I have tried HHO implementation but not getting the superconvergnce as expected for each k
#HHO DIFFUSION
#Hybrid High-Order method for diffusion problem
from dolfinx import mesh, fem, io, log
import basix
from scipy.sparse import lil_matrix, csr_matrix, coo_matrix
from scipy.sparse.linalg import bicgstab, spsolve
from numpy.polynomial.legendre import leggauss
import time
import warnings
import itertools
warnings.filterwarnings(“ignore”)
# PROBLEM DEFINITION
def u_exact(x):
"""Exact solution"""
return np.sin(np.pi \* x\[0\]) \* np.sin(np.pi \* x\[1\])
def grad_exact(x):
"""Gradient of exact solution"""
return np.array(\[
    np.pi \* np.cos(np.pi \* x\[0\]) \* np.sin(np.pi \* x\[1\]),
    np.pi \* np.sin(np.pi \* x\[0\]) \* np.cos(np.pi \* x\[1\])
def source(x):
"""Source term f(x)"""
return 2 \* np.pi\*\*2 \* np.sin(np.pi \* x\[0\]) \* np.sin(np.pi \* x\[1\])
def kappa(x):
"""Diffusion tensor (piecewise constant)"""
return np.eye(2)
def bc_dirichlet(x):
"""Dirichlet boundary condition"""
return u_exact(x)
def bc_neumann(x):
"""Neumann boundary condition (zero)"""
return 0.0
# POLYNOMIAL UTILITIES - UPDATED WITH HIERARCHICAL BASIS
def dim_poly(k, d=2):
if k < 0:
    return 0
if d == 2:
    return (k + 1) \* (k + 2) // 2
    return (k + 1) \* (k + 2) \* (k + 3) // 6
def poly_basis_2d(k, x, y, hierarchical=False):
basis = \[\]
if hierarchical:
    \# Constant mode: 1
    basis.append(1.0)
    \# Gradient modes: polynomials with degree >= 1
    for degree in range(1, k + 1):
        for i in range(degree + 1):
            j = degree - i
            basis.append((x \*\* i) \* (y \*\* j))
    \# Standard basis: all monomials (degree 0 to k)
    for degree in range(k + 1):
            j = degree - i
return np.array(basis)
def poly_grad_basis_2d(k, x, y, hierarchical=False):
grad = \[\]
if hierarchical:
    \# Constant mode gradient: 0
    grad.append(np.array(\[0.0, 0.0\]))
    \# Gradient modes: gradients of monomials with degree >= 1
            j = degree - i
            if i > 0:
                dx = i \* (x \*\* (i - 1)) \* (y \*\* j)
                dx = 0.0
            if j > 0:
                dy = j \* (x \*\* i) \* (y \*\* (j - 1))
                dy = 0.0
            grad.append(np.array(\[dx, dy\]))
    \# Standard gradients: gradients of all monomials (degree 0 to k)
            j = degree - i
            if i > 0:
                dx = 0.0
            if j > 0:
                dy = 0.0
return np.array(grad)
def poly_basis_edge(k, s):
"""Evaluate polynomial basis P^k on edge at parameter s"""
return np.array(\[s \*\* i for i in range(k + 1)\])
# GAUSS-LEGENDRE QUADRATURE FOR EDGES (USING BASIX)
def gauss_legendre_1d_basix(n):
points, weights = basix.make_quadrature(
    basix.CellType.interval,  # 1st: CellType
    n                         # 2nd: degree (int)
\# Map from \[-1, 1\] to \[0, 1\]
points = 0.5 \* (points + 1.0)
weights = 0.5 \* weights
return points.flatten(), weights.flatten()
def quadrature_edge(n):
"""Quadrature for edge using Gauss-Legendre"""
return gauss_legendre_1d_basix(n)
def quadrature_triangle(degree):
