Importing domain/boundary markers in fenicsx
Dear all,
I have created a mesh with different physical groups in gmsh, converted in to xdmf and loaded it in dolfinx (see code below).
However, I wasn’t able to get the physical groups in dolfinx. I’ve found several tutorials on this topic, but all seem outdated?
Version 1. As suggested here (resp. in this code, line 143), I tried using read_information_int, but this method seems to have been removed.
Version 2. In this tutorial, it is suggested to use the find-method on MeshTags, which also seem to have been removed.
Version 3. In this post using boundary_markers = dolfinx.mesh.MeshFunction("size_t", mesh, mesh.topology().dim() - 1) is suggested, but MeshFunctions seem to also have been removed. Which, simultaneously, makes msh2xdmf obsolete, I think?
So, what to do? How can I access the physical groups in the current dolfinx release (0.4)?
Thank you in advance.
Here’s the code:
# load_mesh.py
with XDMFFile(MPI.COMM_WORLD, "mesh_vol.xdmf", "r") as xdmf:
    ct = xdmf.read_meshtags(mesh, name="Grid")
    ## Version 1.
    # tag_info = xdmf.read_information_int()
mesh.topology.create_connectivity(mesh.topology.dim-1, 0)
with XDMFFile(MPI.COMM_WORLD, "mesh_surf.xdmf", "r") as xdmf:
    ft = xdmf.read_meshtags(mesh, name="Grid")
## Version 2.
# ft.find
## Version 3
# boundary_markers = dolfinx.mesh.cpp.MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
# convert.py
### Convert from msh to XDMF
    out_mesh = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
    return out_mesh
mesh = meshio.read("mesh.msh")
mesh_surf = create_mesh(mesh, "triangle")
meshio.write("mesh_surf.xdmf", mesh_surf)
mesh_vol = create_mesh(mesh, "tetra")
meshio.write("mesh_vol.xdmf", mesh_vol)
//+ mesh.geo
SetFactory("OpenCASCADE");
Box(1) = {0, 0, 0, 1, 1, 1};
Physical Surface("s1") = {6};
Physical Surface("s2") = {1};
Physical Surface("s3") = {5};
Physical Surface("s4") = {2};
Physical Surface("s5") = {4};
Physical Surface("s6") = {3};
Physical Volume("dom") = {1};
Since you are working with v0.4.0, while the tutorial is using v0.4.2.0, I would suggest you have a look at: https://github.com/jorgensd/dolfinx-tutorial/blob/v0.4.0/chapter3/subdomains.ipynb
In particular: bottom_cells = ct.indices[ct.values==bottom_marker]
Thanks a bunch, mate. For you answer as well as all the tutorials.
I shouldn’t have dropped the minor version, apparently I’m using 0.4.1 though, at least that’s what condaforge is saying. Your solution still works.
If I would also save the labels into the xdmf-file, would there be a way to read them into fenicsx and access them directly via strings? Or would I still need to use the integer-indices? That is, there is no equivalent to Version 1 anymore, right?
It has been a very long time (if ever) that there has been support for labelling with strings. The reason for this is that a string can have arbitrary length, and therefore be incredibly inefficient to save/load.
The solution in version one was removed a long time ago, as MeshFunctions are inefficient for storing information about any sub-entity (vertices, edges, facets), as one almost never need to tag all of them.
Sounds reasonable. Thanks again.
