hello, anyone concerned,
I am a freshmen for FEniCSx.
Now I want to solve this problem: Find S= S(x,y,t) satisfying:
where \kappa(t) is time dependent, e.g. \kappa(t) = t.
I compute the source f = \exp(-x - y) - 2t^2 \exp(-x - y) - 2t^3 \exp(-x - y) from the exact solution S_{ex} = t \exp(-x - y). I first tried Dirichlet boundary condition in my code, and also compute the error between FEM solution and exact solution.
Here is my code:
t = 0.0
T = 1.0
num_steps = 50
dt = T / num_steps
nx, ny = 50, 50
domain = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([0, 0]), np.array([1, 1])], [nx, ny], mesh.CellType.triangle)
V = fem.FunctionSpace(domain, ("Lagrange", 1))
def initial_condition(x):
return np.exp(-t * (x[0]**2 + x[1]**2))
S_n = fem.Function(V)
S_n.name = "S_n"
S_n.interpolate(initial_condition)
with io.XDMFFile(domain.comm, "diffusion.xdmf", "w") as xdmf:
xdmf.write_mesh(domain)
Sh = fem.Function(V)
Sh.name = "Sh"
Sh.interpolate(initial_condition)
xdmf.write_function(Sh, t)
S = ufl.TrialFunction(V)
t_c = fem.Constant(domain, t)
S_exact = t_c * ufl.exp(-x[0] - x[1])
def boundary_D(x):
return np.logical_or(np.isclose(x[0], 0), np.isclose(x[0], 1))
dofs_D = fem.locate_dofs_geometrical(V, boundary_D)
f = ufl.exp(-x[0] - x[1]) - 2 * (t_c**2) * ufl.exp(-x[0] - x[1]) - 2*(t_c**3) * ufl.exp(-x[0] - x[1])
a = S * v * ufl.dx + t_c * dt * ufl.dot(ufl.grad(S), ufl.grad(v)) * ufl.dx
L = (S_n + dt * f) * v * ufl.dx
S_exact_func = fem.Function(V)
S_exact_func.name = "S_exact"
errors = []
for i in range(num_steps):
t_c.value = t
S_bc = fem.Function(V)
S_bc.interpolate(lambda x: t * np.exp(-x[0] - x[1]))
bc = fem.dirichletbc(S_bc, dofs_D)
Sh = problem.solve()
S_exact_func.interpolate(lambda x: t * np.exp(-x[0] - x[1]))
error_L2 = fem.assemble_scalar(fem.form((Sh - S_exact_func)**2 * ufl.dx))**0.5
errors.append(error_L2)
with io.XDMFFile(domain.comm, "diffusion.xdmf", "a") as xdmf:
print("error_L2:", errors)
However, the error seems too big. I trust there is something wrong, but I cannot discover it. Can anyone help me? Thanks very mush!