\# Basix gives points and weights on the reference triangle
    basix.CellType.triangle,  # 2D triangle
    degree                    # quadrature degree
return points, weights
# Mesh utilities
def get_cell_vertices(domain, cell_idx):
"""Get vertices of a cell"""
connectivity = domain.topology.connectivity(domain.topology.dim, 0)
return connectivity.links(cell_idx)
def get_cell_edges(domain, cell_idx):
"""Get edges of a cell"""
connectivity = domain.topology.connectivity(domain.topology.dim, 1)
def get_edge_vertices(domain, edge_idx):
"""Get vertices of an edge"""
connectivity = domain.topology.connectivity(1, 0)
return connectivity.links(edge_idx)
def get_edge_cells(domain, edge_idx):
"""Get cells adjacent to an edge"""
connectivity = domain.topology.connectivity(1, domain.topology.dim)
def get_cell_center(domain, cell_idx):
"""Get center of a cell"""
vertices = get_cell_vertices(domain, cell_idx)
coords = domain.geometry.x
return np.mean(coords\[vertices\], axis=0)
def get_edge_center(domain, edge_idx):
"""Get center of an edge"""
vertices = get_edge_vertices(domain, edge_idx)
def get_cell_measure(domain, cell_idx):
"""Get area of a cell"""
coords = domain.geometry.x\[vertices\]\[:, :2\]
v0, v1, v2 = coords
return 0.5 \* abs(np.cross(v1 - v0, v2 - v0))
def get_edge_measure(domain, edge_idx):
"""Get length of an edge"""
return np.linalg.norm(coords\[1\] - coords\[0\])
def get_edge_normal(domain, cell_idx, edge_idx):
"""Get outward normal of an edge with respect to a cell"""
cell_center = get_cell_center(domain, cell_idx)
edge_verts = get_edge_vertices(domain, edge_idx)
coords = domain.geometry.x\[edge_verts\]
edge_vec = coords\[1\] - coords\[0\]
normal = np.array(\[-edge_vec\[1\], edge_vec\[0\]\])
normal = normal / (np.linalg.norm(normal) + 1e-12)
edge_center = get_edge_center(domain, edge_idx)
to_cell = cell_center - edge_center
if np.dot(normal, to_cell\[:2\]) < 0:
    normal = -normal
return normal
def point_on_edge(domain, edge_idx, s):
"""Get point on edge at parameter s ∈ \[0,1\]"""
return coords\[0\] + s \* (coords\[1\] - coords\[0\])
def is_boundary_edge(domain, edge_idx):
"""Check if an edge is on the boundary"""
cells_adjacent = get_edge_cells(domain, edge_idx)
return len(cells_adjacent) == 1
# ELEMENT QUADRATURE CLASS
class ElementQuad:
def \__init_\_(self, domain, cell_idx, K, L):
    self.domain = domain
    self.cell_idx = cell_idx
    self.K = K
    self.Ldeg = max(L, 0)
    \# Create topology if needed
    domain.topology.create_entities(0)
    domain.topology.create_entities(1)
    domain.topology.create_entities(2)
    domain.topology.create_connectivity(domain.topology.dim, 1)
    domain.topology.create_connectivity(1,0)
    self.edges = get_cell_edges(domain, cell_idx)
    self.n_edges = len(self.edges)
    \# Determine quadrature rule
    self.doeT = self.Ldeg + self.K+1 #Degree of exactness needed for cell integrals
    self.doeF = 2 \* self.K +1 # Degree of exactness needed for face integrals
    \# Minimum quadrature needed for stiffness and mass matrices
    self.quad_rule = max(self.doeT, self.doeF) #Take the maximum of cell and face requirements
