I am trying to reach the first-order Nedelec function for any edge of the element. I defined a basis function on any element, for example a master triangular element. Now, I want to access the basis function of any edge. For example, I want to access the basis function of the hypotenuse edge for the master triangle that I defined in the code. How can I do that?
For master triangle:
V_coarse = FunctionSpace(mesh_coarse, (“Nedelec 1st kind H(curl)”, 1))
u_coarse = TrialFunction(V_coarse)
v_coarse = TestFunction(V_coarse) -
I defined the Nedelec basis functions for the master triangle in the example. I also defined Nedelec basis functions for a different geometry. I want to obtain the inner product of the basis functions of my new element (9-sided finer geometry) with the basis function that I found corresponding to any side of the master triangle (obtained result from my first question).
x = np.array([[0.0, 0.0], # Vertex 0
[1.0, 0.0], # Vertex 1
[0.0, 1.0], # Vertex 2
[0.5, 0.0], # Vertex 3 (midpoint of edge 0-1)
[0.5, 0.5], # Vertex 4 (midpoint of edge 1-2)
[0.0, 0.5]]) # Vertex 5 (midpoint of edge 2-0)
cells = np.array([[0, 3, 5], # Lower left triangle
[3, 1, 4], # Lower right triangle
[3, 4, 5], # Middle triangle
[5, 4, 2]], # Top triangle
dtype=np.int32)
mesh_fine = dolfinx.mesh.create_mesh(MPI.COMM_WORLD, cells, x, domain)
After multiplying these vectors, I want to do the integration in new smaller triangles (inner product calculation on the finer geometry). I couldn’t do this with built-in functions, the functions in similar questions I found on this website seem cannot be applicable for Fenicsx, I wonder how I can do this. Shortly, I would like to ask how I can calculate the inner product of Nedelec basis functions of different meshes in any geometry.
- Finally, how can I reach the basis function or norm of the basis function at any point in the cell? For example, for the master triangle, how can I reach basis function norm value or corresponding total basis function at the midpoint or any point of the triangle?
Thank you very much,
