How to make sure the subdomains are connected in built-in mesh?
Hi all,
I am modifying the this example to a geometry with an extra subdomain on the upper half. The subdomain definitions are
Omega = {
    0 : lambda x: x[1] <= 0.5, # lower half of the mesh
    # a block at the middle on the upper half of the mesh
    1 : lambda x : np.logical_and(
        np.logical_and(x[0] >= 1/3, x[0] <= 2/3),
        x[1] >= 0.75
# the remaining part in the upper mesh
Omega[2] = lambda x : np.logical_and(x[1] >= 0.5, np.logical_not(Omega[1](x)))
I assigned the same \kappa value to subdomain 1 and 2 so that the expect solution should be the same as if there are only 2 subdomains. However, the solution is Nan. I have tried chopping the upper mesh into half and solution is valid. So, what is the best practice to implement subdomains to make sure they are connected? I appreciate for the help. Below if the script to reproduce the issue.
from dolfinx import mesh, fem
from dolfinx.fem import FunctionSpace
domain = mesh.create_unit_square(MPI.COMM_WORLD, 30, 30)
Q = FunctionSpace(domain, ('DG', 0))
Omega = {
    # this division works
    # 1 : lambda x : np.logical_and(x[1] >= 0.5, x[0] <= 0.5),
    # 2 : lambda x : np.logical_and(x[1] >= 0.5, x[0] >= 0.5),
        x[1] >= 0.75
cells = {
    tag : mesh.locate_entities(domain, domain.topology.dim, omega) for tag, omega in Omega.items()
domain_indices = [cell for _, cell in cells.items()]
domain_markers = [np.full_like(cell, tag) for tag, cell in cells.items()]
domain_indices = np.hstack(domain_indices).astype(np.int32)
domain_markers = np.hstack(domain_markers).astype(np.int32)
sorted_domain = np.argsort(domain_indices)
subdomain_tag = mesh.meshtags(domain, domain.topology.dim, domain_indices[sorted_domain], domain_markers[sorted_domain])
dx = ufl.Measure('dx', domain=domain, subdomain_data=subdomain_tag)
Q = FunctionSpace(domain, ('DG',0))
kappa = fem.Function(Q)
kappa_values = {
    0 : 1,
    1 : 0.1,
    2 : 0.1,
for tag, value in kappa_values.items():
    cell = cells[tag]
    kappa.x.array[cell] = np.full_like(cell, value, dtype=ScalarType)
V = FunctionSpace(domain, ('CG', 1))
u = ufl.TrialFunction(V)
s = fem.Constant(domain, ScalarType(1.))
a = kappa * ufl.inner(ufl.grad(u), ufl.grad(v)) * dx
L = ufl.inner(s, v) * dx
dofs = fem.locate_dofs_geometrical(V, lambda x : np.isclose(x[0], 0))
bcs = [fem.dirichletbc(ScalarType(1.), dofs, V)]
problem = fem.petsc.LinearProblem(a, L, bcs=bcs, petsc_options={'ksp_type': 'preonly', 'pc_type': 'lu'})
uh = problem.solve()
import pyvista
pyvista.start_xvfb()
print(pyvista.global_theme.jupyter_backend)
num_cells_local = domain.topology.index_map(domain.topology.dim).size_local
marker = np.zeros(num_cells_local, dtype=np.int32)
for tag, cell in cells.items():
    cell = cell[cell < num_cells_local]
    marker[cell] = tag
topology, cell_types, geometry = create_vtk_mesh(domain, domain.topology.dim, np.arange(num_cells_local, dtype=np.int32))
grid = pyvista.UnstructuredGrid(topology, cell_types, geometry)
grid.cell_data['Marker'] = marker
grid.set_active_scalars('Marker')
plotter = pyvista.Plotter()
plotter.view_xy()
if not pyvista.OFF_SCREEN:
    plotter.show()
u_topology, u_cell_types, u_geometry = create_vtk_mesh(V)
u_grid = pyvista.UnstructuredGrid(u_topology, u_cell_types, u_geometry)
u_grid.point_data['u'] = uh.x.array
u_grid.set_active_scalars('u')
u_plotter = pyvista.Plotter()
u_plotter.add_mesh(u_grid, show_edges=True)
u_plotter.view_xy()
    u_plotter.show()
So just to let me clarify, you want to split the domain into three separate regions, that doesn’t necessarily align with your grid. If you want to do so, I would start by marking all cells with a given value:
Omega = {
        x[1] >= 0.75
cell_map = domain.topology.index_map(domain.topology.dim)
all_cells = np.arange(cell_map.size_local+cell_map.num_ghosts, dtype=np.int32)
# Start by marking all cells with 1
values = np.full_like(all_cells,1, dtype=np.int32)
# Mark 0-value cells
dofs_0 = mesh.locate_entities(domain, domain.topology.dim, Omega[0])
values[dofs_0] = np.full_like(dofs_0, 0, dtype=np.int32)
# Mark 2-value cells
dofs_2 = mesh.locate_entities(domain, domain.topology.dim, Omega[2])
values[dofs_2] = np.full_like(dofs_2, 2, dtype=np.int32)
subdomain_tag = mesh.meshtags(domain, domain.topology.dim, all_cells, values)
with XDMFFile(MPI.COMM_WORLD, "cell_tag.xdmf", "w") as xdmf:
    xdmf.write_mesh(domain)
    xdmf.write_meshtags(subdomain_tag, domain.geometry)
kappa_values = {
    0 : 1,
    1 : 0.1,
    2 : 0.3,
    cell = subdomain_tag.find(tag)
with XDMFFile(MPI.COMM_WORLD, "kappa.xdmf", "w") as xdmf:
    xdmf.write_function(kappa)
If you make the domains align with the grid, you won’t see a band of cells that doesn’t satisfy either criteria.
