Hybrid High Order(HHO) method for Poisson Equation Fencisx demo code
Hi everyone,
I’m currently learning the Hybrid High-Order (HHO) method and would really appreciate some guidance. I’m looking for demo or example code using FEniCSx that implements HHO in both 2D and 3D (even simple benchmark problems would be very helpful).
If anyone has:
  • Minimal working examples for the Poisson equation and the Heat equation.
  • GitHub repositories or tutorials.
  • Tips on implementing HHO concepts in FEniCSx.
I’d be grateful if you could share them. I’m especially interested in understanding the implementation’s structure and best practices.
Thanks in advance for your help!.
I guess you could consider contacting the author of:
as they implemented similar codes in DOLFINx and state that their code is available upon request.
Thank you so much Sir!.
Respected Sir,
I requested the materials earlier, but I have not received any response yet. Could you please help me regarding this?. At the moment, I need at least a demo code for the Poisson equation using the HHO method, so that I can use it as a reference and modify it for my work. Thank you for your time and supports.
Dear experts,
I am still struggling with this problem. Is there any demo code available for the Hybrid High-Order (HHO) method applied to the Poisson equation in FEniCSx that could help me understand the implementation?.
In particular, I am looking for a simple example that illustrates the assembly of the bilinear forms, local reconstruction operators, and static condensation (if applicable).
Any guidance, references, or sample codes would be greatly appreciated.
Thank you in advance.
Best regards,
Monirul Islam
I have tried the HHO code for the Poisson equation using quadrilateral mesh discretization; it is running, but not achieving superconvergence. Here is my code>
import scipy.sparse as sp
from scipy.sparse.linalg import spsolve
import dolfinx.fem as fem
import dolfinx.mesh as mesh
import basix
import warnings
# Parameters
k = 1                     # degree for cell and face unknowns (Pk)
deg_phi = k + 1           # degree for reconstructed polynomial
n_ref = 4                 # number of refinement levels
L2error = np.zeros(n_ref)
DGerror = np.zeros(n_ref)
RGerror = np.zeros(n_ref)
Dx = np.zeros(n_ref)
def u_exact(x):
    return np.sin(np.pi * x[0]) * np.sin(np.pi * x[1])
# Helper: map reference interval [0,1] to reference quadrilateral edge
def map_interval_to_quad_edge(t, local_edge):
    local_edge: 0 -> bottom (v0->v1), 1 -> right (v1->v2),
                2 -> top (v2->v3),   3 -> left (v3->v0)
    if local_edge == 0:      # bottom: (t, 0)
        return t, 0.0
    elif local_edge == 1:    # right:  (1, t)
        return 1.0, t
    elif local_edge == 2:    # top:    (1-t, 1)
        return 1.0 - t, 1.0
    else:                    # left:   (0, 1-t)
        return 0.0, 1.0 - t
# Helper: safe inverse of 2x2 matrix (with pseudo‑inverse fallback)
def safe_inv_2x2(J, tol=1e-14):
    det = J[0,0]*J[1,1] - J[0,1]*J[1,0]
    if abs(det) < tol:
        # Use pseudo‑inverse to avoid singular matrix error
        return np.linalg.pinv(J)
        return np.linalg.inv(J)
