Hello,In the following minimal running example, I am attempting to run the weak form over a rectangular domain, where the left and right edges have prescribed values. u is a vector field while P is a scalar field, I have cut off the piece associated with P in order to make the code minimal, so now it is essentially a 2D elastic stretch problem. I ran into an issue associated with applying BCs on u, the error is listed after the example code, could anyone help me with this issue? Thank you!
set_log_level(LogLevel.ERROR)
# Class representing the intial conditions
class InitialConditions(UserExpression):
def __init__(self, **kwargs):
super().__init__(**kwargs)
def eval(self, values, x):
values[0] = 0.0
values[1] = 0.0
values[2] = 0.0
def value_shape(self):
return (3,)
# Class for interfacing with the Newton solver
class Equation(NonlinearProblem):
def __init__(self, L, a, bc_u_left, bc_u_right):
self.L = L
self.a = a
self.bc_u_left = bc_u_left
self.bc_u_right = bc_u_right
def F(self, b, x):
assemble(self.L, tensor=b)
self.bc_u_left.apply(b,x)
self.bc_u_right.apply(b,x)
def J(self, A, x):
assemble(self.a, tensor=A)
self.bc_u_left.apply(A)
self.bc_u_right.apply(A)
# Boundary conditions
def left(x, on_boundary):
return near(x[0],0.)
def right(x, on_boundary):
return near(x[0],1.)
mesh = RectangleMesh(Point(0.,0.),Point(1.0, 0.1),100,10)
P1 = VectorElement("CG", mesh.ufl_cell(), 2)
P2 = FiniteElement("CG", mesh.ufl_cell(), 1)
ME = FunctionSpace(mesh, MixedElement( [P1, P2] ))
dSol = TrialFunction(ME)
testfunc = TestFunction(ME)
v,w = split(testfunc)
Sol = Function(ME)
Sol0 = Function(ME)
du, dP = split(dSol)
u, P = Sol.split(True)
u0, P0 = split(Sol0)
Sol_init = InitialConditions(degree=2)
Sol.interpolate(Sol_init)
Sol0.interpolate(Sol_init)
def eps(u):return sym(nabla_grad(u))
sigma = eps(u) + div(u)*Identity(u.geometric_dimension())
L = inner( sigma, eps(v) )*dx
a = derivative(L, Sol, dSol)
g_u = Constant((0.0,0.0))
bc_u_left = DirichletBC(ME.sub(0), g_u, left)
Ubc = 0.0
u_bc = Constant((Ubc,0.0))
bc_u_right = DirichletBC(ME.sub(0), u_bc, right)
problem = Equation(L, a, bc_u_left, bc_u_right)
Ubc += 5.0*10.0**-4.81
u_bc.assign(Constant((Ubc,0.0)))
Sol0.vector()[:] = Sol.vector()
solver = NewtonSolver()
solver.solve(problem, Sol.vector())
File "x.py", line 88, in <module>
File "x.py", line 34, in J
RuntimeError:
*** Error: Unable to set given (local) rows to identity matrix.
*** Reason: some diagonal elements not preallocated (try assembler option keep_diagonal).
*** Where: This error was encountered inside PETScMatrix.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: 15b823f2c45d3036b6af931284d0f8e3c77b6845
[1]+ Done clear
