Hello everyone,
I’m trying to set temperature constraints in Optimal control of heat equation. As I know, one way to do it is penalization technique. So I tried Moreau-Yosida regularization and didn’t get the goal. (state is steal not constrained).
I was wondering, what else can I do to set these constraints or what should be the right way?
Here is my initial code without attemps to use Moreau-Yosida regularization.
from fenics_adjoint import *
from collections import OrderedDict
data = Expression("16*x[0]*(x[0]-1)*x[1]*(x[1]-1)*sin(pi*t)", t=0, degree=4)
nu = Constant(1e-5)
nx = ny = 20
mesh = UnitSquareMesh(nx, ny)
class Left(SubDomain):
return near(x[0], 0.0)
class Right(SubDomain):
return near(x[0], 1.0)
class Bottom(SubDomain):
return near(x[1], 0.0)
class Top(SubDomain):
return near(x[1], 1.0)
left = Left()
top = Top()
right = Right()
bottom = Bottom()
boundaries.set_all(0)
left.mark(boundaries, 1)
top.mark(boundaries, 2)
right.mark(boundaries, 3)
bottom.mark(boundaries, 4)
g1 = Constant("0.01")
g2 = Constant("0.01")
g3 = Constant("0.01")
g4 = Constant("0.01")
ds = ds(subdomain_data = boundaries)
class Obstacle(SubDomain):
return (between(x[1], (0.4, 0.6)) and between(x[0], (0.4, 0.6)))
obstacle = Obstacle()
domains = MeshFunction("size_t", mesh, mesh.topology().dim())
domains.set_all(0)
obstacle.mark(domains, 1)
dx = dx(subdomain_data = domains)
dt = Constant(0.1)
T = 2
steps = 20
ctrls = OrderedDict()
t = float(dt)
while t <= T:
ctrls[t] = Function(V)
t += float(dt)
def solve_heat(ctrls):
f = Function(V, name="source")
u_0 = Function(V, name="solution")
d = Function(V, name="data")
F = ((u - u_0)/dt*v*(dx(0) + dx(1)) + nu*inner(grad(u), grad(v))*dx(0) + nu*inner(grad(u), grad(v))*dx(1) - f*v*dx(1) - g1*v*ds(1) - g2*v*ds(2) - g3*v*ds(3) - g4*v*ds(4))
a, L = lhs(F), rhs(F)
t = float(dt)
j = 0.5*float(dt)*assemble((u_0 - d)**2*(dx(0) + dx(1)))
while t <= T:
f.assign(ctrls[t])
data.t = t
d.assign(interpolate(data, V))
solve(a == L, u_0)
if t > T - float(dt):
weight = 0.5
weight = 1
j += weight*float(dt)*assemble((u_0 - d)**2*(dx(0) + dx(1)))
t += float(dt)
return u_0, d, j
u, d, j = solve_heat(ctrls)
alpha = Constant(1e-2)
regularisation = alpha/2*sum([1/dt*(fb-fa)**2*(dx(0) + dx(1)) for fb, fa in
zip(list(ctrls.values())[1:], list(ctrls.values())[:-1])])
J = j + assemble(regularisation)
m = [Control(c) for c in ctrls.values()]
c_max = 1.5
c_min = -1.5
lower = [interpolate(Constant(c_min), V) for i in range(steps-1)]
upper = [interpolate(Constant(c_max), V) for i in range(steps-1)]
rf = ReducedFunctional(J, m)
opt_ctrls = minimize(rf, options={"maxiter": 50}, bounds = (lower,upper))
Appreciate any help.
