Hi all,
I am trying to understand what the local ordering of cell entities (vertices, edges, faces, …) used by dolfinx is and how the mesh.topology can be related to the mesh.geometry.
Some cells are defined in cpp/dolfinx/io/cells.h:
quadrilateral using local vertex order as in Basix
2--------3
0--------1
However, this is the input-output module and I did not find a similar clear definition of the cells somewhere under cpp/dolfinx/mesh/.
After experimenting with a mesh using quadrilateral cells it seems that the local order of the vertices in dolfinx is
dolfinx (built-in mesh)
1--------3
0--------2
I can also confirm the above with the following MWE:
import tempfile
from dolfinx.io import gmshio
def create_rectangle_grid(
xmin,
xmax,
ymin,
ymax,
z=0.0,
lc=0.1,
num_cells=None,
recombine=False,
out_file=None,
"""TODO docstring"""
gmsh.model.add("rectangle")
p0 = gmsh.model.geo.addPoint(xmin, ymin, z, lc)
p1 = gmsh.model.geo.addPoint(xmax, ymin, z, lc)
p2 = gmsh.model.geo.addPoint(xmax, ymax, z, lc)
p3 = gmsh.model.geo.addPoint(xmin, ymax, z, lc)
l0 = gmsh.model.geo.addLine(p0, p1)
l1 = gmsh.model.geo.addLine(p1, p2)
l2 = gmsh.model.geo.addLine(p2, p3)
l3 = gmsh.model.geo.addLine(p3, p0)
curve_loop = gmsh.model.geo.addCurveLoop([l0, l1, l2, l3])
surface = gmsh.model.geo.addPlaneSurface([curve_loop])
if num_cells is not None:
try:
nx, ny = num_cells
except TypeError:
nx = ny = num_cells
gmsh.model.geo.mesh.setTransfiniteCurve(l0, nx + 1)
gmsh.model.geo.mesh.setTransfiniteCurve(l2, nx + 1)
gmsh.model.geo.mesh.setTransfiniteCurve(l1, ny + 1)
gmsh.model.geo.mesh.setTransfiniteCurve(l3, ny + 1)
gmsh.model.geo.mesh.setTransfiniteSurface(surface, "Left")
if recombine:
# setRecombine(dim, tag, angle=45.0)
gmsh.model.geo.mesh.setRecombine(2, surface)
gmsh.model.geo.synchronize()
gmsh.model.addPhysicalGroup(2, [surface])
filepath = out_file or "./rectangle.msh"
gmsh.model.mesh.generate(2)
gmsh.write(filepath)
gmsh.finalize()
if __name__ == "__main__":
with tempfile.NamedTemporaryFile(suffix=".msh") as tf:
0.0, 1.0, 0.0, 1.0, num_cells=(2, 1), recombine=True, out_file=tf.name
gmsh_grid, _, _ = gmshio.read_from_msh(tf.name, MPI.COMM_WORLD, gdim=2)
df_grid = dolfinx.mesh.create_unit_square(
MPI.COMM_WORLD, 2, 1, dolfinx.mesh.CellType.quadrilateral
def do_test(grid):
verts = grid.topology.connectivity(2, 0).links(0)
print(f"{verts=}")
x = dolfinx.mesh.compute_midpoints(grid, 0, verts)
print(f"{x=}")
print(f"{grid.geometry.x=}")
do_test(gmsh_grid)
do_test(df_grid)
Output:
verts=array([0, 1, 2, 3], dtype=int32)
x=array([[0. , 0. , 0. ],
[0.5, 0. , 0. ],
[0. , 1. , 0. ],
[0.5, 1. , 0. ]])
grid.geometry.x=array([[0. , 0. , 0. ],
[0.5, 0. , 0. ],
[0. , 1. , 0. ],
[0.5, 1. , 0. ],
[1. , 0. , 0. ],
[1. , 1. , 0. ]])
[0. , 1. , 0. ],
[0.5, 0. , 0. ],
[0.5, 1. , 0. ]])
[0. , 1. , 0. ],
[0.5, 0. , 0. ],
[0.5, 1. , 0. ],
[1. , 0. , 0. ],
[1. , 1. , 0. ]])
Questions/Remarks:
- The second and third vertex (indices 1 and 2) are swapped as the ordering of the quadrilateral in
/cpp/dolfinx/io/cells.hsuggests. However, as a user I would have expected the same mesh whether this was constructed with dolfinx or with Gmsh (why doesgmshio.cells_perm_array(dolfinx.mesh.CellType.quadrilateral, 4)returnnp.array([0, 1, 3, 2])and notnp.array([0, 3, 1, 2])?) - I was of the impression that in the above code
grid.geometry.x[verts]should give the correct coordinates corresponding to the global vertex indices, that is the vertex tags for the topology and geometry are the same. Is this correct or not true in general? - There is also
grid.geometry.dofmap, butdf_grid.geometry.x[df_grid.geometry.dofmap.links(0)]andgmsh_grid.geometry.x[gmsh_grid.geometry.dofmap.links(0)]give the same result as above with vertices 2 and 3 swapped.
I feel I am overlooking something.
Thanks,
Philipp
