Hi everyone,
I am trying to simulate steady flow on an upper half of a square domain. I am using the MeshView to create submesh and I use FEniCS on docker mixed-dimensional branch on Docker.
I got the following error,
*** Error: Unable to set given (local) rows to identity matrix.
*** Reason: some diagonal elements not preallocated (try assembler option keep_diagonal).
*** Where: This error was encountered inside PETScMatrix.cpp.
*** Process: 0
*** Git changeset: f0a90b8fffc958ed612484cd3465e59994b695f9
My MWE looks like the below snippet.
class Top(SubDomain):
return near(x[1], 1.0)
class Left1(SubDomain):
return near(x[0], 0.0) and between(x[1], (0.5, 1))
class Right1(SubDomain):
return near(x[0], 1.0) and between(x[1], (0.5, 1))
class Interface(SubDomain):
return near(x[1], 0.5)
class Bottom(SubDomain):
return near(x[1], 0.0)
# Create meshes
n = 20
mesh = UnitSquareMesh(n, n)
# Domain markers
domain = MeshFunction("size_t", mesh, mesh.geometry().dim(), 0)
for c in cells(mesh):
domain[c] = c.midpoint().y() > 0.5
# Interface markers
facets = MeshFunction("size_t", mesh, mesh.geometry().dim()-1, 0)
Interface().mark(facets,1)
# Meshes
mesh_U = MeshView.create(domain, 1)
mesh_L = MeshView.create(domain, 0)
mesh_I = MeshView.create(facets, 1)
# Function spaces
VE = VectorElement("CG", mesh.ufl_cell(), 1) # velocity
PE = FiniteElement("CG", mesh.ufl_cell(), 1) # Pressure
U_U = FunctionSpace(mesh_U,VE) # Velocity on the upper domain
P_U = FunctionSpace(mesh_U,PE) # Pressure on the upper domain
W = MixedFunctionSpace(U_U, P_U)#, T_U, T_L, L_I_temp)
# Markers for Dirichlet and Neuman bcs
ff_U = MeshFunction("size_t", mesh_U, mesh_U.geometry().dim()-1, 0)
Top().mark(ff_U, 1)
Left1().mark(ff_U, 2)
Right1().mark(ff_U, 3)
Interface().mark(ff_U, 4)
# Boundary conditions
bc_U1 = DirichletBC(W.sub_space(0), Constant((0,0)), ff_U, 1)
bc_U2 = DirichletBC(W.sub_space(0), Constant((0,0)), ff_U, 4)
bc_U3 = DirichletBC(W.sub_space(1), Constant(80), ff_U, 2)
bc_U4 = DirichletBC(W.sub_space(1), Constant(0), ff_U, 3)
bcs = [bc_U1, bc_U2, bc_U3, bc_U4]
# Measures
dx_U = Measure("dx", domain=W.sub_space(0).mesh())
ds_U = Measure("ds", domain=W.sub_space(0).mesh(), subdomain_data=ff_U)
# Function and test functions
(u, p) = TrialFunctions(W)
(v, q) = TestFunctions(W)
# Parameters for the variational problem
mu = 0.89
# create function space
w = Function(W)
u = w.sub(0)
p = w.sub(1)
# Variational problem
F = rho*inner(grad(u)*u, v)*dx_U \
+ mu*inner(grad(u), grad(v))*dx_U \
+ inner(grad(p),v)*dx_U \
- div(u)*q*dx_U \
# solving the problem
solve(F == 0, w, bcs)
Can anyone point me out what is the cause of this error?
Thank you
