How to pass quadratic quadrilateral mesh from `dolfinx.io.gmshio` to PyVista?
Hello!
Brief description (goal)
I am trying to pass a mesh with qudrangles to PyVista. The mesh has lagrangean quadratic elements (“Lagrange”, degree=2), and is made with Gmsh. Then, it is imported with dolfinx.io.gmshio.
What is going on
I only see triangular elements on PyVista. The same thing happens with dolfinx.mesh.create_unit_square.
Minimal working example (MWE)
Both of these show the same with all the data formats.
::: captioned-content
::: caption
Here, I am only showing the code with dolfinx.mesh.create_unit_square.
import basix
from dolfinx.fem import functionspace
from dolfinx import fem
from dolfinx import mesh
from dolfinx import io
import dolfinx.fem.petsc as petsc
from dolfinx import plot
import pyvista
fe_degree = 2
domain = mesh.create_unit_square(
      MPI.COMM_WORLD, 8, 8, mesh.CellType.quadrilateral)
gdim = domain.geometry.dim
element = basix.ufl.element(
    family="Lagrange", cell=basix.CellType.quadrilateral,
    # family="Lagrange", cell=domain.basix_cell(),
    shape=(gdim,), degree=fe_degree)
V = functionspace(domain, element)
topology, cell_types, geometry = plot.vtk_mesh(V)
vtu = pyvista.UnstructuredGrid(
  topology, cell_types, geometry)
pvpl = pyvista.Plotter(window_size=[200, 200])
pvpl.add_mesh(vtu, show_edges=True)
pvpl.view_xy()
pvpl.show()
import basix
import pyvista
fe_degree = 2
simu_name = "quadrangles"
mesh_comm = MPI.COMM_WORLD
model_rank = 0
    gmsh.option.set_number("Geometry.CopyMeshingMethod", 2)
    gmsh.option.setNumber('General.Verbosity', 0)
    gmsh.model.mesh.setOrder(fe_degree)
    # Do your best at creating quadrangles
    gmsh.option.setNumber("Mesh.Algorithm", 8)
    gmsh.option.setNumber("Mesh.RecombinationAlgorithm", 2)
    gmsh.option.setNumber("Mesh.RecombineAll", 1)
    gmsh.model.add(simu_name)
    gmsh.model.setCurrent(simu_name)
    occ = gmsh.model.occ
    lc = 1e-3
    quad_mesh = True
    quart_orig = (0, 0, 0)
    square_ratio = 0.4
    n_pts = (3, 3)
    div_factor = (0.5, 0.5)
    mesh_type = ["Bump", "Bump"]
    tag = gmsh.model.occ.add_rectangle(0, 0, 0, 1, 1, roundedRadius=0)
    occ.synchronize()
    gmsh.model.add_physical_group(2, [tag], 1)
    occ.synchronize()
    gmsh.model.mesh.generate(2)
mesh_gmsh, cell_tags, facet_tags = io.gmshio.model_to_mesh(
    gmsh.model, mesh_comm, model_rank, gdim=2)
    gmsh.fltk.run()
    gmsh.finalize()
domain = mesh_gmsh
pvpl.view_xy()
pvpl.save_graphic("q.svg")
pvpl.show()
with io.XDMFFile(domain.comm, "output.xdmf", "w") as xdmf:
    xdmf.write_mesh(domain)
Gmsh
PyVista
ParaView
XDMF (can’t upload otherwise)
::: caption
output.xdmf
<?xml version="1.0"?>
<!DOCTYPE Xdmf SYSTEM "Xdmf.dtd" []>
<Xdmf Version="3.0" xmlns:xi="https://www.w3.org/2001/XInclude">
  <Domain>
    <Grid Name="mesh" GridType="Uniform">
      <Topology TopologyType="Quadrilateral" NumberOfElements="64" NodesPerElement="4">
        <DataItem Dimensions="64 4" NumberType="Int" Format="HDF">output.h5:/Mesh/mesh/topology</DataItem>
      </Topology>
      <Geometry GeometryType="XY">
        <DataItem Dimensions="81 2" Format="HDF">output.h5:/Mesh/mesh/geometry</DataItem>
      </Geometry>
    </Grid>
  </Domain>
</Xdmf>
My system
(I also tested on 0.7.0.dev0~r27554~.cfeffe0-1)
- FEniCSx software
  dolfinx: 0.8.0.dev0_r27568.a34b0c9-1
  basix: 0.8.0.dev0_r952.eebbc52-1
  ufl: 2023.3.0.dev0_r3568.f132188-1
  ffcx: 0.8.0.dev0_r7083.b4cb217-1
- Dependencies
  python: 3.11.5-2
  python-numpy: 1.26.0-1
  petsc: 3.19.5.1171.g37df9106526-1
  hdf5-openmpi: 1.14.2-1
  boost: 1.83.0-2
  adios2: 2.8.3-5
  scotch: 7.0.4-1
  pybind11: 2.11.1-1
  python-build: 1.0.1-1
  python-cffi: 1.15.1-4
  python-cppimport: 22.08.02.r6.g0849d17-1
  python-installer: 0.7.0-3
  python-mpi4py: 3.1.4-3
  python-pytest: 7.4.2-1
  python-scikit-build: 0.17.6-1
  python-setuptools: 1:68.0.0-1
  python-wheel: 0.40.0-3
  xtensor: 0.24.0-2
  xtensor-blas: 0.20.0-1
- Operating system
  Arch Linux: 6.5.4-arch2-1
Pyvista has an issue with edge visualization of higher order, see: VTK_LAGRANGE_HEXAHEDRON not supported with showing edges · Issue #947 · pyvista/pyvista · GitHub
Thus the mesh visualized is a quadrilateral mesh, pyvista just adds multiple extra edges to it.
