How to use Adaptive Nonlinear Variational Solver with mixed nonlinear problem?
I want to use the AdaptiveNonlinearVariationalSolver to adapt my mesh automatically, but my problem is nonlinear and in a mixed space. I can solve my problem generally with solve(), but now that I want to put it in the correct format for AdaptiveNonlinearVariationalSolver, it doesn’t work. Currently the error is: ValueError: too many values to unpack (expected 2). I gathered that it is because I define it as a Nonlinear problem (instead of MixedNonlinear), and that’s not correct. However, I can’t figure out the right way to fix it.
This is my MWE:
mesh = RectangleMesh(Point(0, 0), Point(0.2, 1), 8, 8)
# Define Taylor--Hood function space W
V = VectorElement("CG", triangle, 2)
Q = FiniteElement("CG", triangle, 1)
S = FiniteElement("CG", triangle, 1)
W = FunctionSpace(mesh, MixedElement([V, Q, S]))
# Define Function and TestFunction(s)
w = TrialFunction(W)
(u, p, T) = split(w)
(v, q, s1) = split(TestFunction(W))
# Define the parameters and bcs
mu = Constant(1.0)
Qc2 = Constant(1.0) # this will be a function of x[0]
Ta = Constant(1.0) # this will be a function of x[1]
Pe = Constant(27.0)
Bi = Constant(11.6)
u_in = Constant(-2.0)
u_c = Constant(-1.0)
inflow = 'near(x[1], 1.0) && x[0]<=0.1'
wall = 'near(x[0], 0.2)'
centre = 'near(x[0], 0.0)'
outflow = 'near(x[1], 0.0)'
bcu_inflow = DirichletBC(W.sub(0), (0.0, u_in), inflow)
bcu_wall = DirichletBC(W.sub(0), (0.0, u_c), wall)
bcu_outflow = DirichletBC(W.sub(0), (0.0, u_c), outflow)
bcu_symmetry = DirichletBC(W.sub(0).sub(0), Constant(0.0), centre)
bcT_inflow = DirichletBC(W.sub(2), 0.0, inflow)
bcs = [bcu_inflow, bcu_wall, bcu_outflow, bcu_symmetry, bcT_inflow]
x = SpatialCoordinate(mesh)
def epsilon(v):
    return sym(as_tensor([[v[0].dx(0), v[0].dx(1), 0],
                          [v[1].dx(0), v[1].dx(1), 0],
                          [0, 0, 0]]))
# stress tensor
def sigma(v, p):
    return 2*mu*epsilon(v)-Id(p)
def Id(p):
    return as_tensor([[p, 0, 0],
                      [0, p, 0],
                     [0, 0, p]])
def cond(v):
    return sym(as_tensor([[v[0].dx(0), v[0].dx(1)],
                          [v[1].dx(0), v[1].dx(1)]]))
def sigmabc(v, p):
    return 2*mu*cond(v) - p*Identity(2)
facet_f = MeshFunction("size_t", mesh, mesh.topology().dim() - 1) # FACET function
CompiledSubDomain('near(x[1], 1.0) && x[0]<=0.1').mark(facet_f, 0)
CompiledSubDomain('near(x[1], 1.0) && x[0]>=0.1').mark(facet_f, 1)
CompiledSubDomain('near(x[0], 0.2)').mark(facet_f, 2)  # wall
CompiledSubDomain('near(x[1], 0.0)').mark(facet_f, 3)  # outflow
CompiledSubDomain('near(x[0], 0.0)').mark(facet_f, 4)
CompiledSubDomain('near(x[1], 1.0) && x[0]>0.1 && x[0]<0.2').mark(facet_f, 5)
# Create the measure
ds = Measure("ds", domain=mesh, subdomain_data=facet_f)
# Define the variational form
f = Constant((0, -1))
a = (inner(sigma(u, p), epsilon(v)) - div(u) * q + (dot(u, grad(T)) * s1 + (
       1 / Pe) * inner(grad(s1), grad(T)))) * dx() - (1 / Pe) * (-Bi * s1 * T * ds(2))
L = (- dot(f, v) - (1/Pe) * Qc2*s1) * dx() - (1/Pe) * (s1 * Bi * Ta * ds(2))
F = a + L # For nonlinear problem, write F = 0
w = Function(W)
# Define goal functional (quantity of interest)
M = inner(w[0], w[0])*dx()
# Define error tolerance
tol = 1.e-6
# Solve equation a = L with respect to u and the given boundary
# conditions, such that the estimated error (measured in M) is less
# than tol
problem = NonlinearVariationalProblem(F, w, bcs) # The problem is here
#problem = MixedNonlinearVariationalProblem(F, w, bcs) # This doesn't work
solver = AdaptiveNonlinearVariationalSolver(problem, M)
solver.parameters["error_control"]["dual_variational_solver"]["linear_solver"] = "umfpack"
#parameters["refinement_algorithm"] = "plaza_with_parent_facets"
solver.solve(tol)
solver.summary()
# Plot solutions
(u0, p0, T0) = w.root_node().split()
(u1, p1, T1) = w.leaf_node().split()
R = w.leaf_node().function_space()
plot(R.mesh())
I think the error is because of the term (dot(u, grad(T)) * s1 , but I don’t know how else to write the variational formulation. Any help would be greatly appreciated.
NOTE: I am aware that my problem for u and p is decoupled from my problem for T, so I could just solve for u and p, and then use that solution to solve for T separately. However, I am working my way up to the fully coupled problem, which is why I have written in that way.
You can resolve this by replacing
with
w = Function(W)
and then removing the line w = Function(W) that appears later in the script, above the definition of the goal functional. (You also need to uncomment
for the adaptivity to work.)
Thank you so much, that does the trick.
For anyone else having these difficulties, I also neglected to write the Jacobian. In addition to the modifications suggested by @kamensky , you also need to add
dw = TrialFunction(W)
J = derivative(F, w, dw)
and define the problem with
problem = NonlinearVariationalProblem(F, w, bcs, J)
Works like a charm.
