My problem is:
find u = u(\boldsymbol{x}, t) obeying
where \Omega is unit square, T =2, and the diffusion coefficient
The sources
are derived from exact solution
The diffusion coefficient
in this demo.
I tried this code:
from dolfinx import mesh, fem
from dolfinx.fem.petsc import assemble_matrix, assemble_vector, apply_lifting, create_matrix, create_vector, set_bc
t = 0.0
T = 2.0
num_steps = 20
dt = (T - t) / num_steps
nx, ny = 5, 5
domain = mesh.create_unit_square(MPI.COMM_WORLD, nx, ny, mesh.CellType.triangle)
V = fem.functionspace(domain, ("Lagrange", 1))
t_c = fem.Constant(domain, t)
u_exact = 1 + x[0]**3 + 2 * x[1]**3 + t_c ** 2
u_D = fem.Function(V)
u_D.interpolate(fem.Expression(u_exact, V.element.interpolation_points()))
tdim = domain.topology.dim
fdim = tdim - 1
bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, fdim, boundary_facets))
u_n = fem.Function(V)
u_n = u_exact
kappa = ufl.sqrt(t_c)
f = fem.Function(V)
f = 2 * t_c - kappa * (6 * x[0] + 12 * x[1])
F = u * v * ufl.dx + dt * kappa * ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx - u_n * v * ufl.dx - dt * f * v * ufl.dx
a = fem.form(ufl.lhs(F))
L = fem.form(ufl.rhs(F))
A = create_matrix(a)
b = create_vector(L)
uh = fem.Function(V)
solver.setOperators(A)
errors_L2 = []
for n in range(num_steps):
t_c.value = t
A.zeroEntries()
assemble_matrix(A, a, bcs=[bc])
with b.localForm() as loc_b:
loc_b.set(0)
assemble_vector(b, L)
apply_lifting(b, [a], [[bc]])
set_bc(b, [bc])
solver.solve(b, uh.vector)
uh.x.scatter_forward()
u_n = uh
V_ex = fem.functionspace(domain, ("Lagrange", 2))
u_ex = fem.Function(V_ex)
u_ex = u_exact
error_L2 = domain.comm.allreduce(fem.assemble_scalar(fem.form((uh - u_ex)**2 * ufl.dx)), op=MPI.SUM)
errors_L2.append(error_L2)
L2_error = np.sqrt(np.trapz(errors_L2, dx=dt))
print(f"L2-error: {L2_error:.2e}")
However, the error is about e^{-1}. Then I tried another code:
t = 0
T = 2
num_steps = 20
dt = float((T - t) / num_steps)
nx, ny = 5, 5
class exact_solution():
def __init__(self, t):
self.t = t
def __call__(self, x):
return 1 + x[0] ** 3 + 2 * x[1] ** 3 + self.t ** 2
u_exact = exact_solution(t)
u_D.interpolate(u_exact)
fdim = tdim - 1
u_n.interpolate(u_exact)
kappa_expression = np.sqrt(t)
kappa = fem.Constant(domain, kappa_expression)
class source_term():
def __init__(self, t, kappa):
self.t = t
self.kappa = kappa
return 2 * self.t - self.kappa * (6 * x[0] + 12 * x[1])
f_expression = source_term(t, kappa_expression)
f = fem.Function(V)
f.interpolate(f_expression)
errors_L2 = []
kappa.value = kappa_expression
u_exact.t = t
f_expression.t = t
f_expression.kappa = kappa_expression
A.zeroEntries()
assemble_matrix(A, a, bcs = [bc])
loc_b.set(0)
set_bc(b, [bc])
u_n.x.array[:] = uh.x.array
u_ex.interpolate(u_exact)
L2_error = np.sqrt(np.trapz(errors_L2, dx = dt))
and the error is about 5e^{-2}.
I think I misunderstood the usage of SpatialCoordinate. Could anyone tell me how to correct the first code ?
Thanks very much!