# Helper: compute physical normal and length for a facet
def facet_normal_and_length(mesh_, facet_index):
    f_verts = mesh_.topology.connectivity(mesh_.topology.dim-1, 0).links(facet_index)
    coords = mesh_.geometry.x[f_verts][:, :2]
    v = coords[1] - coords[0]
    length = np.linalg.norm(v)
    f_to_c = mesh_.topology.connectivity(mesh_.topology.dim-1, mesh_.topology.dim)
    adj = f_to_c.links(facet_index)
    cell_index = adj[0]
    cell_verts = mesh_.topology.connectivity(mesh_.topology.dim, 0).links(cell_index)
    cell_center = np.mean(mesh_.geometry.x[cell_verts][:, :2], axis=0)
    facet_center = np.mean(coords, axis=0)
    vec = facet_center - cell_center
    n = np.array([v[1], -v[0]])
    n = n / np.linalg.norm(n)
    if np.dot(n, vec) < 0:
        n = -n
    return n, length
# Main loop over refinement levels
for n in range(n_ref):
    print(f"\n--- Level {n}, cells per edge = {2**(n+4)} ---")
    n_cells = 2**(n+4)
    mesh_ = mesh.create_rectangle(MPI.COMM_WORLD, [[0.0,0.0],[1.0,1.0]],
                                  [n_cells,n_cells], mesh.CellType.quadrilateral)
    h = 1.0 / n_cells
    Dx[n] = h
    mesh_.topology.create_entities(1)
    mesh_.topology.create_connectivity(mesh_.topology.dim-1, 0)
    mesh_.topology.create_connectivity(mesh_.topology.dim, mesh_.topology.dim-1)
    mesh_.topology.create_connectivity(mesh_.topology.dim-1, mesh_.topology.dim)
    # 1. Function spaces
    V_T = fem.functionspace(mesh_, ("DG", k))
    V_phi = fem.functionspace(mesh_, ("DG", deg_phi))
    num_facets = mesh_.topology.index_map(mesh_.topology.dim-1).size_local
    facets = np.arange(num_facets, dtype=np.int32)
    facet_mesh, facet_map, _, _ = mesh.create_submesh(mesh_, mesh_.topology.dim-1, facets)
    V_F = fem.functionspace(facet_mesh, ("DG", k))
    map_T = V_T.dofmap
    map_phi = V_phi.dofmap
    map_F = V_F.dofmap
    N_T = map_T.index_map.size_local
    N_phi = map_phi.index_map.size_local
    N_F = map_F.index_map.size_local
    # 2. Basix elements and quadrature
    elem_T = basix.create_element(basix.ElementFamily.P, basix.CellType.quadrilateral, k,
                                  basix.LagrangeVariant.equispaced)
    elem_phi = basix.create_element(basix.ElementFamily.P, basix.CellType.quadrilateral, deg_phi,
    elem_F = basix.create_element(basix.ElementFamily.P, basix.CellType.interval, k,
    q_pts_cell, q_wts_cell = basix.make_quadrature(basix.CellType.quadrilateral, 2*deg_phi)
    q_pts_facet, q_wts_facet = basix.make_quadrature(basix.CellType.interval, 2*deg_phi)
    tab_T_cell = elem_T.tabulate(1, q_pts_cell)
    tab_phi_cell = elem_phi.tabulate(1, q_pts_cell)
    phi_T_vals = tab_T_cell[0]
    phi_phi_vals = tab_phi_cell[0]
    grad_phi_ref = tab_phi_cell[1]
    if grad_phi_ref.ndim == 3:
        if grad_phi_ref.shape[2] == 1:
            warnings.warn("Gradient tabulation returned only one component; duplicating to make 2D.")
            grad_phi_ref = np.concatenate([grad_phi_ref, grad_phi_ref], axis=2)
        elif grad_phi_ref.shape[2] != 2:
            grad_phi_ref = grad_phi_ref[:, :, :2]
        raise ValueError("Unexpected gradient shape from Basix tabulation.")
