How to correctly apply a point source in nonlinear problem in fenicsx
I am simulating a problem where flow injected through a point source on a horizontal plane. The axisymmetric dimensionless equation is
\begin{aligned} xu_t+\left(x\partial_x+1\right)\Gamma&=\frac{\delta(x)}{2\pi } \quad\text{in } \Omega=[0, 1]\\ u(0,x)&=0\\ u_x(t,0)&=0,\quad u(t,1)=0 \end{aligned}
where the flux \Gamma=-u^3u_x and the weak form is
\int_0^1 \left(vxu_t-x\Gamma v_x\right)\mathrm{d} x=\frac{v(0)}{2\pi}
I checked this post on point source, but that is a linear problem and the v(0)/2\pi term is added to the RHS b. Is there a way to add a point source for a nonlinear problem? The following MWE is for a simplified problem
\begin{aligned} xu_t+\left(x\partial_x+1\right)\Gamma&=0\quad\text{in } \Omega=[0, 1]\\ u(0,x)&=\frac{1}{1+100x^2}\\ u_x(t,0)&=0,\quad u(t,1)=0 \end{aligned}
Time-dependent 1D lubrication equation [@garel2014analogue]
u_t+Γ_x+Γ/x=0, Γ_x=-u^3 u_x
u_x(0,t)=0, u(R,t)=0, u(0,t)=exp(-100 x^2)
The weak formulation is
∫(vxu_t-xΓv_x)dx = 0
import matplotlib.pylab as plt
from dolfinx import mesh
from dolfinx.fem import (
    Constant,
    Function,
    dirichletbc,
    form,
    functionspace,
    locate_dofs_geometrical,
from ufl import TestFunction, derivative, dx, grad, inner
# Define temporal parameters
T = 1  # final time
num_steps = 100  # time steps
dt = T / num_steps
nx = 200  # number of intervals in space
rank = MPI.COMM_WORLD.Get_rank()
domain = mesh.create_interval(MPI.COMM_WORLD, nx, [0, 1])
V = functionspace(domain, ("Lagrange", 1))
# Create initial condition
initial_condition = lambda x: 1 / (1 + 100 * x[0] ** 2)
# Define solution variable, and interpolate initial solution for visualization in Paraview
u_n = Function(V)
u.interpolate(initial_condition)
u.x.scatter_forward()
u_n.x.array[:] = u.x.array
# Define boundary conditions
bc_right = dirichletbc(
    Constant(domain, PETSc.ScalarType(0)),
    locate_dofs_geometrical(V, lambda x: np.isclose(x[0], 1)),
    V,
bcs = [bc_right]
# Time-dependent output
# xdmf = XDMFFile(domain.comm, "result/eqn02_diffusion.xdmf", "w")
# xdmf.write_mesh(domain)
# xdmf.write_function(uh, t)
F = inner(u - u_n, v) * dx + dt * u**3 * inner(grad(u), grad(v)) * dx
# Compute the Jacobian (derivative of F with respect to u)
J = derivative(F, u)
problem = NonlinearProblem(F, u, bcs=bcs, J=J)
solver.rtol = 1e-8
ksp = solver.krylov_solver
opts = PETSc.Options()
ksp.setFromOptions()
x = V.tabulate_dof_coordinates()[:, 0]
# Updating the solution and right hand side per time step
t = 0
for i in range(num_steps):
    # Solve linear problem
    n, converged = solver.solve(u)
    if rank == 0:
    # Write solution to file
    if i % 10 == 0:
        plt.plot(x, u.x.array)
# xdmf.close()
Have you solved this problem? Because I have encountered the same problem. I’m trying to rewrite a function class that combines nonlinearity and point source, but it’s to difficult for me to do it at present.