    self.quad_rule = max(self.quad_rule, 2\*(self.K+1)) #Ensure sufficient accuracy for L² error computation
    self.quad_rule = min(self.quad_rule, 20) # Cap at Dunavant maximum (20)
    \# Cell quadrature using Dunavant rules
    self.quadT_nodes, self.quadT_weights_ref = quadrature_triangle(self.quad_rule)
    self.v0, self.v1, self.v2 = coords\[0\], coords\[1\], coords\[2\]
    \# Scale weights by cell area
    cell_area = get_cell_measure(domain, cell_idx)
    self.quadT_weights = self.quadT_weights_ref \* (cell_area / 0.5)
    \# Map from reference triangle to physical triangle
    self.quadT_physical = \[\]
    for ref_node in self.quadT_nodes:
        x = self.v0 + ref_node\[0\] \* (self.v1 - self.v0) + ref_node\[1\] \* (self.v2 - self.v0)
        self.quadT_physical.append(x\[:2\])
    self.quadT_physical = np.array(self.quadT_physical)
    self.quadT_size = len(self.quadT_physical)
    \# Edge quadrature (Gauss-Legendre)
    self.quadF_nodes = \[\]
    self.quadF_weights = \[\]
    self.quadF_physical = \[\]
    self.quadF_sizes = \[\]
    for edge_idx in self.edges:
        nodes, weights_ref = quadrature_edge(self.quad_rule)
        edge_len = get_edge_measure(domain, edge_idx)
        self.quadF_nodes.append(nodes)
        self.quadF_weights.append(weights_ref \* edge_len)
        phys = \[\]
        for s in nodes:
            pt = point_on_edge(domain, edge_idx, s)
            phys.append(pt\[:2\])
        self.quadF_physical.append(np.array(phys))
        self.quadF_sizes.append(len(nodes))
    \# Precompute basis function values with hierarchical basis
    self.\_precompute_basis()
def \_precompute_basis(self):
    self.phiT_quadT = \[\]
    self.dphiT_quadT = \[\]
    for pt in self.quadT_physical:
        self.phiT_quadT.append(poly_basis_2d(self.K + 1, pt\[0\], pt\[1\], hierarchical=True))
        self.dphiT_quadT.append(poly_grad_basis_2d(self.K + 1, pt\[0\], pt\[1\], hierarchical=True))
    self.phiT_quadT = np.array(self.phiT_quadT)
    self.dphiT_quadT = np.array(self.dphiT_quadT)
    self.phiL_quadT = \[\]
        self.phiL_quadT.append(poly_basis_2d(self.Ldeg, pt\[0\], pt\[1\], hierarchical=False))
    self.phiL_quadT = np.array(self.phiL_quadT)
    \# Cell basis P^{K+1} at edge quadrature points (HIERARCHICAL)
    self.phiT_quadF = \[\]
    self.dphiT_quadF = \[\]
    for edge_idx in range(self.n_edges):
        phi_list = \[\]
        dphi_list = \[\]
        for pt in self.quadF_physical\[edge_idx\]:
            phi_list.append(poly_basis_2d(self.K + 1, pt\[0\], pt\[1\], hierarchical=True))
            dphi_list.append(poly_grad_basis_2d(self.K + 1, pt\[0\], pt\[1\], hierarchical=True))
        self.phiT_quadF.append(np.array(phi_list))
        self.dphiT_quadF.append(np.array(dphi_list))
    \# Edge basis P^K at edge quadrature points (STANDARD)
    self.phiF_quadF = \[\]
        phi_list = \[\]
        for s in self.quadF_nodes\[edge_idx\]:
            phi_list.append(poly_basis_edge(self.K, s))
        self.phiF_quadF.append(np.array(phi_list))
def get_quadT(self):
