I am trying to solve a time-dependent PDE (parabolic PDE) involving vector-valued functions on a 2D mesh.
I tried solving the problem using the VectorFunctionSpace functionality but it seems to be giving incorrect results. To test, I wrote two versions of the code for the 1-dimensional vector case.
In the first code, I used a “FunctionSpace” for a scalar function space on a 2D mesh.
In the second code, I used a “VectorFunctionSpace” of vector-dimension 1, on the 2D mesh.
The first code, (scalar function space) case gives the correct expected result. However, the second code which was expected to give the same result seems to be giving a different incorrect result. Could you please help me understand what might be going wrong? I would like to use the VectorFunctionSpace code to deal with vector-valued functions, but since it doesn’t even work for the 1d vector case, it seems to be giving incorrect results for the higher dimensional vector case as well.
The two codes written in python are as follows:
#Code 1 (Scalar function case, works correctly)
import matplotlib
from mpl_toolkits.mplot3d import Axes3D
from matplotlib.ticker import ScalarFormatter, FormatStrFormatter
dx = dx(metadata={'quadrature_degree': 3})
Tf = 1e-3 # Final time
Nsteps = 5e4
dt = Tf/Nsteps
t = 0. # initial time
Domain = Rectangle(Point(-20.,0.),Point(20.,10.))
Mesh = generate_mesh(Domain,60)
V = FunctionSpace(Mesh, 'P',2)
phis = [ Expression('0.5*x[0]*x[0]',degree=2,domain=Mesh) ]
ic = Expression(str(1./40.),degree=2,domain=Mesh)
u0 = project(ic,V)
#PDE
J = Dx(u,0) + u*Dx(phis[0],0)
ai_phi = (u*v+ dt*J*Dx(v,0))*dx
Li_phi = u0*v*dx
F = ai_phi - Li_phi
#Time Loop for PDE solving
Jac = derivative(F,u)
problem = NonlinearVariationalProblem(F, u, [],Jac)
fig3 = plt.figure(3)
ax3 = fig3.add_subplot(111, projection='3d')
ax3.view_init(elev=45., azim=-65.)
plt.ion()
c2 = None
plotcount=0
for n in range(10):
# Solve the problem
solver.solve()
###### Update intial condition for next time step ######
u0.assign(u)
t=t+dt
plotcount = plotcount + 1
#region ############## plot the solution ####################
if plotcount >=5:
plt.figure(3)
fig3.clear()
ax3.zaxis.set_major_formatter(ScalarFormatter(useOffset=False,useMathText=False))
h2=plot(u,title=r'$\theta$')
c2 = plt.colorbar(h2)
c2.solids.set_edgecolor("face")
plt.show(block=False)
plotcount = 0
print(n)
print(t)
plt.savefig('u.png', bbox_inches='tight')
plt.show(block=True)
Output for code 1:
#Code 2 (Vector Function case, incorrect result)
import matplotlib
Nsteps = 5e4
dt = Tf/Nsteps
Ndim = 1 # Number of dimensions
V = VectorFunctionSpace(Mesh, 'P',2,Ndim) # Main difference from code 1
ic = Expression(tuple([str(1./40.)]*Ndim),degree=2,domain=Mesh)
u0 = project(ic,V)
#PDE
J = Dx(u[0],0) + u[0]*Dx(phis[0],0)
ai_phi = (u[0]*v[0]+ dt*J*Dx(v[0],0))*dx
Li_phi = u0[0]*v[0]*dx
F = ai_phi - Li_phi
plt.ion()
c2 = None
plotcount=0
for n in range(10):
# Solve the problem
solver.solve()
u0.assign(u)
t=t+dt
if plotcount >=5:
plt.figure(3)
fig3.clear()
h2=plot(u[0],title=r'$\theta$')
plotcount = 0
print(n)
print(t)
plt.savefig('u1.png', bbox_inches='tight')
Output for code 2 (incorrect result):
Could you please help me understand why the use of VectorFunctionSpace leads to an incorrect result.
Thanks in advance.
