrix(J, self.a, bcs=self.bc)
J.assemble()
j_norm = J.norm(PETSc.NormType.NORM_FROBENIUS)
snes.getKSP().setOperators(J)
snes.getKSP().setUp()
vx_ksp, vy_ksp, vz_ksp, p_ksp = snes.getKSP().getPC().getFieldSplitSubKSP()
p_ksp.setOperators(Mp, Mp)
##################################### PETSc Solver #############################################
#Snes solver
problem = NonlinearPDE_PseudoProblem(F_PV,J_PV, uh, bcs)
J = create_matrix(problem.a)
b = create_vector(problem.L)
# Create Newton solver and solve
snes = PETSc.SNES().create()
snes.setFunction(problem.F, b)
snes.setJacobian(problem.J, J)
problem_prefix = "ns_"
snes.setOptionsPrefix(problem_prefix)
opts = PETSc.Options()
opts.prefixPush(problem_prefix)
opts["snes_type"] = "newtonls"
opts['snes_linesearch_type'] ='basic'
#opts['snes_monitor'] = None
#opts["snes_converged_reason"] = None
_, map_vx = U.sub(0).sub(0).collapse()
_, map_vy = U.sub(0).sub(1).collapse()
_, map_vz = U.sub(0).sub(2).collapse()
_, map_vel = U.sub(0).collapse()
_, map_p = U.sub(1).collapse()
dofmap_U = U.dofmap
U_indexmap = dofmap_U.index_map
localdofs_vx = np.setdiff1d(U_indexmap.local_to_global(np.array(map_vx)), U_indexmap.ghosts)
localdofs_vy = np.setdiff1d(U_indexmap.local_to_global(np.array(map_vy)), U_indexmap.ghosts)
localdofs_vz = np.setdiff1d(U_indexmap.local_to_global(np.array(map_vz)), U_indexmap.ghosts)
localdofs_p = np.setdiff1d(U_indexmap.local_to_global(np.array(map_p)), U_indexmap.ghosts)
localdofs_vel = np.setdiff1d(U_indexmap.local_to_global(np.array(map_vel)), U_indexmap.ghosts)
snes.getKSP().setType("fgmres")
snes.getKSP().getPC().setType(PETSc.PC.Type.FIELDSPLIT)
ISvx_ns = PETSc.IS().createGeneral(np.array(localdofs_vx, dtype=np.int32), comm=mesh.comm)
ISvy_ns = PETSc.IS().createGeneral(np.array(localdofs_vy, dtype=np.int32), comm=mesh.comm)
ISvz_ns = PETSc.IS().createGeneral(np.array(localdofs_vz, dtype=np.int32), comm=mesh.comm)
ISp_ns = PETSc.IS().createGeneral(np.array(localdofs_p, dtype=np.int32), comm=mesh.comm)
ns_ksp = snes.getKSP().getPC()
ns_ksp.setFieldSplitIS(("vx", ISvx_ns), ("vy", ISvy_ns),("vz", ISvz_ns), ("p", ISp_ns))
ns_ksp.setFieldSplitType(PETSc.PC.CompositeType.MULTIPLICATIVE)
opts["ksp_rtol"] = 1e-1
opts["ksp_max_it"] = 10000
opts["ksp_converged_reason"] = None
opts["ksp_gmres_restart"] = 150
#opts["ksp_monitor"] = None
opts["ksp_pc_side"] = "right"
vel_components = ["vx", "vy", "vz"]
for vel in vel_components:
opts[f"fieldsplit_{vel}_ksp_type"]= "gmres"
opts[f"fieldsplit_{vel}_ksp_rtol"]= 1e-1
opts[f"fieldsplit_{vel}_pc_type"]= "asm"
opts[f"fieldsplit_{vel}_ksp_gmres_restart"] = 50
opts[f"fieldsplit_{vel}_pc_asm_overlap"] = 1
opts[f"fieldsplit_{vel}_sub_pc_type"] = "lu"
opts[f"fieldsplit_{vel}_sub_pc_factor_mat_solver_type"] = "mumps"
opts["fieldsplit_p_ksp_type"]= "cg"
opts["fieldsplit_p_pc_type"]= "jacobi"
opts["fieldsplit_p_ksp_max_it"] = 15
################################ Solver loop #########################################
opts["snes_max_it"] = 1
opts.prefixPop() # ns_
snes.setFromOptions()
x = uh.x.petsc_vec.copy()
x_norm = x.norm()
CFL_prev = 0
CFL_min = 1
CFL = CFL_min # Valeur minimale de CFL
CFL_max = 1000 # Valeur maximale de CFL
beta = 0.8 # Paramètre beta (fixé à 1 dans l'article)
vnorm = sqrt(dot(v,v))
h = ufl.CellDiameter(mesh)
dt_local = CFL * h/vnorm
dt_expr = dolfinx.fem.Expression(dt_local, T.element.interpolation_points())
k.interpolate(dt_expr)
ite = 1
uh_prev.x.array[:] = uh.x.array[:]
uh_prev.x.scatter_forward()
norm_res_l2_0 = 1
norm_res_inf_0 = 1
t0 = time.time()
for i in range(100):
t2 = time.time()
comm.barrier()
snes.solve(None, x)
comm.barrier()
t3 = time.time()
if comm.rank ==0:
print("time solve: ", t3-t2)
x.copy(uh.x.petsc_vec)
uh.x.petsc_vec.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
#Update cfl and dt
if problem.norm_res_l2 != 0 and problem.norm_res_inf != 0 and ite > 1:
r = max(problem.norm_res_l2 / norm_res_l2_0, problem.norm_res_inf/ norm_res_inf_0 )
CFL = min(CFL_min/r**beta, CFL_max)
comm.barrier()
t12 = time.time()
comm.barrier()
t13 = time.time()
k.x.scatter_forward() # Synchronise les données locales vers le vecteur PETSc global
k.x.petsc_vec.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.REVERSE)
CFL_prev = CFL
norm_k = k.x.petsc_vec.norm()
if comm.rank ==0:
print("time in expression: ", t13-t12)
print("norm k: ", norm_k)
CFL = CFL *1
CFL_prev = CFL
if (ite == 1 or ite == 2) and problem.norm_res_l2 != 0 and norm_res_l2_0 == 1:
norm_res_l2_0 = problem.norm_res_l2
if MPI.COMM_WORLD.rank == 0:
print("-" * 60)
print(f"Iteration {ite:3d} | Résidu L2: {problem.norm_res_l2:.3e} CFL: {CFL:.2f}")
if (problem.norm_res_l2) < 1e-9 and ite >2:
break
ite += 1
uh_norm = uh.x.petsc_vec.norm()
t1 = time.time()
if comm.rank ==0:
print("Temps écoulé: ", t1-t0)
print(uh_norm)`
