In the following MWE, I am solving the Poisson equation (with the right-hand side multiplied by T) on a disc of radius Sqrt(3). T is a scalar that ranges from 0 to 5. Then in order to apply the solution to every mesh coordinate, I applied the following commands:
Y = mesh.coordinates()
X = project(Y,W1)
X += np.vstack(map(u,X))
MWE:
from mshr import Circle, generate_mesh
"eliminate_zeros": True, \
"precompute_ip_const": True}
class boundary(SubDomain):
return on_boundary
class disk(SubDomain):
return True
C = Circle(Point(0, 0), sqrt(3))
mesh = generate_mesh(C, 100)
surface_markers = MeshFunction("size_t", mesh, mesh.topology().dim(), 0)
boundary().mark(boundary_markers, 2)
disk().mark(surface_markers, 1)
dx = Measure('dx', domain=mesh, subdomain_data=surface_markers)
print(assemble(1*dx(1)), assemble(1*ds(2)))
W1 = FunctionSpace(mesh, "Lagrange", 1)
G , mu = 1, 0.1
u_D = Constant(0.0)
d = mesh.geometry().dim()
I = Identity(d)
T = Constant(0.0)
c = Constant((1.0,0.0))
bc = DirichletBC(W1, u_D, boundary_markers, 2)
print(assemble(1*ds(2)))
for k in range(0,5,1):
u = TrialFunction(W1)
v = TestFunction(W1)
f = Constant(-G/mu) # f=-G/mu
a = dot(grad(u), grad(v))*dx
L = T*f*v*dx
T = T + k
# Compute solution
u = Function(W1)
solve(a == L, u, bc)
X = project(Y,W1)
Error:
X = project(Y,W1)
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/projection.py", line 129, in project
L = ufl.inner(w, v) * dx
File "/usr/lib/python3/dist-packages/ufl/operators.py", line 155, in inner
b = as_ufl(b)
File "/usr/lib/python3/dist-packages/ufl/constantvalue.py", line 437, in as_ufl
raise UFLValueError("Invalid type conversion: %s can not be converted"
ufl.log.UFLValueError: Invalid type conversion: [[-1.73197184 0.01653895]
[-1.73197184 -0.01653895]
[-1.73134016 -0.04961083]
[ 0.97718622 1.04771416]
[ 0.09944235 0.30137168]
[ 0.06897023 0.31762106]] can not be converted to any UFL type.
What’s wrong here with my implementation of the “project” function or is there another problem with my code? Any help or suggestion will be helpful.
