I have written a minimal working example with a simpler domain, which should produce a solution, but the newton solver do not converge. If you have time, please take a look:
import dolfinx.fem.petsc
import pyvista
from dolfinx import fem
import dolfinx.plot as dplt
from dolfinx.fem import (Constant, VectorFunctionSpace, Function, FunctionSpace, assemble_scalar,
dirichletbc, form, locate_dofs_topological,extract_function_spaces)
from dolfinx.fem.petsc import LinearProblem, NonlinearProblem
from dolfinx.mesh import create_unit_square, locate_entities, meshtags, create_rectangle, CellType, Mesh
from ufl import (VectorElement,FiniteElement,FacetNormal, Measure, SpatialCoordinate, TestFunction, TrialFunction, TrialFunctions, TestFunctions,
div, dot, dx, grad, inner, lhs, rhs, MixedElement, nabla_grad, split)
################# options #####################
save_stokes_results=True
reee=100.0 #reynolds
c=1.0 # inlet max velocity
a=0.0
b=1.0
xm=(a+b)*0.5
def calc_parabola(x1, y1, x2, y2, x3, y3):
denom = (x1-x2) * (x1-x3) * (x2-x3)
A = (x3 * (y2-y1) + x2 * (y1-y3) + x1 * (y3-y2)) / denom
B = (x3*x3 * (y1-y2) + x2*x2 * (y3-y1) + x1*x1 * (y2-y3)) / denom
C = (x2 * x3 * (x2-x3) * y1+x3 * x1 * (x3-x1) * y2+x1 * x2 * (x1-x2) * y3) / denom
return A,B,C
alpha,beta,om=calc_parabola(a,0,b,0,xm,c)
def vel_in(x):
val = alpha*x[0]*x[0] + beta*x[0] + om
return np.stack((np.zeros(x.shape[1]), -val*np.ones(x.shape[1])))
mesh = create_rectangle(comm=MPI.COMM_WORLD,
points=((0.0, 0.0), (1.0, 5.0)), n=(50, 200),
cell_type=CellType.triangle)
ds = Measure("ds", domain=mesh)
fdim = mesh.topology.dim - 1
P2 = VectorElement("Lagrange", mesh.ufl_cell(), 2)
TH = P2*P1
W = FunctionSpace(mesh, TH)
V=W.sub(0).collapse()[0]
Q=W.sub(1).collapse()[0]
# parabolic inlet
u_in = Function(V)
u_in.interpolate(vel_in)
where = locate_entities(mesh, fdim,marker=lambda t: np.isclose(t[1], 5.0))
dofs = locate_dofs_topological(V, fdim, where)
bc0 = dirichletbc(u_in, dofs)
# noslip
noslip = Constant(mesh,(0.0,0.0))
where = locate_entities(mesh, fdim,marker=lambda t: np.isclose(t[0], 0.0))
bc1 = dirichletbc(noslip, dofs, V)
# noslip
where = locate_entities(mesh, fdim,marker=lambda t: np.isclose(t[0], 1.0))
bc2 = dirichletbc(noslip, dofs, V)
# pressure=0 out
pres=Constant(mesh,(0.0))
where = locate_entities(mesh, fdim,marker=lambda t: np.isclose(t[1], 0.0))
dofs = locate_dofs_topological(Q, fdim, where)
bc3 = dirichletbc(pres, dofs, Q)
bcs = [bc0,bc1,bc2,bc3]
(u, p) = TrialFunction(V), TrialFunction(Q)
(v, q) = TestFunction(V), TestFunction(Q)
f = Constant(mesh, (ScalarType(0), ScalarType(0)))
Re = Constant(mesh,ScalarType( reee ))
delta=1
a = form([[(1/Re)*inner(grad(u), grad(v)) * dx, -inner(p, div(v)) * dx],
[-inner(div(u), q) * dx, -delta*inner(grad(p),grad(q)) * dx ]])
L = form([inner(f, v) * dx, delta*inner(f, grad(q)) * dx])
a_p11 = form(inner(p, q) * dx)
a_p = [[a[0][0], None],
[None, a_p11]]
# nested
A = fem.petsc.assemble_matrix_nest(a, bcs=bcs)
P11 = fem.petsc.assemble_matrix(a_p11, [])
P = PETSc.Mat().createNest([[A.getNestSubMatrix(0, 0), None], [None, P11]])
P.assemble()
b = fem.petsc.assemble_vector_nest(L)
