Is there a way of writing the source vector (node loads in the code below) so they can be exported as an xdmf file and visualized in ParaView?
How can bc facets (like boundary_facets in the code below) be marked and exported with an xdmf file?
Thank you,
Alex
from dolfinx import mesh, fem, default_scalar_type, io
from dolfinx.fem.petsc import assemble_matrix, assemble_vector, apply_lifting, create_vector, set_bc
mu = 1
lambda_ = 1.25
domain = mesh.create_unit_cube(MPI.COMM_WORLD, nx=1, ny=1, nz=1, cell_type=mesh.CellType.tetrahedron)
# Extract the coordinates of the nodes associated with the facets
node_coords = domain.geometry.x
print(str(node_coords) + '\n')
def clamped_boundary(x):
return np.isclose(x[0], 0)
print(type(boundary_facets))
bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, fdim, boundary_facets), V)
return ufl.sym(ufl.grad(u)) # Equivalent to 0.5*(ufl.nabla_grad(u) + ufl.nabla_grad(u).T)
def sigma(u):
u = ufl.TrialFunction(V)
L = ufl.dot(T, v) * ds
a_compiled = fem.form(a)
L_compiled = fem.form(L)
# Assemble system, applying boundary conditions
A = assemble_matrix(a_compiled, bcs=[bc])
b = assemble_vector(L_compiled)
apply_lifting(b, [a_compiled], bcs=[[bc]])
set_bc(b, [bc])
global_node = 3 # Chosen based on printed node coordinates
b.setValue(3*global_node, 1.0)
b.setValue(3*global_node+1, 1.0)
b.setValue(3*global_node+2, 1.0)
# Create solution function
uh = fem.Function(V)
# Solver
solver.setOperators(A)
# Compute solution
solver.solve(b, uh.x.petsc_vec)
with io.XDMFFile(domain.comm, "deformation.xdmf", "w") as xdmf:
xdmf.write_mesh(domain)
uh.name = "Deformation"
xdmf.write_function(uh)
