How to bound the solution to a given intervall
I’m working on a PDE which I succeed to solve with Fenics but now I want to constraint a part of the solution to a given interval. In fact I am solving an équation of (u,p) where u is a 2D vector and p a density (scalar).
Before to constraint I was solving my PDE like this:
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
tx=5
ty=tx
nbx=100
nby=nbx
domain=Rectangle(Point(-tx/2,-ty/2),Point(tx/2,ty/2))
mesh=RectangleMesh(Point(-tx/2,-ty/2),Point(tx/2,ty/2),nbx,nby)
V1 = VectorElement("Lagrange", mesh.ufl_cell(), 2)
V2 = FiniteElement("Lagrange", mesh.ufl_cell(), 2)
V = VectorFunctionSpace(mesh,'P',2)
Vs= FunctionSpace(mesh,'P',2)
# Make a mixed space
TH = V1*V2
W = FunctionSpace(mesh, TH)
#Initial conditions
r=2
u_0 = Expression(('r*(rand()-0.5)', 'r*(rand()-0.5)'),degree=2,r=r)
u_alea=interpolate(u_0, W.sub(0).collapse())
p_0 = Expression('0.2', degree=0,r=r)
p_cst=interpolate(p_0, W.sub(1).collapse())
#Declare functions
w=Function(W)
w_1=Function(W)
assign(w,[u_alea,p_cst])
assign(w_1,[u_alea,p_cst])
w_t=TestFunction(W)
(u,p)=split(w)
(u_1,p_1)=split(w_1)
(v,q)=split(w_t)
#Declare constants
mur_g  = 'near(x[0], -2.5)'
mur_d  = 'near(x[0], 2.5)'
mur_b  = 'near(x[1], -2.5)'
mur_h  = 'near(x[1], 2.5)'
bcu_d  = DirichletBC(W.sub(0), Constant((0,1)), mur_d)
bcu_g  = DirichletBC(W.sub(0), Constant((0,-1)), mur_g)
bcu_h  = DirichletBC(W.sub(0), Constant((-1,0)), mur_h)
bcu_b  = DirichletBC(W.sub(0), Constant((1,0)), mur_b)
bcu = [bcu_d,bcu_b,bcu_g,bcu_h]
lamb=Constant(0.7) #SD
alph= Constant(1e2) #s-1
pho_c=Constant(3e-3) #SD
pho=Constant(0.1) #SD
a2=Constant(alph*(pho-pho_c)) #s-1
a4=Constant(10) #mm-2 s
D=Constant(1e-2) #mm2 s-1
D2=Constant(4e-6) #mm2 s-1
sigma=Constant(5) #mm2 s-2
dt=0.5e-2
Dt = Constant(dt)
num_step=500
#Declare the form
F = dot((u-u_1)/Dt,v)*dx\
    +lamb*dot(dot(u, nabla_grad(u)), v)*dx\
    +D*(dot(grad(u[0]), grad(v[0]))+dot(grad(u[1]), grad(v[1])))*dx\
    -(alph*(p-pho_c)-a4*dot(u,u))*dot(u,v)*dx\
    +sigma*dot(grad(p),v)*dx\
    +(((p-p_1)/Dt+div(p*u))*q+D2*dot(grad(p), grad(q)))*dx\
    -D2*dot(grad(p),n)*q*ds
for i in range(0,num_step):
    solve(F==0,w,bcu)
    assign(w_1,w)
But now I want p (the density) to remain in the interval [0,1] to be physically relevant. And I don’t want to do post solving treatment like set the negatives values to zero … Because this adds mass to my system.
The solution I am exploring is around problem.set_bounds(wmin, wmax)
To do so I’ve just added some code before the loop over time:
J = derivative(F, w, TestFunction(W))
p_lower = Constant(0.0) # lower bound
p_upper = Constant(1.0) # upper bound
# handle the bounds
lower = Function(W)
upper = Function(W)
ninfty = Function(V); ninfty.vector()[:] = -np.infty
pinfty = Function(V); pinfty.vector()[:] =  np.infty
assign(lower, [ninfty, interpolate(p_lower, Vs)])
assign(upper, [pinfty, interpolate(p_upper, Vs)])
# set bounds and solve
problem = NonlinearVariationalProblem(F, w, bcu,J=J)
problem.set_bounds(lower, upper)
solver  = NonlinearVariationalSolver(problem)
solver.solve()
I get a big error, but since I never use NonlinearVariationalProblem I am not even sure what I am doing wrong.
If you have any hint to give me I would appreciate.
Kind regards,
Yoann
I would suggest creating your own solver. PETScSNESSolver allows you to provide the lower and upper bounds for your function.
So the way forward could be to create a subclass of NonlinearProblem, calculate the jacobian as you have above, and then use PETScSNESSolver to solve the problem like here, along with providing the bound vectors. Basically the array of dofs for your lower and upper functions (namely lower.vector() and upper.vector()). See also here
Edit: It does seem that you can do the same with NonlinearVariationalProblem, I can take a look at it sometime later today.
This should instead be
J = derivative(F, w, TrialFunction(W))
You can stack the bounds for your vectors directly, without having to use interpolate
lowerVec = np.hstack((-1.e9*np.ones(W.sub(0).dim()),np.zeros(W.sub(1).dim())))
upperVec = np.hstack((1.e9*np.ones(W.sub(0).dim()),np.ones(W.sub(1).dim())))
lower.vector()[:] = lowerVec
upper.vector()[:] = upperVec
I set the lower and upper bounds of u to some absurdly low and high values (didn’t want to use inf), but I assume you must be having an idea apriori as to what those must be.
A cleaned up version (assuming the variational formulation is correct):
tx=5
ty=tx
nbx=100
nby=nbx
TH = V1*V2
#Initial conditions
r=2
#Declare functions
w=Function(W)
w_1=Function(W)
w_t=TestFunction(W)
(u,p)=split(w)
(v,q)=split(w_t)
#Declare constants
dt=0.5e-2
Dt = Constant(dt)
num_step=500
#Declare the form
# handle the bounds
lower = Function(W)
upper = Function(W)
solver.parameters.update({"nonlinear_solver":"snes"})
for i in range(num_step):
    solver.solve()
    w_1.assign(w)
Thank you so much this works perfectly fine!
And indeed no need to use inf. I will try to read about the PETScSNESSolver and the parameters to use.