# Modify ('lift') the RHS for Dirichlet boundary conditions
fem.petsc.apply_lifting_nest(b, a, bcs=bcs)
# Sum contributions from ghost entries on the owner
for b_sub in b.getNestSubVecs():
b_sub.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
# Set Dirichlet boundary condition values in the RHS
bcs0 = fem.bcs_by_block(extract_function_spaces(L), bcs)
fem.petsc.set_bc_nest(b, bcs0)
ksp = PETSc.KSP().create(mesh.comm)
ksp.setOperators(A, P)
ksp.setType("minres")
ksp.setTolerances(rtol=1e-9)
ksp.getPC().setType("fieldsplit")
ksp.getPC().setFieldSplitType(PETSc.PC.CompositeType.ADDITIVE)
# Define the matrix blocks in the preconditioner with the velocity and
# pressure matrix index sets
nested_IS = P.getNestISs()
ksp.getPC().setFieldSplitIS(
("u", nested_IS[0][0]),
("p", nested_IS[0][1]))
# Set the preconditioners for each block
ksp_u, ksp_p = ksp.getPC().getFieldSplitSubKSP()
ksp_u.setType("preonly")
ksp_u.getPC().setType("gamg")
ksp_p.setType("preonly")
ksp_p.getPC().setType("jacobi")
# Monitor the convergence of the KSP
ksp.setFromOptions()
u, p = Function(V), Function(Q)
x = PETSc.Vec().createNest([_cpp.la.petsc.create_vector_wrap(u.x), _cpp.la.petsc.create_vector_wrap(p.x)])
ksp.solve(b, x)
norm_u_0 = u.x.norm()
norm_p_0 = p.x.norm()
if MPI.COMM_WORLD.rank == 0:
print("(A) Norm of velocity coefficient vector (nested, iterative): {}".format(norm_u_0))
print("(A) Norm of pressure coefficient vector (nested, iterative): {}".format(norm_p_0))
## Write the solution to file
if save_stokes_results:
with XDMFFile(MPI.COMM_WORLD, "out_stokes/velocity.xdmf", "w") as ufile_xdmf:
u.x.scatter_forward()
ufile_xdmf.write_mesh(mesh)
ufile_xdmf.write_function(u)
with XDMFFile(MPI.COMM_WORLD, "out_stokes/pressure.xdmf", "w") as pfile_xdmf:
p.x.scatter_forward()
pfile_xdmf.write_mesh(mesh)
pfile_xdmf.write_function(p)
########### non linear problem ##########
# get previous solution
u_initial=u
p_initial=p
up = Function(W)
u_size=len(u_initial.x.array)
p_size=len(p_initial.x.array)
# use previous as initial condition
up.x.array[:u_size]=u_initial.x.array
up.x.array[u_size:(p_size+u_size)]=p_initial.x.array
up.x.scatter_forward()
uu, pp = split(up)
v, q = TestFunctions(W)
# define the new problem
F= (1/Re)*inner(grad(uu), grad(v)) * dx \
-inner(pp, div(v)) * dx -inner(div(uu), q) * dx \
-inner(dot(uu, nabla_grad(uu)),v) * dx \
-delta*inner(grad(pp),grad(q)) * dx
# Create nonlinear problem and Newton solver
problem = NonlinearProblem(F, up, bcs)
solver.rtol = 1e-5
solver.report = True
solver.max_it = 1000
# helper function to print norm
def normal2(arr):
val=0
for a in arr:
val+=a**2
return np.sqrt(val)
r = solver.solve(up)
print(f"Num iterations: {r[0]}")
curr_u_array=up.x.array[:u_size]
curr_p_array=up.x.array[u_size:(u_size+p_size)]
norm_u_0 = normal2(curr_u_array)
norm_p_0 = normal2(curr_p_array)
# check if norm of solution is comparable to the one of the stokes problem
print("(A) Norm2 of velocity coefficient vector (nested, iterative): {}".format(norm_u_0))
print("(A) Norm2 of pressure coefficient vector (nested, iterative): {}".format(norm_p_0))
