I have this code that im working on. I only know how to apply ‘c.vector().get_local()’ to get the solution. But i want to know if there is a way to find the value at the cell-centered
def solver(f, c0, t_0, t_N, dt, radius, height, xmin, ymin, fs_order, u_in, u_x, D_xx, D_xy, D_yy, solution_dict):
diameter = radius * 2
xmax = diameter
ymax = height
domain = Rectangle(Point(xmin, ymin), Point(xmax, ymax))
mesh = generate_mesh(domain, 4)
element = FiniteElement(family='CG', cell=mesh.ufl_cell(),
degree=fs_order, quad_scheme='quadrature')
c = TrialFunction(V)
w = TestFunction(V)
u_y = u_in
D_yx = D_xy
u = as_vector([u_x, u_y])
D = as_matrix(((D_xx, D_xy), (D_yx, D_yy)))
c_in = c0 / 100 # [ppm]
g_in = u_in * c_in
c_0 = Constant(c0)
if t_0 in solution_dict:
c_init = solution_dict[t_0]
c_init = Function(V)
c_init.assign(c_0)
domains = MeshFunction("size_t", mesh, mesh.topology().dim())
boundary_parts = MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
class BottomBoundary(SubDomain):
tol = 1E-14
return on_boundary and abs(x[1] - ymin) < tol
Gamma_1 = BottomBoundary()
Gamma_1.mark(boundary_parts, 1)
c_B = Constant(c_in)
bc1 = DirichletBC(V, c_B, boundary_parts, 1)
class RightBoundary(SubDomain):
tol = 1E-14
return on_boundary and abs(x[0] - xmax) < tol
Gamma_2 = RightBoundary()
Gamma_2.mark(boundary_parts, 2)
c_R = Constant(0.0)
bc2 = DirichletBC(V, c_R, boundary_parts, 2)
class TopBoundary(SubDomain):
tol = 1E-14
return on_boundary and abs(x[1] - ymax) < tol
Gamma_3 = TopBoundary()
Gamma_3.mark(boundary_parts, 3)
c_T = Constant(0.0)
bc3 = DirichletBC(V, c_T, boundary_parts, 3)
class LeftBoundary(SubDomain):
tol = 1E-14
return on_boundary and abs(x[0] - xmin) < tol
Gamma_4 = LeftBoundary()
Gamma_4.mark(boundary_parts, 4)
c_L = Constant(0.0)
bc4 = DirichletBC(V, c_L, boundary_parts, 4)
bcs = [bc1]
dx = Measure('dx', domain=mesh, subdomain_data=domains)
ds = Measure('ds', domain=mesh, subdomain_data=boundary_parts)
a = c * w * dx + dt * c * w * dx + dt * inner(grad(w), dot(D, grad(c)) - u * c) * dx + dt * c * w * u_y * ds(3)
L = c_init * w * dx + dt * f * w * dx - dt * w * g_in * ds(1)
c = Function(V)
c.rename('concentración', 'c')
c_file = File('Transporte_Prueba_new/concentracion_new.pvd')
c.assign(c_init)
A = assemble(a)
b = assemble(L)
for bc in bcs:
bc.apply(A, b)
solve(A, c.vector(), b, 'lu')
print(f"Time step: {t_0}, Concentration: {c.vector().get_local()[0]}")
solution_dict[t_0 + dt] = c.copy(deepcopy=True)
c_file << (c, t_0)
return c
def run_solver():
radius = 0.01 # m
height = 0.05 # m
xmin = 0.
ymin = 0.
fs_order = 1
u_in = 2.5e-07
u_x = 0
D_xx = 0
D_xy = 0
D_yy = 5e-10
f = 0
c0 = 1000
t_0 = 0.
t_N = 90
dt = 10
solution_dict = {}
while True:
c = solver(f, c0, t_0, t_N, dt, radius, height, xmin, ymin, fs_order, u_in, u_x, D_xx, D_xy, D_yy, solution_dict)
t_0 += dt
user_input = input("Enter 'q' to quit or press Enter to continue with the next run: ")
if user_input.lower() == 'q':
break
if __name__ == '__main__':
run_solver()