    """Return cell quadrature points and weights"""
    return self.quadT_physical, self.quadT_weights
def get_quadF(self, edge_idx):
    """Return edge quadrature points and weights"""
    return self.quadF_physical\[edge_idx\], self.quadF_weights\[edge_idx\]
def get_phiT_quadT(self):
    """Return cell basis P^{K+1} values at cell quadrature points (HIERARCHICAL)"""
    return self.phiT_quadT
def get_dphiT_quadT(self):
    """Return cell basis P^{K+1} gradients at cell quadrature points (HIERARCHICAL)"""
    return self.dphiT_quadT
def get_phiL_quadT(self):
    """Return cell basis P^L values at cell quadrature points (STANDARD)"""
    return self.phiL_quadT
def get_phiT_quadF(self, edge_idx):
    """Return cell basis P^{K+1} values at edge quadrature points (HIERARCHICAL)"""
    return self.phiT_quadF\[edge_idx\]
def get_dphiT_quadF(self, edge_idx):
    """Return cell basis P^{K+1} gradients at edge quadrature points (HIERARCHICAL)"""
    return self.dphiT_quadF\[edge_idx\]
def get_phiF_quadF(self, edge_idx):
    """Return edge basis P^K values at edge quadrature points (STANDARD)"""
    return self.phiF_quadF\[edge_idx\]
def get_phiL_quadF(self, edge_idx):
    """Return cell basis P^L values at edge quadrature points (STANDARD)"""
    phiL_quadF = \[\]
        phiL_quadF.append(poly_basis_2d(self.Ldeg, pt\[0\], pt\[1\], hierarchical=False))
    return np.array(phiL_quadF)
# HHO DIFFUSION CLASS - PRIMAL FORMULATION
class HHODiffusion:
def \__init_\_(self, domain, K, L, kappa_func, source_func, bc_type='Dirichlet',
             bc_dirichlet_func=None, bc_neumann_func=None,
             exact_solution=None, grad_exact=None,
             solver_type='bicgstab', use_scaling=True):
    \# Create connectivity
    domain.topology.create_connectivity(2, 1)
    domain.topology.create_connectivity(1, 2)
    self.cell_edge_connectivity = domain.topology.connectivity(2, 1)
    self.edge_cell_connectivity = domain.topology.connectivity(1, 2)
    self.K = K
    self.L = L
    self.use_scaling = use_scaling
    self.kappa_func = kappa_func
    self.source_func = source_func
    self.bc_type = bc_type
    self.bc_dirichlet_func = bc_dirichlet_func
    self.bc_neumann_func = bc_neumann_func
    self.exact_solution = exact_solution
    self.grad_exact = grad_exact
    self.solver_type = solver_type
    \# DOF dimensions
    self.m_nlocal_cell_dofs = dim_poly(self.Ldeg)
    self.m_nlocal_edge_dofs = self.K + 1
    \# High-order space dimensions:
    \# P^{K+1} full dimension
    self.m_nhighorder_dofs = dim_poly(self.K + 1) # This is N_high for P^{K+1}
    \# Gradient space (remove constant mode): dimension = full - 1
    self.m_nhighorder_grad = self.m_nhighorder_dofs - 1
    self.n_cells = domain.topology.index_map(domain.topology.dim).size_local
    self.n_edges = domain.topology.index_map(1).size_local
    self.m_ntotal_cell_dofs = self.n_cells \* self.m_nlocal_cell_dofs
    self.m_ntotal_edge_dofs = self.n_edges \* self.m_nlocal_edge_dofs
    \# Boundary edge counts
    self.n_dir_edges = 0
    self.n_nondir_edges = 0
