How to get the `fem.Form` of the derivative of a `fem.functionspace` with `basix.ufl.quadrature_element`?
Hello.
The following code runs with version 0.7.0 of DOLFINx and fails with version 0.8.0.
What do I need to make it run in version 0.8.0?. Thanks in advance for your kind answer.
(Continuing the discussion from https://fenicsproject.discourse.group/t/12474)
MWE
I’m sorry that this is long (I did reduce the original code by about 100 lines).
#!/usr/bin/env python
# This file uses the code from
# https://newfrac.github.io/fenicsx-fracture/notebooks/plasticity/plasticity.html
# which holds an MIT license, under the Copyright (c) 2021 Jack S. Hale.
# The listed authors are Gaspard Blondet, Andrey Latyshev, Corrado Maurini
# Contents were removed and adapted to version 0.8.0 of DOLFINx from the original
from dolfinx import (
    fem, geometry, default_scalar_type as num_type)
from dolfinx.fem import petsc
import dolfinx.fem.petsc
from dolfinx.io import gmshio
import basix
from dolfinx.cpp.log import LogLevel, log
def strain(v):
    e = ufl.sym(ufl.grad(v))
    return ufl.as_tensor([[e[0, 0], e[0, 1], 0],
                          [e[0, 1], e[1, 1], 0],
                          [0, 0, 0]])
def sigma_tr(strain_el, lmbda, mu):
    return (1 / 3 * (3 * lmbda + 2 * mu)
            * ufl.tr(strain_el) * ufl.Identity(3))
def sigma_dev(strain_el, mu):
    return 2 * mu * ufl.dev(strain_el)
def as_3D_tensor(X):
    return ufl.as_tensor([[X[0], X[3], 0],
                          [X[3], X[1], 0],
                          [0, 0, X[2]]])
def tensor_to_vector(X):
    Take a 3x3 tensor and return a vector of size 4 in 2D
    return ufl.as_vector([X[0, 0], X[1, 1], X[2, 2], X[0, 1]])
def normVM(sig):
    """Von Mises' equivalent stress"""
    s_ = ufl.dev(sig)
    return ufl.sqrt(3 / 2 * ufl.inner(s_, s_))
def compute_new_state(du, sig_old, p_old, lmbda, mu, H, sig0):
    '''This function returns the updated mechanical state
    for a given displacement increment. We separate spheric
    and deviatoric parts of the stress to optimize
    convergence of the solver
    sig_n = as_3D_tensor(sig_old)
    sig_el_tr = (1 / 3 * ufl.tr(sig_n) * ufl.Identity(3)
                 + sigma_tr(strain(du), lmbda, mu))
    sig_el_dev = ufl.dev(sig_n) + sigma_dev(strain(du), mu)
    sig_el = sig_el_tr + sig_el_dev
    criterion = normVM(sig_el) - sig0 - H * p_old
    dp_ = ufl.conditional(
        criterion < 0, 0, criterion / (3 * mu + H))
    direction = ufl.dev(sig_n)/normVM(sig_n)
    new_sig_tr = sig_el_tr
    new_sig_dev = ufl.conditional(
        criterion < 0, sig_el_dev,
        sig_el_dev - 2 * mu * 3 / 2 * dp_ * direction)
    return new_sig_tr, new_sig_dev, dp_
# Geometric parameters
# external/internal radius
R_e = 1.3
R_i = 1
# Mesh parameters
lc = 0.03
gdim = 2
verbosity = 0
# Quarter of a ring (pressure vessel)
# Mesh using gmsh ########################################
mesh_comm = MPI.COMM_WORLD
model_rank = 0
facet_tags = {"Lx": 1, "Ly": 2, "inner": 3, "outer": 4}
cell_tags = {"all": 20}
    model = gmsh.model()
    model.add("Quart_cylinder")
    model.setCurrent("Quart_cylinder")
    # Create the points
