How to find the coordinate where a vector function is max?
Hi! I am trying to find the mesh coordinate where my solution is maximum. In the following MWE, I am solving the Poisson equation with 0 BC on a disk of radius 3. To find the coordinate where the solution attains its max, I implemented the following lines of code:
max_index = np.argmax(u.vector()[:])
print(mesh.coordinates()[max_index,:])
This gives me a coordinate that doesn’t match with what I see in Paraview.
MWE:
from dolfin import Mesh, XDMFFile, File, MeshValueCollection, cpp
               "eliminate_zeros": True, \
               "precompute_ip_const": True}
from mshr import Circle, generate_mesh
from dolfin import Mesh, File, MeshFunction, Point, BoundaryMesh, SubDomain, plot, File
class boundary(SubDomain):
        return on_boundary
class disk(SubDomain):
        return True
C = Circle(Point(0, 0), 3)
mesh = generate_mesh(C, 100)
surface_markers = MeshFunction("size_t", mesh, mesh.topology().dim(), 0)
boundary().mark(boundary_markers, 2)
disk().mark(surface_markers, 1)
ds = Measure('ds', subdomain_data=boundary_markers)
dx = Measure('dx', subdomain_data=surface_markers)
W1 = FunctionSpace(mesh, "Lagrange", 1)
G , mu = 1, 0.1
u_D=Constant(0.0)
bc = DirichletBC(W1, u_D, boundary_markers, 2)
u = TrialFunction(W1)
v = TestFunction(W1)
f = Constant(-G/mu) # f=-G/mu
a = dot(grad(u), grad(v))*dx
L = -f*v*dx
# Compute solution
u = Function(W1)
solve(a == L, u, bc)
max_u = max(u.vector())
print(max_u)
file = File("dispex.pvd");
file << u;
Results:
[-2.61086432  0.7678868 ]
22.4992211222971
What I see in Paraview:
So, the result my script gives doesn’t match with what I see. I am expecting the max to be somewhat near the center. But [-2.61086432 0.7678868 ] is far off.
Can someone please tell me what’s wrong in here?
The mesh coordinates and the coordinates of the dofs are not the same,
To get the coordinates of the degrees of freedom, you need to use
x= W1.tabulate_dof_coordinates()
print(x[max_index])
Thanks. It worked. But can you explain what x= W1.tabulate_dof_coordinates() does?
It tabulates (in other words compute) the coordinates of the degrees of freedom (the entries in u.vector()).
Imagine that you have a second order lagrange space on a triangle. Then your degrees of freedom no longer align with the mesh vertices, and therefore you need to compute/tabulate them
Hi, how do I find different maximum values for different subdomains ? I have created a post here How to calculate two max values of vector in two different subdomains?
