Hi, everyone!
I want to obtain the points coordinates with the sorted order by their global indices in a dolfinx.mesh.Mesh(). First, I think this canbe done using mesh.geometry.x. However, I found that the points are out of order. How can i get my thoungts done? Thanks!
There is a distinct split in DOLFINx between topology and geometry.
The topology describes a cell and its connectivity to vertices, ridges and facets. These will always be linear cells and described through vertices.
The geometry contains information about potentially higher order, curved cells, and thus what you find in mesh.geometry.x does not link 1-1 with the vertices in mesh.topology.index_map(0).
You can use entities_to_geometry to map between the two.
domain = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 10, 10)
vertex_map = domain.topology.index_map(0)
num_owned_vertices = vertex_map.size_local
local_start = vertex_map.local_range[0]
domain.topology.create_connectivity(0, domain.topology.dim)
geometry_indices = dolfinx.mesh.entities_to_geometry(
domain, 0, np.arange(num_owned_vertices, dtype=np.int32)
).flatten()
coordinates = domain.geometry.x[geometry_indices]
for i in range(num_owned_vertices):
print(
f"Global Vertex {local_start + i} local geom index {geometry_indices[i]} {coordinates[i]}"