    if phi_phi_vals.ndim == 3:
        phi_phi_vals = phi_phi_vals[:, :, 0]
    # 3. Sparse matrices
    projT = sp.lil_matrix((N_T, N_phi))
    projFd = sp.lil_matrix((N_F, N_phi))
    potT = sp.lil_matrix((N_phi, N_T))
    potF = sp.lil_matrix((N_phi, N_F))
    M_TT_facet = sp.lil_matrix((N_T, N_T))
    M_TF_facet = sp.lil_matrix((N_T, N_F))
    M_FF_facet = sp.lil_matrix((N_F, N_F))
    uPhi = ufl.TrialFunction(V_phi)
    vPhi = ufl.TestFunction(V_phi)
    S_phi_form = ufl.inner(ufl.grad(uPhi), ufl.grad(vPhi)) * ufl.dx
    S_phi = fem.assemble_matrix(fem.form(S_phi_form))
    S_phi = S_phi.to_scipy().tocsc()
    cell_facets = mesh_.topology.connectivity(mesh_.topology.dim, mesh_.topology.dim-1)
    facet_vertices = mesh_.topology.connectivity(mesh_.topology.dim-1, 0)
    vertices_cell = mesh_.topology.connectivity(mesh_.topology.dim, 0)
    num_cells = mesh_.topology.index_map(mesh_.topology.dim).size_local
    num_facets_global = mesh_.topology.index_map(mesh_.topology.dim-1).size_local
    # 4. Cell loop: projT, potT, potF
    for c in range(num_cells):
        dofs_T = map_T.cell_dofs(c)
        dofs_phi = map_phi.cell_dofs(c)
        nT = len(dofs_T)
        nphi = len(dofs_phi)
        cell_verts = vertices_cell.links(c)
        cell_coords = coords[cell_verts][:, :2]   # (4,2)
        # ---- projT ----
        M_T_loc = np.zeros((nT, nT))
        M_T_phi_loc = np.zeros((nT, nphi))
        for q in range(len(q_pts_cell)):
            xi, eta = q_pts_cell[q]
            wq = q_wts_cell[q]
            N = np.array([(1-xi)*(1-eta), xi*(1-eta), xi*eta, (1-xi)*eta])
            dN_dxi = np.array([-(1-eta), (1-eta), eta, -eta])
            dN_deta = np.array([-(1-xi), -xi, xi, (1-xi)])
            J = np.zeros((2,2))
            J[0,0] = np.dot(dN_dxi, cell_coords[:,0])
            J[0,1] = np.dot(dN_deta, cell_coords[:,0])
            J[1,0] = np.dot(dN_dxi, cell_coords[:,1])
            J[1,1] = np.dot(dN_deta, cell_coords[:,1])
            detJ = np.linalg.det(J)
            w = wq * abs(detJ)
            phi_T = phi_T_vals[q, :]
            phi_phi = phi_phi_vals[q, :]
            for i in range(nT):
                for j in range(nT):
                    M_T_loc[i, j] += w * phi_T[i] * phi_T[j]
                for j in range(nphi):
                    M_T_phi_loc[i, j] += w * phi_T[i] * phi_phi[j]
        try:
            projT_loc = np.linalg.solve(M_T_loc, M_T_phi_loc)
        except np.linalg.LinAlgError:
            projT_loc = np.zeros((nT, nphi))
        for i, gi in enumerate(dofs_T):
            for j, gj in enumerate(dofs_phi):
                projT[gi, gj] = projT_loc[i, j]
        # ---- potT and potF ----
        S_phi_loc = np.zeros((nphi, nphi))
        RHS_T_loc = np.zeros((nphi, nT))
        facet_contribs = []
        local_facets = cell_facets.links(c)
        for f in local_facets:
            adj = f_to_c.links(f)
            side_cell = adj[0]
            if side_cell != c:
                continue
            facet_vert_indices = facet_vertices.links(f)
            f_coords = coords[facet_vert_indices][:, :2]
            phys_length = np.linalg.norm(f_coords[1] - f_coords[0])
            # ---- Determine local edge ----
            local_edge = -1
            # 1) index-based
            for e in range(4):
                v1_idx = cell_verts[e]
                v2_idx = cell_verts[(e+1)%4]
                if (v1_idx == facet_vert_indices[0] and v2_idx == facet_vert_indices[1]) or \
                   (v1_idx == facet_vert_indices[1] and v2_idx == facet_vert_indices[0]):