    if bc_type == 'Dirichlet':
        for e in range(self.n_edges):
            if is_boundary_edge(domain, e):
                self.n_dir_edges += 1
                self.n_nondir_edges += 1
        self.n_nondir_edges = self.n_edges
    self.m_ndir_edge_dofs = self.n_dir_edges \* self.m_nlocal_edge_dofs
    self.m_nnondir_edge_dofs = self.n_nondir_edges \* self.m_nlocal_edge_dofs
    self.m_ntotal_dofs = self.m_ntotal_cell_dofs + self.m_ntotal_edge_dofs
    \# Storage
    self.aT = {}
    self.P_T_cache = {}  # Will store only gradient coefficients (bP_T)
    self.D_T_cache = {}
    self.D_TF_cache = {}
    self.GlobMat = None
    self.SysMat = None
    self.GlobRHS = None
    self.ScRHS = None
    self.A_sc = None
    self.invATT_ATF_cache = {}
    self.invATT_b_cache = {}
    self.Xh = None
    self.quad_cache = {}
    \# Timing
    self.\_assembly_time = 0
    self.\_solving_time = 0
    self.\_solving_error = 0
    print(f"\[HHO_Diffusion\] Initialized: K={K}, L={L}, cells={self.n_cells}, edges={self.n_edges}")
    print(f"  Cell DOFs: {self.m_nlocal_cell_dofs}, Edge DOFs: {self.m_nlocal_edge_dofs}")
    print(f"  High-order space P^{K+1} full: {self.m_nhighorder_dofs},gradient: {self.m_nhighorder_grad}")
def get_element_quad(self, cell_idx):
    """Get or create ElementQuad for a cell"""
    if cell_idx not in self.quad_cache:
        self.quad_cache\[cell_idx\] = ElementQuad(self.domain, cell_idx, self.K, self.L)
    return self.quad_cache\[cell_idx\]
def \_get_kappa_at_point(self, x, cell):
    """Get diffusion tensor at point"""
    cell_center = get_cell_center(self.domain, cell)
    return self.kappa_func(cell_center)
def diffusion_operator(self, cell_idx, elquad):
    edges = elquad.edges
    n_edges = len(edges)
    local_dofs = self.m_nlocal_cell_dofs + n_edges \* self.m_nlocal_edge_dofs
    N_cell = self.m_nlocal_cell_dofs
    N_edge = self.m_nlocal_edge_dofs
    N_high_full = self.m_nhighorder_dofs
    N_high_grad = self.m_nhighorder_grad      # Gradient modes dimension (N_high_full - 1)
    \# Get quadrature data
    quadT_physical = elquad.quadT_physical
    quadT_weights = elquad.quadT_weights
    n_quadT = len(quadT_physical)
    \# Hierarchical basis at cell quadrature points
    phiT_quadT = elquad.get_phiT_quadT()      # Full P^{K+1} basis \[constant, gradient modes\]
    dphiT_quadT = elquad.get_dphiT_quadT()    # Gradients: first row is zero
    phiL_quadT = elquad.get_phiL_quadT()      # P^L basis
    \# Compute S_T = \[(∇φ\_i, ∇φ\_j)\_T\]
    S_T_full = np.zeros((N_high_full, N_high_full))
    for i in range(N_high_full):
        for j in range(N_high_full):
            for q in range(n_quadT):
                x = quadT_physical\[q\]
                Kx = self.\_get_kappa_at_point(x, cell_idx)
                S_T_full\[i, j\] += quadT_weights\[q\] \* np.dot(dphiT_quadT\[q, i\], Kx @ dphiT_quadT\[q, j\])
    \# Extract reduced matrix eS_T (remove first row/col)
    eS_T = S_T_full\[1:, 1:\]
    \# Compute L_T^{k+1} = \[(φ\_i, 1)\_T\] and L_T^k = \[(φ\_i^L, 1)\_T\]
    \# for constant recovery
    L_T_high = np.zeros(N_high_full)
