Dear all,
As far as I know, to use PointSource, you need to use assemble( ) and apply( ). I have so many point sources in a nonlinear problem, and it is quite slow if I just simply add up the expressions which I write either in “class” or “Expression”.
From the post here, it seems that it is possible to use in PointSource in nonlinear problem as well, but I don’t know how it works.
Can anyone give a simple example for this? Thanks in advance.
Best regards,
Alice