    pix = model.occ.addPoint(R_i, 0.0, 0, lc)
    pex = model.occ.addPoint(R_e, 0, 0, lc)
    piy = model.occ.addPoint(0, R_i, 0, lc)
    pey = model.occ.addPoint(0, R_e, 0, lc)
    center = model.occ.addPoint(0, 0, 0, lc)
    # Create the lines
    lx = model.occ.addLine(pix, pex, tag = facet_tags["Lx"])
    lout = model.occ.addCircleArc(pex, center, pey, tag = facet_tags["outer"])
    ly = model.occ.addLine(pey, piy, tag = facet_tags["Ly"])
    lin = model.occ.addCircleArc(piy, center, pix, tag = facet_tags["inner"])
    # Create the surface
    cloop1 = model.occ.addCurveLoop([lx, lout, ly, lin])
    surface_1 = model.occ.addPlaneSurface([cloop1], tag = cell_tags["all"])
    model.occ.synchronize()
    # Assign mesh and facet tags
    surface_entities = [entity[1] for entity in model.getEntities(2)]
    model.addPhysicalGroup(2, surface_entities, tag=cell_tags["all"])
    model.setPhysicalName(2, 2, "Quart_cylinder surface")
    for (key, value) in facet_tags.items():
        # 1 : it is the dimension of the object (here a curve)
        model.addPhysicalGroup(1, [value], tag=value)
        model.setPhysicalName(1, value, key)
    # Finalize mesh
    gmsh.option.setNumber('General.Verbosity', verbosity)
    model.mesh.generate(gdim)
# import the mesh in fenicsx with gmshio
msh, cell_tags, facet_tags = gmshio.model_to_mesh(
            model, mesh_comm, 0, gdim=gdim)
msh.topology.create_connectivity(msh.topology.dim - 1, msh.topology.dim)
    gmsh.finalize()
# mesh ends ###########################################
# elasticity modulus MPa
E = fem.Constant(msh, num_type(1))
# Poisson's ratio
nu = fem.Constant(msh, num_type(0.3))
lmbda = fem.Constant(
    msh, num_type(E * nu / (1 + nu) / (1 - 2 * nu)))
mu = fem.Constant(msh, num_type(E / (2 * (1 + nu))))
# yield strength MPa
sig0 = fem.Constant(msh, num_type(250 / 70e3))
# hardening modulus MPa
H = fem.Constant(msh, num_type(1 / 99))
# Polynomials
deg_u = 2
deg_stress = 2
# Changed for compatibility #####################
if "0.7.0" in dolfinx.__version__:
    Ve = ufl.VectorElement(
        'Lagrange', msh.ufl_cell(), degree=deg_u, dim=2)
    V = fem.FunctionSpace(msh, Ve)
    # Vector 1x4 (not 2x2 tensor; by design: out-of-plane plasticity)
    We = ufl.VectorElement(
        "Quadrature", msh.ufl_cell(), degree=deg_stress, dim=4)
    W = fem.FunctionSpace(msh, We)
    W_scal_e = ufl.FiniteElement(
        "Quadrature", msh.ufl_cell(), degree=deg_stress)
    W_scal = fem.FunctionSpace(msh, W_scal_e)
elif "0.8.0" in dolfinx.__version__:
    msh_cell_type = msh.basix_cell()
    Ve = basix.ufl.element(
        'Lagrange', msh_cell_type, degree=deg_u, shape=(gdim,))
    V = fem.functionspace(msh, Ve)
    We = basix.ufl.quadrature_element(
        msh_cell_type, value_shape=(gdim * gdim,),
        degree=deg_stress)
    W = fem.functionspace(msh, We)
    W_scal_e = basix.ufl.quadrature_element(
        msh_cell_type, value_shape=(), degree=deg_stress)
    W_scal = fem.functionspace(msh, W_scal_e)
sig = fem.Function(W, name="Stress")
p = fem.Function(W_scal, name="Cumulative_plastic_strain")
u = fem.Function(V, name="Total_displacement")
