How to set 'boundary condition' inside the boundary?
I am solving the coupling equation for displacement(u) and (p).
The current topic is “Cryer’s problem” with such boundary conditions :
Cryers-problem-of-a-clay-sphere
  • u(r=0) = 0
  • p(r=R) = 0
    where R is the radius of the sphere.
I could deal with pressure at the boundary, as it is laterally boundary condition.
However, for the center, I am not sure how to implement this ‘boundary condition’, u(r=0)=0
What I have tried is as follows :
# Define function spaces
u_elem     = VectorElement('CG', domain.ufl_cell(), 2) # displacement(2D)
p_elem     = FiniteElement('CG', domain.ufl_cell(), 1) # pore water pressure(scalar)
V    = FunctionSpace(domain, MixedElement([u_elem, p_elem])) #Define vector function space for [u,p]
#Set space for u and p from V
U = FunctionSpace(domain, u_elem)
P = FunctionSpace(domain, p_elem)
def center(x):
    return x[0]**2 + x[1]**2 < (0.1*R)**2
cells_center = locate_entities(domain, dim, center)
#Dirichlet BC for u : center
U, _ = V.sub(0).collapse()
u_bc = Function(U)
u_bc.x.set(0)
#center : u = 0
boundary_dofs_u_center = locate_dofs_topological((V.sub(0), U), dim, cells_center)
BC_u_center = dirichletbc(np.full_like(boundary_dofs_u_center, 0, dtype=ScalarType)[0], boundary_dofs_u_center, V.sub(0))
which followed the demo code of ‘’ Defining subdomains for different materials".
The error message is as follows :
TypeError                                 Traceback (most recent call last)
File /usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/bcs.py:125, in DirichletBCMetaClass.__init__(self, value, dofs, V)
    124 try:
--> 125     super().__init__(_value, dofs, V)  # type: ignore
    126 except TypeError:
TypeError: __init__(): incompatible constructor arguments. The following argument types are supported:
    1. dolfinx.cpp.fem.DirichletBC_float64(g: numpy.ndarray[numpy.float64], dofs: numpy.ndarray[numpy.int32], V: dolfinx::fem::FunctionSpace)
    2. dolfinx.cpp.fem.DirichletBC_float64(g: dolfinx::fem::Constant<double>, dofs: numpy.ndarray[numpy.int32], V: dolfinx::fem::FunctionSpace)
    3. dolfinx.cpp.fem.DirichletBC_float64(g: dolfinx::fem::Function<double>, dofs: numpy.ndarray[numpy.int32])
    4. dolfinx.cpp.fem.DirichletBC_float64(g: dolfinx::fem::Function<double>, dofs: List[numpy.ndarray[numpy.int32][2]], V: dolfinx::fem::FunctionSpace)
Invoked with: array([0., 0., 0., 0., 0., 0., 0., 0., 0., 0., 0., 0., 0., 0., 0., 0., 0.,
       0.]), [array([1796, 1797, 1888, 1889, 1901, 1902, 2041, 2042, 2043, 2044, 2045,
       2046, 2133, 2134, 2137, 2138, 2140, 2141], dtype=int32), array([1270, 1271, 1260, 1261, 1268, 1269, 1460, 1461, 1462, 1463, 1456,
       1457, 1482, 1483, 1478, 1479, 1480, 1481], dtype=int32)], FunctionSpace(Mesh(VectorElement(Basix element (P, triangle, 1, equispaced, unset, False), 2), 0), VectorElement(FiniteElement('Lagrange', triangle, 2), dim=2))
Cell In[17], line 20
     16 #center : u = 0
     17 #boundary_dofs_u_center = locate_dofs_topological((V.sub(0), U), bdim, boundary_facets_center)
     18 #BC_u_center = dirichletbc(u_bc, boundary_dofs_u_center, V.sub(0))
     19 boundary_dofs_u_center = locate_dofs_topological((V.sub(0), U), dim, cells_center)
---> 20 BC_u_center = dirichletbc(np.full_like(boundary_dofs_u_center, 0, dtype=ScalarType)[0], boundary_dofs_u_center, V.sub(0))
     22 #Dirichlet BC for p : surface
     23 P, _ = V.sub(1).collapse()
File /usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/bcs.py:183, in dirichletbc(value, dofs, V)
    180     raise AttributeError("Boundary condition value must have a dtype attribute.")
