Since there are so many views on my question, I decided to share my code and my solution.
The idea ist based on the github code:
and the paper
Computational homogenization of time-harmonic Maxwell’s equations
Patrick Henning and Anna Persson
Here is the piece of code for computation in 2 D:
from dof2edge2 import *
mesh = UnitSquareMesh(1,1)
print(“Lagrange basis functions”)
LA = FiniteElement(‘Lagrange’,triangle,1)
Q = FunctionSpace(mesh,LA)
w = TrialFunction(Q)
tau = TestFunction(Q)
L = assemble(w * tau * dx).array()
v_d=vertex_to_dof_map(Q)
psi=np.zeros(mesh.num_vertices())
for vertt in vertices(mesh):
psi[vertt.index()] = L[v_d[vertt.index()],v_d[vertt.index()]]
print("||phi_0||_omega^{2}",psi)
print(“manual solution”)
phi_basic = Function(Q)
e_vector = np.zeros(mesh.num_vertices())
for k in range(mesh.num_vertices()):
e_vector[v_d[k]]=1
phi_basic.vector().set_local(e_vector)
e_vector[v_d[k]]=0
sol = assemble(phi_basic * phi_basic * dx)
solely = assemble(phi_basic*dx) # integral over a basis function
print("||phi_0||_omega^{2}",sol)
print("\int_Omega phi_0 dx",solely)
print(“Nedelec basis functions”)
NE = FiniteElement(‘N1curl’,triangle,1)
Q1 = FunctionSpace(mesh,NE)
w1 = TrialFunction(Q1)
tau1 = TestFunction(Q1)
L = assemble(inner(w1,tau1)*dx).array()
d2e, e2d = dof2edge(mesh)
psi1=np.zeros(mesh.num_edges())
for E in edges(mesh):
psi1[E.index()] = L[e2d[E.index()],e2d[E.index()]]
print("||phi_0||_omega^{2}",psi1)
phi_basic1 = Function(Q1)
e_vector = np.zeros(mesh.num_edges())
for k in range(mesh.num_edges()):
e_vector[e2d[k]]=1
phi_basic1.vector().set_local(e_vector)
e_vector[e2d[k]]=0
sol = assemble(inner(phi_basic1,phi_basic1)*dx)
assemble((phi_basic1[0]*Constant(1))*dx +(phi_basic1[1]*Constant(1))*dx )
The code in dof2edge2.py constructs a mapping between the numbering of the edges and degrees of freedom.
dof2edge2.py: (Code of Anna Persson)
import scipy.sparse as sps
print(" Computes two mappings: dof to edge and edge to dof")
def dof2edge(mesh):
V = FunctionSpace(mesh, 'N1curl', 1)
N = V.dim()
# Cell to edge map
cell2edges = V.mesh().topology()(2, 1)
# Cell to dof map
cell2dofs = V.dofmap().cell_dofs
dof2edge = np.zeros(mesh.num_edges(), dtype="int")
edge2dof = np.zeros(mesh.num_edges(), dtype="int")
# Iterate over cells, associating the edges to the dofs for that cell
for c in range(mesh.num_cells()):
# get the global edge numbers for this cell
c_edges = cell2edges(c)
# get the global dof numbers for this cell
c_dofs = cell2dofs(c)
# associate the edge numbers to the corresponding dof numbers and vice versa
dof2edge[c_dofs] = c_edges
edge2dof[c_edges] = c_dofs
return dof2edge, edge2dof
I hope this helps other people to solve similar problems.