                    local_edge = e
                    break
            # 2) coordinate-based with tolerance
            if local_edge == -1:
                for e in range(4):
                    v1 = cell_coords[e]
                    v2 = cell_coords[(e+1)%4]
                    if (np.allclose(v1, f_coords[0], rtol=1e-6, atol=1e-8) and
                        np.allclose(v2, f_coords[1], rtol=1e-6, atol=1e-8)) or \
                       (np.allclose(v1, f_coords[1], rtol=1e-6, atol=1e-8) and
                        np.allclose(v2, f_coords[0], rtol=1e-6, atol=1e-8)):
                        local_edge = e
                        break
            # 3) distance-based fallback (most robust)
                min_dist = np.inf
                best_edge = -1
                for e in range(4):
                    v1 = cell_coords[e]
                    d1 = np.linalg.norm(f_coords[0] - v1) + np.linalg.norm(f_coords[1] - v2)
                    d2 = np.linalg.norm(f_coords[0] - v2) + np.linalg.norm(f_coords[1] - v1)
                    d = min(d1, d2)
                    if d < min_dist:
                        min_dist = d
                        best_edge = e
                if best_edge != -1:
                    local_edge = best_edge
                raise ValueError("Facet not found in cell")
            t_pts = q_pts_facet[:, 0]
            xi_eta = np.array([map_interval_to_quad_edge(t, local_edge) for t in t_pts])
            tab_T_trace = elem_T.tabulate(1, xi_eta)
            tab_phi_trace = elem_phi.tabulate(1, xi_eta)
            phi_T_trace = tab_T_trace[0]
            phi_phi_trace = tab_phi_trace[0]
            grad_phi_ref_trace = tab_phi_trace[1]
            if grad_phi_ref_trace.ndim == 3:
                if grad_phi_ref_trace.shape[2] == 1:
                    grad_phi_ref_trace = np.concatenate([grad_phi_ref_trace, grad_phi_ref_trace], axis=2)
                elif grad_phi_ref_trace.shape[2] != 2:
                    grad_phi_ref_trace = grad_phi_ref_trace[:, :, :2]
            normal, _ = facet_normal_and_length(mesh_, f)
            w_f = q_wts_facet * phys_length
            f_mesh_cell = facet_map[f]
            dofs_F = map_F.cell_dofs(f_mesh_cell)
            nF = len(dofs_F)
            tab_F = elem_F.tabulate(0, q_pts_facet)
            phi_F_vals = tab_F[0]
            M_TT_edge = np.zeros((nT, nT))
            M_TF_edge = np.zeros((nT, nF))
            M_FF_edge = np.zeros((nF, nF))
            RHS_T_edge = np.zeros((nphi, nT))
            RHS_F_edge = np.zeros((nphi, nF))
            for q in range(len(t_pts)):
                xi, eta = xi_eta[q]
                w = w_f[q]
                phi_Tq = phi_T_trace[q, :]
                phi_Fq = phi_F_vals[q, :]
                J = np.zeros((2,2))
                # ---- Safe inverse ----
                invJ = safe_inv_2x2(J)
                grad_phi_q = grad_phi_ref_trace[q, :, :] @ invJ.T
                n_dot_grad = np.dot(grad_phi_q, normal)
                for i in range(nphi):
                    for j in range(nT):
                        RHS_T_edge[i, j] += w * (-phi_Tq[j] * n_dot_grad[i])
                    for j in range(nF):
                        RHS_F_edge[i, j] += w * (phi_Fq[j] * n_dot_grad[i])
                inv_h = 1.0 / h
                for i in range(nT):
                    for j in range(nT):
                        M_TT_edge[i, j] += w * inv_h * phi_Tq[i] * phi_Tq[j]
                    for j in range(nF):
                        M_TF_edge[i, j] += w * inv_h * phi_Tq[i] * phi_Fq[j]
                for i in range(nF):
