Hi all,
I am very new to Fenics and to Finite Element Analysis in general. I am currently trying to model the heating of a 2D rectangular block in a vacuum via a laser, accounting for conduction and radiation only. Because of the nature of the problem, I do not have any Dirichlet boundary conditions, instead I only have a boundary condition which states that the energy lost to the vacuum at the boundaries must go as T**4 (ie radiative boundaries). Whilst I can obtain a solution using NonlinearVariationalProblem in order to solve:
F = T*v*dx - const*dt*dot(grad(T), grad(v))*dx + const*Q*v*dt*ds(3) - const*sum(integrals_R) -T_n*v*dx
where:
Q = Expression('2*A*t*Pmax/(pi*w*w)*exp(-2*pow(x[0]-2, 2)/(w*w))',degree=2, A=0.1, Pmax=200,w=0.3,x0=0, y0=0, t=0) #power
And sum(integrals_R) is the radiation boundary condition is defined via:
boundary_conditions = {0: {'Robin': (es, T_a4)},
1: {'Robin': (es, T_a4)},
2: {'Robin': (es, T_a4)},
3: {'Robin': (es, T_a4)}}
ds = Measure('ds', domain=mesh, subdomain_data = boundary_markers)
integrals_R = []
T = TrialFunction(V)
T_ = Function(V)
T_n = interpolate(T_am, V)
#Account for Radiation
for i in boundary_conditions:
if 'Robin' in boundary_conditions[i]:
integrals_R.append(es*(T**4 - T_a4)*v*dt*ds(i)) #t-t_am will work for now to make problem solvable
I can obtain a solution using this, however, it seems wrong from the bottom face, specifically the negative temperatures.
In addition, if I change any parameter (ie w in Q), the solution does not converge. Does anyone have any idea how I can make the solution more stable and hopefully fix these issues?
My full code is shown below:
import math
time = 100.0 # final time
num_steps = 100 # number of time steps
dt = time / num_steps # time step size
#build rectangular mesh to model 2D slice
nx = 32
ny = 16
x0 = 0
y0 = 0
x1 = 4
y1 = 2
pi = 3.141592653589793
T_am = Constant("10") #ambient vacuum temperature
T_a4 = T_am**4
epsilon = 0.6 # material emissivity
sigma = 5.67E-8 # W/(m2.K4)
es = epsilon*sigma
#----------THERMAL--PROPERTIES----------
kappa = 94 #conductivity [W/m K]
c = 0.444 #Specific Heat Capacity [J/gK]
rho = 7 #Density [g/cm^3]
const = kappa /(c * rho)
sw = Point (x0, y0)
ne = Point (x1,y1)
mesh = RectangleMesh(sw, ne, nx, ny, diagonal= "right")
V = FunctionSpace(mesh, 'P', 2)
# Define boundary condition
# build expression for power guassian (x0 and y0 displace the beam from the centre, A is the absorptivity of the target, Pmax is the maximum power of the beam, w is the width of the beam.)
#-----BOUNDARY-CONDITIONS--------------------------
#-----Define Markers for the different parts of the boundary-------
boundary_markers = MeshFunction("size_t", mesh, mesh.topology().dim()-1)
tol = 1E-14
class BoundaryX0(SubDomain):
tol = 1E-14
return on_boundary and near(x[0], x0, tol)
bx0 = BoundaryX0()
bx0.mark(boundary_markers, 0)
class BoundaryX1(SubDomain):
tol = 1E-14
return on_boundary and near(x[0], x1, tol)
bx1 = BoundaryX1()
bx1.mark(boundary_markers, 1)
class BoundaryY0(SubDomain):
tol = 1E-14
return on_boundary and near(x[1], y0, tol)
by0 = BoundaryY0()
by0.mark(boundary_markers, 2)
class BoundaryY1(SubDomain):
tol = 1E-14
return on_boundary and near(x[1], y1, tol)
by1 = BoundaryY1()
by1.mark(boundary_markers, 3)
# For the implimentation of these boundary conditions to be general, we can let the user specify what kind of boundary condition that applies to each of the four boundaries. We set up a Python dictionary for this purpose.
#ENCODE BOUNDARY CONDITIONS (MAY NEED ALTERING OR REMOVAL)
integrals_R = []
T_ = Function(V)
vtkfile = File('test2D/solution.pvd')
# fix F
# RUNTIME ERROR
T_= Function(V) # the most recently computed solution
F = action(F,T_)
J = derivative(F, T_,T)
t = dt
bcs = []
while t <= time:
print ('time =', t)
Q.t = t
problem = NonlinearVariationalProblem(F, T_, bcs, J)
solver.solve()
prm = solver.parameters
prm['newton_solver']['absolute_tolerance'] = 1E-9
prm['newton_solver']['relative_tolerance'] = 1E-9
prm['newton_solver']['maximum_iterations'] = 100
prm['newton_solver']['relaxation_parameter'] = 1.0
T_n.assign(T_)
vtkfile << (T_, t)
plot(T_)
p = plot(T_)
p.set_cmap("inferno")
#p.set_clim(0,100)
plt.colorbar(p)
plt.savefig("test2D.png")