            L_T_high\[i\] += quadT_weights\[q\] \* phiT_quadT\[q, i\]
    L_T_low = np.zeros(N_cell)
    for i in range(N_cell):
            L_T_low\[i\] += quadT_weights\[q\] \* phiL_quadT\[q, i\]
    \# Compute M_TT^{k,k+1} = \[(φ\_i^L, φ\_j^{K+1})\_T\]
    \# This is the hierarchical mass matrix for P^L and P^{K+1}
    M_TT_k_k1 = np.zeros((N_cell, N_high_full))
                M_TT_k_k1\[i, j\] += quadT_weights\[q\] \* phiL_quadT\[q, i\] \* phiT_quadT\[q, j\]
    \# Extract M_TT^{k,k} as sub-matrix of M_TT^{k,k+1}
    \# Mk;k_TT is a sub-matrix of Mk;k+1_TT
    M_TT_kk = M_TT_k_k1\[:, :N_cell\]  # First N_cell columns correspond to P^L basis
    #Compute bB\_{P,T} = \[(∇φ\_i, ∇φ\_j^L)\_T - Σ\_F (∇φ\_i·n, φ\_j^L)\_F\]
    B_P_T = np.zeros((N_high_full, N_cell))
    \# Cell contribution
    dphiL_quadT = np.zeros((n_quadT, N_cell, 2))
        dphiL_quadT\[q\] = poly_grad_basis_2d(self.Ldeg, quadT_physical\[q\]\[0\], quadT_physical\[q\]\[1\],hierarchical=False)
        for j in range(N_cell):
                B_P_T\[i, j\] += quadT_weights\[q\] \* np.dot(dphiT_quadT\[q, i\], Kx @ dphiL_quadT\[q, j\])
    #face contributions (substract)
    for e, edge_idx in enumerate(edges):
        normal = get_edge_normal(self.domain, cell_idx, edge_idx)
        quadF_physical = elquad.quadF_physical\[e\]
        quadF_weights = elquad.quadF_weights\[e\]
        n_quadF = len(quadF_physical)
        dphiT_quadF = elquad.get_dphiT_quadF(e)
        phiL_quadF = elquad.get_phiL_quadF(e)
                for q in range(n_quadF):
                    x = quadF_physical\[q\]
                    B_P_T\[i, j\] -= quadF_weights\[q\] \* np.dot(dphiT_quadF\[q, i\], Kx @ normal) \* phiL_quadF\[q, j\]
        \# Remove constant mode to get bB_P,T
        bB_P_T = B_P_T\[1:, :\] # N_high_grad x N_cell
    \#  Compute bB\_{P,F} = \[(∇φ\_i·n, φ\_j^F)\_F\]
    B_P_F = \[None\] \* n_edges
    bB_P_F = \[None\] \* n_edges
        phiF_quadF = elquad.get_phiF_quadF(e)
        B_P_F\[e\] = np.zeros((N_high_full, N_edge))
            for j in range(N_edge):
                    B_P_F\[e\]\[i, j\] += quadF_weights\[q\] \* np.dot(dphiT_quadF\[q, i\], Kx @ normal) \* phiF_quadF\[q, j\]
        bB_P_F\[e\] = B_P_F\[e\]\[1:, :\]  # N_high_grad x N_edge
    \# Assemble bB_P = \[bB_P,T, bB_P,F1, ..., bB_P,Fn\]
    bB_P = np.zeros((N_high_grad, local_dofs))
    bB_P\[:, :N_cell\] = bB_P_T
    for e in range(n_edges):
        start = N_cell + e \* N_edge
        bB_P\[:, start:start + N_edge\] = bB_P_F\[e\]
    \# solve reduced system : bP_T = bB_P / es_T
    try:
        bP_T = np.linalg.solve(eS_T +  1e-12\*np.eye(N_high_grad), bB_P)
    except:
        bP_T = np.linalg.lstsq(eS_T + 1e-12\*np.eye(N_high_grad), bB_P, rcond=None)\[0\]
    self.P_T_cache\[cell_idx\] = bP_T
    P_T_full = np.zeros((N_high_full, local_dofs))
    cell_area = L_T_high\[0\]  # (φ\_T^1, 1)\_T = area of cell
    L_T_low_extended = np.zeros(local_dofs)
    L_T_low_extended\[:N_cell\] = L_T_low
    if cell_area > 1e-12:
        P_T_full\[0, :\] = (L_T_low_extended - L_T_high\[1:\] @ bP_T) / cell_area