du = fem.Function(V, name="Current_increment")
v = ufl.TrialFunction(V)
u_ = ufl.TestFunction(V)
dx = ufl.Measure(
    "dx", domain=msh, metadata={"quadrature_degree": deg_u})
dx_m = ufl.Measure(
    "dx", domain=msh, metadata={"quadrature_degree": deg_stress})
new_sig_tr, new_sig_dev, dp_ = compute_new_state(
    du, sig, p, lmbda, mu, H, sig0)
residual_u = (ufl.inner(new_sig_tr, strain(v)) * dx_m
              + ufl.inner(new_sig_dev, strain(v)) * dx)
# Works
J_u = ufl.derivative(residual_u, du, u_)
# Does not work with 0.8.0
fem.form(residual_u)
fem.form(J_u)
Error (Not Implemented)
  File "<string>", line 19, in __PYTHON_EL_eval
  File "/tmp/pyXESJz9", line 203, in <module>
  File "/usr/lib/python3.11/site-packages/dolfinx/fem/forms.py", line 188, in form
    return _create_form(form)
  File "/usr/lib/python3.11/site-packages/dolfinx/fem/forms.py", line 183, in _create_form
    return _form(form)
  File "/usr/lib/python3.11/site-packages/dolfinx/fem/forms.py", line 141, in _form
  File "/usr/lib/python3.11/site-packages/dolfinx/jit.py", line 56, in mpi_jit
  File "/usr/lib/python3.11/site-packages/dolfinx/jit.py", line 204, in ffcx_jit
  File "/usr/lib/python3.11/site-packages/ffcx/codegeneration/jit.py", line 199, in compile_forms
    raise e
  File "/usr/lib/python3.11/site-packages/ffcx/codegeneration/jit.py", line 190, in compile_forms
    impl = _compile_objects(decl, forms, form_names, module_name, p, cache_dir,
  File "/usr/lib/python3.11/site-packages/ffcx/codegeneration/jit.py", line 260, in _compile_objects
    _, code_body = ffcx.compiler.compile_ufl_objects(ufl_objects, prefix=module_name, options=options)
  File "/usr/lib/python3.11/site-packages/ffcx/compiler.py", line 97, in compile_ufl_objects
    analysis = analyze_ufl_objects(ufl_objects, options)
  File "/usr/lib/python3.11/site-packages/ffcx/analysis.py", line 86, in analyze_ufl_objects
    form_data = tuple(_analyze_form(form, options) for form in forms)
  File "/usr/lib/python3.11/site-packages/ffcx/analysis.py", line 86, in <genexpr>
  File "/usr/lib/python3.11/site-packages/ffcx/analysis.py", line 160, in _analyze_form
    form_data = ufl.algorithms.compute_form_data(
  File "/usr/lib/python3.11/site-packages/ufl/algorithms/compute_form_data.py", line 281, in compute_form_data
    form = attach_estimated_degrees(form)
  File "/usr/lib/python3.11/site-packages/ufl/algorithms/compute_form_data.py", line 207, in attach_estimated_degrees
    degree = estimate_total_polynomial_degree(integral.integrand())
  File "/usr/lib/python3.11/site-packages/ufl/algorithms/estimate_degrees.py", line 380, in estimate_total_polynomial_degree
    degrees = map_expr_dags(de, [e])
  File "/usr/lib/python3.11/site-packages/ufl/corealg/map_dag.py", line 98, in map_expr_dags
    r = handlers[v._ufl_typecode_](v)
  File "/usr/lib/python3.11/site-packages/ufl/algorithms/estimate_degrees.py", line 87, in coefficient
    d = e.embedded_superdegree  # FIXME: Use component to improve accuracy for mixed elements
  File "/usr/lib/python3.11/site-packages/basix/ufl.py", line 132, in embedded_superdegree
    return self.highest_degree
