Solving adaptive nonlinear equation in Vector Space
Hello all,
I am trying to use adaptive meshing to solve a nonlinear equation. In my code, I am trying to minimize elastic energy (such as this example on documentation: https://fenicsproject.org/docs/dolfin/2019.1.0/python/demos/hyperelasticity/demo_hyperelasticity.py.html).
My problem is that when I use “solve(F == 0, u, bcs=bc, tol=tol, M=M)” to solve my problem, it gives me the following error:
File “/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/solving.py”, line 228, in solve
_solve_varproblem_adaptive(*args, **kwargs)
File “/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/solving.py”, line 321, in _solve_varproblem_adaptive
eq, u, bcs, J, tol, M, form_compiler_parameters,
ValueError: too many values to unpack (expected 8)
Please also note that since I am trying to solve a VectorFunctionSpace parameter, I have defined goal function M as below:
M = y[1] * dx(0)
where y is the deformation vector.
For solving nonlinear equation adaptively, I am using section 4 of the following document:
https://fenicsproject.org/docs/dolfin/2017.2.0/python/programmers-reference/fem/solving/solve.html
Any help is much appreciated!
Please supply a minimal working code example. Note that your latter link references the FEniCS 2017.2.0 API, which is now outdated.
Thank you very much for your reply.
Here is my code:
mesh = RectangleMesh(Point(-1,-1),Point(1,1), 10, 10)
dy = TrialFunction(V)
v  = TestFunction(V)             # Test function
y  = Function(V)
u  = Function(V)
# Define Dirichlet boundary
F11=1.0
F12=0.0+0.001
F21=0.0
F22=1.0-0.001
y_BC = Expression(("F11*x[0]+F12*x[1]", "F21*x[0]+F22*x[1]"),F11=F11,F12=F12,F21=F21,F22=F22,degree=2)
def x0_boundary(x, on_boundary):
    return on_boundary
bc = DirichletBC(V, y_BC, x0_boundary)
y=project(y_BC,V)
y_reference = Expression(("x[0]","x[1]"),degree=3)
# Elasticity model:
E, nu = 10.0, 0.3
mu, lmbda = Constant(E/(2*(1 + nu))), Constant(E*nu/((1 + nu)*(1 - 2*nu)))
def W(y):
    F = grad(y)
    J  = det(F)
    C = F.T*F
    Ic = tr(C)
    return (mu/2)*(Ic - 3) - mu*ln(J) + (lmbda/2)*(ln(J))**2
# Solving adaptively
M = inner(y,y)*dx()
tol = 1.e-3
W1 = W(y) * dx
dW1 = derivative(W1, y, v) # first variation (derivative at u in the direction of v)
ddW1 = derivative(dW1, y, dy) # Jacobian of dPi
solve(dW1 == 0, y, bcs=bc, tol=tol, M=M)
Unfortunately, I cannot reproduce your error using Docker:
 docker run -ti -v $(pwd):/home/fenics/shared -w /home/fenics/shared/ --rm quay.io/fenicsproject/stable:latest
You need to supply more information about how you have installed dolfin, and which version you are using for me to be of any more help.
Thanks for the follow-up.
I have installed Fenics using virtual Ubuntu on Windows 10, and this the version of dolfin I have installed:
2019.2.0.dev0
I can confirm that there is an issue with 2019.2.0.dev0. I have submitted a fix for it at BitBucket. So you could either add this to your source code, or go back on release to 2019.1.0, as the code works there.
I really appreciate your help.
Can you please tell me how I should add this fix to my source code?
Simply open: /usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/solving.py and change line 321/322 as indicated in my Pull request.
Thank you so much! The problem of my code is now resolved!
Hello all,
I am trying to use the “SNES” library to solve my nonlinear variational problem adaptively. However, I am getting the following error:
RuntimeError: Parameter nonlinear_variational_solver not found in Parameters object
My minimal code is as below:
mesh = RectangleMesh(Point(-1,-1),Point(1,1), 40, 40)
y  = Function(V)
u  = Function(V)
F11=1.0
F12=0.0+0.001
F21=0.0
F22=1.0-0.001
    return on_boundary
y=project(y_BC,V)
# Elasticity model:
E, nu = 10.0, 0.3
def W(y):
    F = grad(y)
    J  = det(F)
    C = F.T*F
    Ic = tr(C)
M = inner(y,y)*dx()
tol = 1.e-8
W1 = W(y) * dx
problem=NonlinearVariationalProblem(dW1,y,bcs=bc,J=ddW1)
solver = AdaptiveNonlinearVariationalSolver(problem, M)
solver.parameters['nonlinear_variational_solver'] = 'snes'
solver.solve(tol)
As in my previous problem, I am using Fenics installed on virtual Ubuntu on Windows 10, and the version of dolfin is 2019.2.0.dev0
I would be so thankful if you could help with fixing this problem.
Try:
solver.parameters["nonlinear_variational_solver"]["nonlinear_solver"]="snes"
A neat thing you can do is to add an embed-session:
from IPython import embed
embed()
and check what the variables of solver.parameters are, by
calling solver.parameters.keys(), solver.parameters["nonlinear_variational_solver"].keys() and so on and so forth to see what they contain
I wanted to ask a follow-up question on using SNES conjugate gradient solver. Following your suggestion on adding an embed-session, I get these keys for solver.parameters["snes_solver"].keys() :
['absolute_tolerance',
 'error_on_nonconvergence',
 'krylov_solver',
 'line_search',
 'linear_solver',
 'lu_solver',
 'maximum_iterations',
 'maximum_residual_evaluations',
 'method',
 'preconditioner',
 'relative_tolerance',
 'report',
 'sign',
 'solution_tolerance']
For my problem, SNES solver converges for the lower number of meshes, however, it diverges for the higher number of meshes because of divergence reason DIVERGED_DTOL
So, I want to increase the divergence tolerance, based on this link ( SNESSetDivergenceTolerance ), but there is no key parameter for setting divergence tolerance based on the embed-session. Can you please help me with setting this parameter?
Also, for using the conjugate gradient method, what is the advantage of using fmin_cg ( scipy.optimize.fmin_cg — SciPy v1.6.1 Reference Guide ) over SNES solver?
Thank you very much!
