How to set the rotation of the mesh in PyVista
Hello everyone, I’m trying to rotate my mesh imported from Gmsh in PyVista, but I haven’t succeeded. I want to display the geometry exactly as it was in Gmsh, but when I attempt to visualize it with PyVista, it appears with a different rotation. What can I do to set the rotation in PyVista?
Below, you’ll find my Gmsh script and the code used to visualize the mesh.
Thank you in advance.
// Gmsh project created on Tue Apr 16 21:06:14 2024
SetFactory("OpenCASCADE");
Point(1) = {0, 0, 0, 1.0};
Point(2) = {1, 0, 0, 1.0};
Point(3) = {0.5, 1, 0, 1.0};
Line(1) = {1, 2};
Line(2) = {2, 3};
Line(3) = {3, 1};
Curve Loop(1) = {3, 1, 2};
Plane Surface(1) = {1};
Extrude {0, 0, 3} {
  Surface{1};
Physical Surface("inlet", 10) = {1};
Physical Surface("outlet", 11) = {5};
Physical Surface("walls_right", 12) = {2};
Physical Surface("walls_left", 13) = {4};
Physical Surface("walls_bottom", 14) = {3};
Physical Volume(15) = {1};
My code is:
import pyvista
print(pyvista.global_theme.jupyter_backend)
tdim = msh.topology.dim
fdim = tdim - 1
from dolfinx import plot
pyvista.start_xvfb()
# Filter out ghosted cells
topology, cell_types, geometry = plot.vtk_mesh(msh, tdim)
p = pyvista.Plotter(window_size=[800, 800])
grid = pyvista.UnstructuredGrid(topology, cell_types, geometry)
p.add_mesh(grid, show_edges=True)
if pyvista.OFF_SCREEN:
    figure = p.screenshot("subdomains_structured.png")
p.show()
the mesh i get with Pyvista is:
The mesh i get with Gmsh :
See for instance Camera view · Issue #40 · pyvista/pyvista-support · GitHub. Once you learn the appropriate function or attribute names, you can search the pyvista repository for further help. Feel free to post the updated code for future reference by other users.
