I’m trying to solve an 2-d evolutionary non-linear PDE which has a term u^\alpha v with \alpha <1, where u,v are both variables and are non-negative in my assumption. Since it’s a non-linear term, i choose to use newton solver but it does not converge from the beginning.
Here is the information provided by using “dolfinx.log.set_log_level(log.LogLevel.INFO)”:
2024-02-18 17:02:13.172 (1923.480s) [main ] graphbuild.cpp:395 INFO| Build local part of mesh dual graph
2024-02-18 17:02:13.173 (1923.480s) [main ] ordering.cpp:203 INFO| GPS pseudo-diameter:(30) 113-14
2024-02-18 17:02:13.173 (1923.480s) [main ] Topology.cpp:901 INFO| Create topology
2024-02-18 17:02:13.173 (1923.480s) [main ] MPI.cpp:166 INFO| Computing communication graph edges (using NBX algorithm). Number of input edges: 1
2024-02-18 17:02:13.173 (1923.480s) [main ] MPI.cpp:237 INFO| Finished graph edge discovery using NBX algorithm. Number of discovered edges 1
2024-02-18 17:02:13.173 (1923.480s) [main ] partition.cpp:233 INFO| Compute ghost indices
2024-02-18 17:02:13.173 (1923.480s) [main ] MPI.cpp:99 INFO| Computing communication graph edges (using PCX algorithm). Number of input edges: 0
2024-02-18 17:02:13.173 (1923.480s) [main ] MPI.cpp:156 INFO| Finished graph edge discovery using PCX algorithm. Number of discovered edges 0
2024-02-18 17:02:13.173 (1923.480s) [main ] MPI.cpp:166 INFO| Computing communication graph edges (using NBX algorithm). Number of input edges: 0
2024-02-18 17:02:13.173 (1923.480s) [main ] MPI.cpp:237 INFO| Finished graph edge discovery using NBX algorithm. Number of discovered edges 0
2024-02-18 17:02:13.173 (1923.480s) [main ] MPI.h:379 INFO| Number of neighbourhood source ranks in distribute_to_postoffice: 0
2024-02-18 17:02:13.173 (1923.480s) [main ] MPI.h:519 INFO| Neighbourhood destination ranks from post office in distribute_data (rank, num dests, num dests/mpi_size): 0, 0, 0
2024-02-18 17:02:13.174 (1923.481s) [main ] MPI.cpp:166 INFO| Computing communication graph edges (using NBX algorithm). Number of input edges: 0
2024-02-18 17:02:13.174 (1923.482s) [main ] MPI.cpp:237 INFO| Finished graph edge discovery using NBX algorithm. Number of discovered edges 0
2024-02-18 17:02:13.174 (1923.482s) [main ] MPI.cpp:166 INFO| Computing communication graph edges (using NBX algorithm). Number of input edges: 0
2024-02-18 17:02:13.175 (1923.482s) [main ] MPI.cpp:237 INFO| Finished graph edge discovery using NBX algorithm. Number of discovered edges 0
2024-02-18 17:02:13.657 (1923.964s) [main ] SparsityPattern.cpp:384 INFO| Column ghost size increased from 0 to 0
2024-02-18 17:02:13.659 (1923.966s) [main ] petsc.cpp:698 INFO| PETSc Krylov solver starting to solve system.
2024-02-18 17:02:13.660 (1923.967s) [main ] petsc.cpp:698 INFO| PETSc Krylov solver starting to solve system.
2024-02-18 17:02:13.660 (1923.967s) [main ] NewtonSolver.cpp:36 INFO| Newton iteration 2: r (abs) = inf (tol = 1e-10) r (rel) = -nan(tol = 1e-06)
2024-02-18 17:02:13.660 (1923.967s) [main ] NewtonSolver.cpp:36 INFO| Newton iteration 3: r (abs) = inf (tol = 1e-10) r (rel) = -nan(tol = 1e-06)
2024-02-18 17:02:13.660 (1923.968s) [main ] petsc.cpp:698 INFO| PETSc Krylov solver starting to solve system.
2024-02-18 17:02:13.661 (1923.968s) [main ] NewtonSolver.cpp:36 INFO| Newton iteration 4: r (abs) = inf (tol = 1e-10) r (rel) = -nan(tol = 1e-06)
2024-02-18 17:02:13.661 (1923.968s) [main ] petsc.cpp:698 INFO| PETSc Krylov solver starting to solve system.