  File "/usr/lib/python3.11/site-packages/basix/ufl.py", line 1204, in highest_degree
    return self.sub_element.highest_degree
  File "/usr/lib/python3.11/site-packages/basix/ufl.py", line 1429, in highest_degree
    raise NotImplementedError()
NotImplementedError
Ancillary
I monkey-patched my running ffcx/analysis.py with this[1], but it didn’t work:
--- a/ffcx/ffcx/analysis.py   2023-10-16
+++ a/ffcx/ffcx/analysis.py   2023-10-28
@@ -193,6 +193,16 @@
         for i, integral in enumerate(integral_data.integrals):
             metadata = integral.metadata()
+            # If form contains a quadrature element, use the custom quadrature scheme
+            custom_q = None
+            for e in ufl.algorithms.extract_elements(integral):
+                if e.has_custom_quadrature:
+                    if custom_q is None:
+                        custom_q = e.custom_quadrature()
+                    else:
+                        assert np.allclose(e._points, custom_q[0])
+                        assert np.allclose(e._weights, custom_q[1])
                 # Extract quadrature degree
                 qd_metadata = integral.metadata().get("quadrature_degree", qd_default)
My system
- FEniCSx software
  dolfinx: 0.8.0.dev0_r27568.a34b0c9-1
  basix: 0.8.0.dev0_r952.eebbc52-1
  ufl: 2023.3.0.dev0_r3568.f132188-1
  ffcx: 0.8.0.dev0_r7083.b4cb217-1
- Dependencies
  python: 3.11.5-2
  python-numpy: 1.26.0-1
  petsc: 3.19.5.1171.g37df9106526-1
  hdf5-openmpi: 1.14.2-1
  boost: 1.83.0-2
  adios2: 2.8.3-5
  scotch: 7.0.4-1
  pybind11: 2.11.1-1
  python-build: 1.0.1-1
  python-cffi: 1.15.1-4
  python-cppimport: 22.08.02.r6.g0849d17-1
  python-installer: 0.7.0-3
  python-mpi4py: 3.1.4-3
  python-meshio: 5.3.4-2
  python-pytest: 7.4.2-1
  python-scikit-build: 0.17.6-1
  python-setuptools: 1:68.0.0-1
  python-wheel: 0.40.0-3
  xtensor: 0.24.0-2
  xtensor-blas: 0.20.0-1
- Operating system
  Arch Linux: 6.5.4-arch2-1
Footnotes
For reference, ffcx/analysis.py
  1. For reference, ffcx/analysis.py
    1c993ce4b1c41d8004b4429cb3b76de42eceeffa
    : changes quadrature rule (source)
    65d96e1b2bcee8c68abbbb6a60ffd7599e316ab2
    : uses element without convert ↩︎
Can be reproduced with a much simpler code:
import basix.ufl
u, v = dolfinx.fem.Function(V), ufl.TestFunction(V)
q_el = basix.ufl.quadrature_element(mesh.topology.cell_name(),value_shape=(),
                                    scheme="default", degree=1)
W = dolfinx.fem.functionspace(mesh, q_el)
c = dolfinx.fem.Function(W)
a = c * ufl.dot(u, v) * ufl.dx(domain=mesh,
                               metadata={"quadrature_degree": q_el.degree})
dolfinx.fem.form(a)
Issue reported at: Basix Quadrature element not complete · Issue #725 · FEniCS/basix · GitHub
Hi!
I just want to confirm that it now works. Thanks!
- FEniCSx software
  dolfinx: 0.8.0.dev0_r27624.095ef96-1
  basix: 0.8.0.dev0_r975.15b915b-1
  ufl: 2023.3.0.dev0_r3583.e8d3077-1
  ffcx: 0.8.0.dev0_r7098.833967c-1
- Dependencies
  python: 3.11.5-2
  petsc: 3.19.5.1172.g92f94a14170-1
  boost: 1.83.0-2
  adios2: 2.8.3-5
  scotch: 7.0.4-1
  pybind11: 2.11.1-1
  xtensor: 0.24.0-2
  python-cattrs: 23.1.2-1
  nanobind: 1.8.0-1
- Operating system
