How to express temperature-dependent thermal conductivity
When the thermal conductivity is a constant, the general heat conduction problem is solved as follows. If the thermal conductivity is a function of temperature, for example, kappa = T**1.5, how should the corresponding variational equation be modified?
from dolfinx.io import gmshio
from dolfinx import io
from ufl import (TestFunction, TrialFunction, dot, dx, grad)
from dolfinx.fem import (functionspace, dirichletbc, locate_dofs_topological)
mesh, cell_markers, facet_markers = gmshio.read_from_msh("f.msh", MPI.COMM_WORLD, gdim=3)
q_v = 0.01    #power
kappa = 0.002  #thermal conductivity
VT = functionspace(mesh, ("CG", 1))
Tf = 1000.0
facets = facet_markers.find(6)
fdim = mesh.topology.dim - 1
dofs = locate_dofs_topological(VT, fdim, facets)
bcT = dirichletbc(Tf, dofs, VT)
T_ = TestFunction(VT)
dT = TrialFunction(VT)
aT = dot(grad(dT), grad(T_)) * dx
LT = q_v/kappa * T_ * dx
problem = LinearProblem(aT, LT, bcs=[bcT], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
Delta_Tf = problem.solve()
This would make the problem nonlinear. Essentially, you’re looking for this:
https://jsdokken.com/dolfinx-tutorial/chapter2/nonlinpoisson.html
Thank you for your reply. I’m currently working through this tutorial.