    182 formcls = type("DirichletBC", (DirichletBCMetaClass, bctype), {})
--> 183 return formcls(value, dofs, V)
File /usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/bcs.py:127, in DirichletBCMetaClass.__init__(self, value, dofs, V)
--> 127         super().__init__(_value, dofs, V._cpp_object)  # type: ignore
    128 else:
    129     super().__init__(_value, dofs)
       1457, 1482, 1483, 1478, 1479, 1480, 1481], dtype=int32)], <dolfinx.cpp.fem.FunctionSpace object at 0x7f68ce2abdb0>
Could you help me to implement this setting?
ALSO, If you can suggest better function for defining center compared to this code :
def center(x):
Please let me know. It seems that np.isclose might not work depending on mesh cell size.
Thanks.
Here you are mixing approaches, how about using
Dear Dokken,
Thanks for your help, it works!
Also, could you comment on this one?
def center(x):
My mesh is like this :
Screenshot from 2023-05-24 16-05-21
Always thanks.
You should really mark the center of your mesh during mesh creation, rather than doing it using geometrical information after mesh creation.
Thanks for your reply.
I think I understand what you mean.
Here is the code for mesh generation (by following the “Electromagnetics example” demo code)
rank = MPI.COMM_WORLD.rank
R = 1
gdim = 2  # Geometric dimension of the mesh
model_rank = 0
mesh_comm = MPI.COMM_WORLD
    # Define geometry for background
    background = gmsh.model.occ.addDisk(0, 0, 0, R, R)
    gmsh.model.occ.synchronize()
    whole_domain = gmsh.model.addPhysicalGroup(gdim, [background], 1)
    # Generate mesh
    gmsh.model.mesh.field.setNumber(2, "IField", 1)
    #gmsh.model.mesh.field.setNumber(2, "LcMin", 0.1)
    gmsh.model.mesh.field.setNumber(2, "LcMax", 0.1)
    #gmsh.model.mesh.field.setNumber(2, "DistMin", 1)
    #gmsh.model.mesh.field.setNumber(2, "DistMax", 1)
    gmsh.model.mesh.field.add("Min", 5)
    gmsh.model.mesh.field.setNumbers(5, "FieldsList", [2])
    gmsh.model.mesh.field.setAsBackgroundMesh(5)
    gmsh.option.setNumber("Mesh.Algorithm", 7)
domain, ct, _ = model_to_mesh(gmsh.model, mesh_comm, model_rank, gdim)
gmsh.finalize()
Here I set the tag for the circle as 1.
Can I use this tag 1 or should define ‘center’ again?
Do you actually want to have a vertex in the center of the mesh? If so I would try to explicitly enforce that.
How can I find some materials to implement such settings?
http://onelab.info/pipermail/gmsh/2019/013265.html
For a different perspective, note that you’ve got spherical symmetry. You could just use a 1D domain along the coordinate r, you don’t need to run a 2D or 3D calculation. In that case the boundary condition at r=0 can be handled naturally.
Dear Dokken,
Thanks to your reply, I applied the marker at the center as follows :
# https://github.com/FEniCS/dolfinx/blob/main/python/demo/demo_gmsh.py
R = 1
model_rank = 0
    # Define geometry for center
    center = gmsh.model.occ.addPoint(0, 0, 0)
    background_domain = gmsh.model.addPhysicalGroup(gdim, [background], 1)
    center_domain = gmsh.model.addPhysicalGroup(0, [center], 1)
    # Generate mesh
gmsh.finalize()
with XDMFFile(MPI.COMM_WORLD, "mt.xdmf", "w") as xdmf:
    xdmf.write_mesh(domain)
    xdmf.write_meshtags(ct)
x = SpatialCoordinate(domain)
dim = domain.topology.dim
bdim = dim - 1
However, If I run this code, the Python kernel is broken, even without any error message. It seems that the code for the marking center would have some problems :
How should I fix my code?
Always thanks.
The link
I suggested didnt suggest adding a physical tag, but using the embed command, as follows:
from dolfinx.io.gmshio import model_to_mesh
R = 1
model_rank = 0
    gmsh.model.mesh.embed(0, [center], 2, background)
    # Generate mesh
    gmsh.model.mesh.field.setNumber(2, "LcMin", 0.01)
    gmsh.model.mesh.field.setNumber(2, "DistMin", 0.2)
    gmsh.model.mesh.field.setNumber(2, "DistMax", 0.7)
gmsh.finalize()
from dolfinx.mesh import locate_entities
print(locate_entities(domain, 0, lambda x: np.isclose(x[0],0) & np.isclose(x[1], 0)))
Please read through the links I post before asking a question.
Dear Dokken,
Sorry for my poor understanding of your suggested document.
I didn’t come up with using locate_entities, but only concentrate on imposing a marker in the center :sweat_smile:
Thanks for spending your valuable time on my question!
