I have a function space, created from a MixedElement, consisting of a number of scalar function spaces and 1 vector function space. I can apply a Dirichlet boundary condition to the scalar function spaces, but I haven’t been able to do the same for the vector function space.
A MWE is:
from dolfinx import fem, mesh
# dolfinx version is 0.4.2.0 - run with docker
domain = mesh.create_unit_square(MPI.COMM_WORLD, 20, 20, mesh.CellType.triangle)
aFE = ufl.FiniteElement("CG", domain.ufl_cell(), 1)
bFE = ufl.VectorElement("CG", domain.ufl_cell(), 1)
ME = fem.FunctionSpace(domain, ufl.MixedElement([aFE, bFE]))
# Determine boundary facets
tdim = domain.topology.dim
fdim = tdim - 1
boundary_facets = np.flatnonzero(mesh.compute_boundary_facets(domain.topology))
# Dirichlet bc for a - no errors
boundary_dofs_a = fem.locate_dofs_topological(ME.sub(0), fdim, boundary_facets)
bc_a = fem.dirichletbc(ScalarType(1.0), boundary_dofs_a, ME.sub(0))
# Dirichlet bc for b
b_D = np.array((1.0,)*domain.geometry.dim, dtype=ScalarType)
boundary_dofs_b = fem.locate_dofs_topological(ME.sub(1), fdim, boundary_facets)
# The below line results in a runtime error
bc_b = fem.dirichletbc(b_D, boundary_dofs_b, ME.sub(1))
This results in the runtime error:
RuntimeError: Creating a DirichletBC using a Constant is not supported when the Constant size is not equal to the block size of the constrained (sub-)space. Use a Function to create the DirichletBC.
I have tried using a function instead but with no success. The full error message from the MWE is
File "/usr/local/dolfinx-real/lib/python3.8/dist-packages/dolfinx/fem/bcs.py", line 136, in __init__
super().__init__(_value, dofs, V)
TypeError: __init__(): incompatible constructor arguments. The following argument types are supported:
1. dolfinx.cpp.fem.DirichletBC_float64(g: float, dofs: numpy.ndarray[numpy.int32], V: dolfinx::fem::FunctionSpace)
2. dolfinx.cpp.fem.DirichletBC_float64(g: numpy.ndarray[numpy.float64], dofs: numpy.ndarray[numpy.int32], V: dolfinx::fem::FunctionSpace)
3. dolfinx.cpp.fem.DirichletBC_float64(g: dolfinx::fem::Constant<double>, dofs: numpy.ndarray[numpy.int32], V: dolfinx::fem::FunctionSpace)
4. dolfinx.cpp.fem.DirichletBC_float64(g: dolfinx::fem::Function<double>, dofs: numpy.ndarray[numpy.int32])
5. dolfinx.cpp.fem.DirichletBC_float64(g: dolfinx::fem::Function<double>, dofs: List[numpy.ndarray[numpy.int32][2]], V: dolfinx::fem::FunctionSpace)
Invoked with: array([1., 1.]), array([ 3, 4, 5, 6, 7, 8, 13, 14, 16, 17, 25,
26, 28, 29, 40, 41, 43, 44, 58, 59, 61, 62,
79, 80, 82, 83, 103, 104, 106, 107, 130, 131, 133,
134, 160, 161, 163, 164, 193, 194, 196, 197, 229, 230,
232, 233, 268, 269, 271, 272, 310, 311, 313, 314, 355,
356, 358, 359, 403, 404, 406, 407, 454, 455, 457, 458,
508, 509, 511, 512, 565, 566, 568, 569, 625, 626, 628,
629, 688, 689, 691, 692, 694, 695, 751, 752, 754, 755,
808, 809, 811, 812, 862, 863, 865, 866, 913, 914, 916,
917, 961, 962, 964, 965, 1006, 1007, 1009, 1010, 1048, 1049,
1051, 1052, 1087, 1088, 1090, 1091, 1123, 1124, 1126, 1127, 1156,
1157, 1159, 1160, 1186, 1187, 1189, 1190, 1213, 1214, 1216, 1217,
1237, 1238, 1240, 1241, 1258, 1259, 1261, 1262, 1276, 1277, 1279,
1280, 1291, 1292, 1294, 1295, 1303, 1304, 1306, 1307, 1312, 1313,
1315, 1316, 1318, 1319, 1321, 1322], dtype=int32), FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2))
File "/root/fenicsx/thickness/testFS.py", line 58, in <module>
File "/usr/local/dolfinx-real/lib/python3.8/dist-packages/dolfinx/fem/bcs.py", line 181, in dirichletbc
return formcls(value, dofs, V)
File "/usr/local/dolfinx-real/lib/python3.8/dist-packages/dolfinx/fem/bcs.py", line 138, in __init__
super().__init__(_value, dofs, V._cpp_object)
Thanks in advance!