        P_T_full\[0, :\] = 0.0
    \# Gradient mode coefficients (from reduced solve)
    P_T_full\[1:, :\] = bP_T
    \# Step 8: Compute consistent part A_T^cons = P_T^T S_T P_T
    A_cons = P_T_full.T @ S_T_full @ P_T_full
    \# Compute D_T using hierarchical mass matrices
    \# D_T = (M_TT^{k,k})^{-1} M_TT^{k,k+1} P_T - \[I 0 ... 0\]
    \# (M_TT^{k,k})^{-1} M_TT^{k,k+1} is the matrix of the linear operator
    \# (π\_T^{0,k})|P^{k+1}(T) : P^{k+1}(T) -> P^k(T)
    try:
       M_TT_inv = np.linalg.inv(M_TT_kk + 1e-12 \* np.eye(N_cell))
    except:
       M_TT_inv = np.linalg.lstsq(M_TT_kk + 1e-12 \* np.eye(N_cell), np.eye(N_cell), rcond=None)\[0\]
    D_T = M_TT_inv @ M_TT_k_k1 @ P_T_full
    D_T\[:, :N_cell\] -= np.eye(N_cell)
    \# Compute D_TF for each face using hierarchical mass matrices
    \# D_TF = (M_FF^{k,k})^{-1} M_FT^{k,k+1} P_T - \[0 ... I ... 0\]
    \# (M_FF^{k,k})^{-1} M_FT^{k,k+1} is the matrix of the linear operator
    \# π\_F^{0,k} ∘ γ\_TF^{k+1} : P^{k+1}(T) -> P^k(F)
    STF = np.zeros((local_dofs, local_dofs))
    D_TF_list = \[\]
        hF = get_edge_measure(self.domain, edge_idx)
        phiT_quadF = elquad.get_phiT_quadF(e)
    \# Compute M_FT^{k,k+1} = \[(φ\_i^F, φ\_j^{K+1})\_F\]
    M_FT_k_k1 = np.zeros((N_edge, N_high_full))
    for i in range(N_edge):
                M_FT_k_k1\[i, j\] += quadF_weights\[q\] \* phiF_quadF\[q, i\] \* phiT_quadF\[q, j\]
    \# Compute M_FF^{k,k} = \[(φ\_i^F, φ\_j^F)\_F\]
    M_FF_kk = np.zeros((N_edge, N_edge))
                M_FF_kk\[i, j\] += quadF_weights\[q\] \* phiF_quadF\[q, i\] \* phiF_quadF\[q, j\]
    \# Compute M_FT^{k,k} = \[(φ\_i^F, φ\_j^L)\_F\]
    M_FT_k_k = np.zeros((N_edge, N_cell))
                M_FT_k_k\[i, j\] += quadF_weights\[q\] \* phiF_quadF\[q, i\] \* phiL_quadF\[q, j\]
    try:
        M_FF_inv = np.linalg.inv(M_FF_kk + 1e-12 \* np.eye(N_edge))
    except:
        M_FF_inv = np.linalg.lstsq(M_FF_kk + 1e-12 \* np.eye(N_edge), np.eye(N_edge), rcond=None)\[0\]
    \# Compute D_TF
    D_TF = M_FF_inv @ M_FT_k_k1 @ P_T_full
    face_start = N_cell + e \* N_edge
    D_TF\[:, face_start:face_start + N_edge\] -= np.eye(N_edge)
    D_TF_list.append(D_TF)
    \# Compute (M_FF^{k,k})^{-1} M_FT^{k,k}
    M_FF_inv_M_FT = M_FF_inv @ M_FT_k_k
    \# Compute difference operator for stabilization
    diff_operator = D_TF - M_FF_inv_M_FT @ D_T
    \# Add to stabilization
    STF += (1.0 / hF) \* diff_operator.T @ M_FF_kk @ diff_operator
    \# Step 15: Assemble local matrix A_T = A_cons + STF
    A_T = A_cons + STF
    return A_T
def load_operator(self, cell_idx, elquad):
    b = np.zeros(local_dofs)
    \# Source term contribution to cell DOFs only
    phiL_quadT = elquad.get_phiL_quadT()  # P^L basis functions
    for i in range(self.m_nlocal_cell_dofs):
        for q in range(len(quadT_physical)):
            b\[i\] += quadT_weights\[q\] \* self.source_func(x) \* phiL_quadT\[q, i\]
    return b
    \# Edge DOFs remain zero (no source term)
    \# The source term will be coupled to edge DOFs through static condensation
    \# in the assemble() method
