I have a mesh script where I entered the dimension for a concrete slab and three steel bars in inches:
proc = MPI.COMM_WORLD.rank
concrete_marker = 11
rebar_marker = 12
if proc == 0:
gmsh.model.add("concreteslab")
concrete = gmsh.model.occ.add_box(-12, -3, -72, 24, 6, 144)
bary = 2
gmsh.option.setNumber('Mesh.MeshSizeFromCurvature', 5)
cylinder1 = gmsh.model.occ.addCylinder(-10, -bary, 72, 0, 0, -144, .5)
cylinder2 = gmsh.model.occ.addCylinder(0, -bary, 72, 0, 0, -144, .5)
cylinder3 = gmsh.model.occ.addCylinder(10, -bary, 72, 0, 0, -144, .5)
gmsh.model.occ.synchronize()
volTags = gmsh.model.getEntities(3)
gmsh.model.occ.fragment(volTags, volTags)
gmsh.model.addPhysicalGroup(3, [concrete], concrete_marker)
gmsh.model.addPhysicalGroup(3, [cylinder1, cylinder2, cylinder3], rebar_marker)
gmsh.model.mesh.generate(3)
gmsh.write("mesh3D.msh")
gmsh.finalize()
I modified demo_elasticity so that the mesh of the slab (mesh3D.msh) can pass through the python system:
from contextlib import ExitStack
from dolfinx import la
from dolfinx.fem import (Expression, Function, FunctionSpace,
VectorFunctionSpace, dirichletbc, form,
locate_dofs_topological, locate_dofs_geometrical)
set_bc)
from dolfinx.mesh import (CellType, GhostMode, create_box,
locate_entities_boundary)
from ufl import dx, grad, inner
dtype = PETSc.ScalarType
from dolfinx.io import gmshio
import pyvista
from dolfinx import plot
out_mesh = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
return out_mesh
def build_nullspace(V):
index_map = V.dofmap.index_map
bs = V.dofmap.index_map_bs
ns = [la.create_petsc_vector(index_map, bs) for i in range(6)]
with ExitStack() as stack:
vec_local = [stack.enter_context(x.localForm()) for x in ns]
basis = [np.asarray(x) for x in vec_local]
dofs = [V.sub(i).dofmap.list.array for i in range(3)]
for i in range(3):
basis[i][dofs[i]] = 1.0
dofs_block = V.dofmap.list.array
x0, x1, x2 = x[dofs_block, 0], x[dofs_block, 1], x[dofs_block, 2]
basis[3][dofs[0]] = -x1
basis[3][dofs[1]] = x0
basis[4][dofs[0]] = x2
basis[4][dofs[2]] = -x0
basis[5][dofs[2]] = x1
basis[5][dofs[1]] = -x2
la.orthonormalize(ns)
assert la.is_orthonormal(ns)
return PETSc.NullSpace().create(vectors=ns)
slabdomaingmshio, cell_markers, facet_markers = gmshio.read_from_msh("mesh3D.msh", MPI.COMM_WORLD, gdim=3)
slabmeshio = meshio.read("mesh3D.msh")
tetra_mesh = create_mesh(slabmeshio, "tetra", prune_z=False)
with XDMFFile(MPI.COMM_WORLD, "mesh.xdmf", "r") as xdmf:
slabdomaingmshio = xdmf.read_mesh(name="Grid")
ct = xdmf.read_meshtags(slabdomaingmshio, name="Grid")
Q = FunctionSpace(slabdomaingmshio, ("DG", 0))
Emod = Function(Q)
concrete = ct.find(11)
Emod.x.array[concrete] = np.full_like(concrete, 4.3e6, dtype=PETSc.ScalarType)
steel = ct.find(12)
Emod.x.array[steel] = np.full_like(steel, 30e6, dtype=PETSc.ScalarType)
VMod = Function(Q)
VMod.x.array[concrete] = np.full_like(concrete, 0.15, dtype=PETSc.ScalarType)
VMod.x.array[steel] = np.full_like(steel, 0.28, dtype=PETSc.ScalarType)
ω, ρ = 5000, 33.3
x = ufl.SpatialCoordinate(slabdomaingmshio)
f = ufl.as_vector((ρ * ω**2 * x[0], ρ * ω**2 * x[1], 0.0))
μ = Emod / (2.0 * (1.0 + VMod))
λ = Emod * VMod / ((1.0 + VMod) * (1.0 - 2.0 * VMod))
def σ(v):
"""Return an expression for the stress σ given a displacement field"""
return 2.0 * μ * ufl.sym(grad(v)) + λ * ufl.tr(ufl.sym(grad(v))) * ufl.Identity(len(v))
V = VectorFunctionSpace(slabdomaingmshio, ("Lagrange", 1))
u = ufl.TrialFunction(V)