2024-02-18 17:02:13.661 (1923.968s) [main ] NewtonSolver.cpp:36 INFO| Newton iteration 5: r (abs) = inf (tol = 1e-10) r (rel) = -nan(tol = 1e-06)
2024-02-18 17:02:13.661 (1923.968s) [main ] NewtonSolver.cpp:36 INFO| Newton iteration 6: r (abs) = inf (tol = 1e-10) r (rel) = -nan(tol = 1e-06)
2024-02-18 17:02:13.662 (1923.969s) [main ] petsc.cpp:698 INFO| PETSc Krylov solver starting to solve system.
2024-02-18 17:02:13.662 (1923.969s) [main ] NewtonSolver.cpp:36 INFO| Newton iteration 7: r (abs) = inf (tol = 1e-10) r (rel) = -nan(tol = 1e-06)
And the following information is the same as above, r(rel) is -nan from the first step.
Then my main code:
> from mpi4py import MPI
> from petsc4py import PETSc
> import numpy as np
> import ufl
> from basix.ufl import element, mixed_element
> from dolfinx import default_real_type, log, plot
> from dolfinx.fem import Function, functionspace
> from dolfinx.fem.petsc import NonlinearProblem
> from dolfinx.io import XDMFFile
> from dolfinx.nls.petsc import NewtonSolver
> from ufl import dx, grad, inner, dot
> import dolfinx.mesh
> import dolfinx
> import gmsh
> dim = 2
> n_default = 8
> T_default = 1
> dt = 0.001
> num_steps_default = int(T_default / dt)
> u0 = 1
> v0 = 0.1
> w0 = 1
> lamda = 1.5
> alpha = 0.5
> chi = 100
> msh = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, n_default, n_default, dolfinx.mesh.CellType.triangle)
> P1 = element("Lagrange", msh.basix_cell(), 1)
> ME = dolfinx.fem.functionspace(msh, mixed_element([P1, P1, P1]))
> v_1, v_2, v_3 = ufl.TestFunctions(ME)
> U = Function(ME)
> U_0 = Function(ME)
> u, v, w = ufl.split(U)
> u_last, v_last, w_last = ufl.split(U_0)
> def ic1(u_0, dim, uu, vv, ww):
> if dim == 2:
> u_0.sub(0).interpolate(lambda x: 1 + uu * np.exp(-1 * ((x[0] - 0.5) ** 2 + (x[1] - 0.5) ** 2)))
> u_0.sub(1).interpolate(lambda x: 1 + vv * np.exp(-1 * ((x[0] - 0.5) ** 2 + (x[1] - 0.5) ** 2)))
> u_0.sub(2).interpolate(lambda x: 1 + ww*np.exp(-1 * ((x[0]-0.5) ** 2 + (x[1]-0.5) ** 2)))
> u_0.x.scatter_forward()
> def calculate_uh(alpha, u0, v0, w0, chi, lamda):
> F1 = ((u - u_last) / dt) * v_1 * dx + dot(grad(u), grad(v_1)) * dx - chi * dot(u * grad(v), grad(
> v_1)) * dx - lamda * v_1 * dx + u * v_1 * dx + (u ** alpha) * w * v_1 * dx
> F2 = ((v - v_last) / dt) * v_2 * dx + dot(grad(v), grad(v_2)) * dx + v * v_2 * dx - (u ** alpha) * w * v_2 * dx
> F3 = ((w - w_last) / dt) * v_3 * dx + dot(grad(w), grad(v_3)) * dx + w * v_3 * dx - v * v_3 * dx
> F = F1 + F2 + F3
> problem = NonlinearProblem(F, U)
> solver = NewtonSolver(MPI.COMM_WORLD, problem)
> solver.convergence_criterion = "incremental"
> solver.rtol = 1e-6
> solver.report = True
> ksp = solver.krylov_solver
> opts = PETSc.Options()
> option_prefix = ksp.getOptionsPrefix()
> opts[f"{option_prefix}ksp_type"] = "preonly"
> opts[f"{option_prefix}pc_type"] = "lu"
> ksp.setFromOptions()
> ic1(U_0, dim, u0, v0, w0)
> t = 0
> for i in range(num_steps_default):
> t = t + dt
> try:
> solver.solve(U)
> U_0.x.array[:] = U.x.array
> except:
> print('Blow up. t = '+str(t))
> return U_0
> return U
> U = calculate_uh(alpha, u0, v0, w0, chi, lamda)
Besides, the situations when \alpha \geq 1 and \alpha =0 worked, so i think the problem is about newton solver and the non-linear term.
Thanks so much for providing any advice!
