I am a newbie to dolfinx and ran into an error with pyvista.
I pull the dolfinx/lab image and create a container. Note that
ipyvtklink has been installed. In testing pyvista
from pyvista import examples
mesh = examples.download_st_helens()
warped = mesh.warp_by_scalar(‘Elevation’)
surf = warped.extract_surface().triangulate()
surf = surf.decimate_pro(0.75) # reduce the density of the mesh by 75%
surf.plot(cmap=‘gist_earth’)
Getting the following error.
/usr/local/lib/python3.9/dist-packages/pyvista/plotting/plotting.py:115: UserWarning:
This system does not appear to be running an xserver.
PyVista will likely segfault when rendering.Try starting a virtual frame buffer with xvfb, or using
pyvista.start_xvfb()warnings.warn(
/usr/local/lib/python3.9/dist-packages/pyvista/jupyter/notebook.py:60: UserWarning: Failed to use notebook backend:Please install
ipyvtklinkto use this feature: GitHub - Kitware/ipyvtklink: 🔗 minimalist ipywidget to interface with any Python vtkRenderWindowFalling back to a static output.
warnings.warn(
ERROR:root:bad X server connection. DISPLAY=
2022-04-24 22:11:04.402 ( 40.906s) [ E6510C00]vtkXOpenGLRenderWindow.:464 ERR| vtkXOpenGLRenderWindow (0x559e810): bad X server connection. DISPLAY=