a = form(inner(σ(u), grad(v)) * dx)
L = form(inner(f, v) * dx)
dofs_L = locate_dofs_geometrical(V, lambda x: np.isclose(x[2], -72))
u_L = Function(Q)
bc_L = dirichletbc(PETSc.ScalarType(0), dofs_L,Q)
dofs_R = locate_dofs_geometrical(V, lambda x: np.isclose(x[2], 72))
u_R = Function(Q)
bc_R = dirichletbc(PETSc.ScalarType(0), dofs_R,Q)
bcs = [bc_L,bc_R]
A = assemble_matrix(a, bcs=bcs)
b = assemble_vector(L)
apply_lifting(b, [a], bcs=[bcs])
set_bc(b, bcs)
null_space = build_nullspace(V)
A.setNearNullSpace(null_space)
opts = PETSc.Options()
opts["ksp_type"] = "cg"
opts["ksp_rtol"] = 1.0e-10
opts["pc_type"] = "gamg"
opts["mg_levels_ksp_type"] = "chebyshev"
opts["mg_levels_pc_type"] = "jacobi"
opts["mg_levels_esteig_ksp_type"] = "cg"
opts["mg_levels_ksp_chebyshev_esteig_steps"] = 20
solver = PETSc.KSP().create(slabdomaingmshio.comm)
solver.setFromOptions()
solver.setOperators(A)
uh = Function(V)
solver.setMonitor(lambda _, its, rnorm: print(f"Iteration: {its}, rel. residual: {rnorm}"))
solver.solve(b, uh.vector)
solver.view()
uh.x.scatter_forward()
sigma_dev = σ(uh) - (1 / 3) * ufl.tr(σ(uh)) * ufl.Identity(len(uh))
sigma_vm = ufl.sqrt((3 / 2) * inner(sigma_dev, sigma_dev))
W = FunctionSpace(slabdomaingmshio, ("Discontinuous Lagrange", 0))
sigma_vm_expr = Expression(sigma_vm, W.element.interpolation_points())
sigma_vm_h = Function(W)
sigma_vm_h.interpolate(sigma_vm_expr)
with XDMFFile(slabdomaingmshio.comm, "out_elasticity/displacements.xdmf", "w") as file:
file.write_mesh(slabdomaingmshio)
file.write_function(uh)
with XDMFFile(slabdomaingmshio.comm, "out_elasticity/von_mises_stress.xdmf", "w") as file:
file.write_function(sigma_vm_h)
unorm = uh.x.norm()
if slabdomaingmshio.comm.rank == 0:
print("Solution vector norm:", unorm)
#pyvista.start_xvfb()
#pyvista.OFF_SCREEN = True
# Create plotter and pyvista grid
#p = pyvista.Plotter()
#topology, cell_types, geometry = plot.create_vtk_mesh(V)
#grid = pyvista.UnstructuredGrid(topology, cell_types, geometry)
# Attach vector values to grid and warp grid by vector
#grid["u"] = uh.x.array.reshape((geometry.shape[0], 3))
#actor_0 = p.add_mesh(grid, style="wireframe", color="k")
#warped = grid.warp_by_vector("u", factor=1.5)
#actor_1 = p.add_mesh(warped, show_edges=True)
#p.show_axes()
#if not pyvista.OFF_SCREEN:
# p.show()
#else:
# figure_as_array = p.screenshot("deflection.png")
#print('done')
This leads to a number of questions I have so far:
- I would like to enter a distributed load in pounds per foot. What are the units of w in this case? How can I enter a distributed load in pounds per foot?
- I would like to look at stress from the exported von_misses_stress.xdmf in PSI. I am attaching a screenshot of what I see in ParaView at the end of this post. So far units for stress (sigma) look nothing in the PSI range. How can I get an export of von_misses_stress.xdmf in PSI?
- In terms of displacements.xdmf there is one being generated. How is it possible in Paraview to get annotations of either current x,y,z of the displacement or an image map showing the largest displacement that occurs from Paraview?
- In terms of the commented out PyVista code at then end of the script, I tried running it in conda,spack and also container environments. deflection.png is the type of image I want for a deflection map. Things seem to lock up at:
p.show() <<-- seems to lock up the system
figure_as_array = p.screenshot("deflection.png") <<--also seems to lock up the system