                    for j in range(nF):
                        M_FF_edge[i, j] += w * inv_h * phi_Fq[i] * phi_Fq[j]
            facet_contribs.append((dofs_F, M_TT_edge, M_TF_edge, M_FF_edge, RHS_T_edge, RHS_F_edge))
            RHS_T_loc += RHS_T_edge
        # Build RHS_F_loc preserving order
        all_F_dofs = []
        for (dofs_F, _, _, _, _, _) in facet_contribs:
            for dof in dofs_F:
                if dof not in all_F_dofs:
                    all_F_dofs.append(dof)
        total_nF_cell = len(all_F_dofs)
        if total_nF_cell > 0:
            RHS_F_loc = np.zeros((nphi, total_nF_cell))
            for (dofs_F, _, _, _, _, RHS_F_edge) in facet_contribs:
                cols = [all_F_dofs.index(dof) for dof in dofs_F]
                    for j, col in enumerate(cols):
                        RHS_F_loc[i, col] += RHS_F_edge[i, j]
            RHS = np.hstack([RHS_T_loc, RHS_F_loc])
            RHS = RHS_T_loc
        # Assemble S_phi_loc
            wq = q_wts_cell[q]
            J = np.zeros((2,2))
            w = wq * abs(detJ)
            grad_phi_q = grad_phi_ref[q, :, :] @ invJ.T
                    S_phi_loc[i, j] += w * np.dot(grad_phi_q[i, :], grad_phi_q[j, :])
        # Average constraint
        int_phi = np.zeros(nphi)
            wq = q_wts_cell[q]
            J = np.zeros((2,2))
            int_phi += wq * abs(detJ) * phi_phi_vals[q, :]
        n_rhs = RHS.shape[1]
        Aug = np.zeros((nphi+1, nphi+1))
        Aug[:nphi, :nphi] = S_phi_loc
        Aug[:nphi, nphi] = int_phi
        Aug[nphi, :nphi] = int_phi
        RHS_aug = np.vstack([RHS, np.zeros((1, n_rhs))])
        try:
            sol_aug = np.linalg.solve(Aug, RHS_aug)
            sol_aug = np.zeros((nphi+1, n_rhs))
        sol_phi = sol_aug[:nphi, :]
        potT_loc = sol_phi[:, :nT]
        potF_loc = sol_phi[:, nT:] if total_nF_cell > 0 else np.zeros((nphi, 0))
        for i, gi in enumerate(dofs_phi):
            for j, gj in enumerate(dofs_T):
                potT[gi, gj] = potT_loc[i, j]
            for j, dof_F in enumerate(all_F_dofs):
                potF[gi, dof_F] = potF_loc[i, j]
        for (dofs_F, M_TT_edge, M_TF_edge, M_FF_edge, _, _) in facet_contribs:
                    M_TT_facet[gi, gj] += M_TT_edge[i, j]
                for j, gj in enumerate(dofs_F):
                    M_TF_facet[gi, gj] += M_TF_edge[i, j]
            for i, gi in enumerate(dofs_F):
                    M_FF_facet[gi, gj] += M_FF_edge[i, j]
    # 5. projFd (facet projection)
    for f in range(num_facets_global):
        nF = len(dofs_F)
        side_cell = adj[0]
        dofs_phi_side = map_phi.cell_dofs(side_cell)
        nphi_side = len(dofs_phi_side)
        M_FF_loc = np.zeros((nF, nF))
        M_F_phi_loc = np.zeros((nF, nphi_side))
        cell_vert_indices = vertices_cell.links(side_cell)
        cell_coords_side = coords[cell_vert_indices][:, :2]
        local_edge = -1
        # index-based
        for e in range(4):
            v1_idx = cell_vert_indices[e]
            v2_idx = cell_vert_indices[(e+1)%4]
                local_edge = e
                break
        # coordinate-based fallback
            for e in range(4):
                v1 = cell_coords_side[e]
                v2 = cell_coords_side[(e+1)%4]
                    local_edge = e
                    break
        # distance-based fallback
            min_dist = np.inf
            best_edge = -1
            for e in range(4):
                d = min(d1, d2)
                if d < min_dist:
                    min_dist = d
                    best_edge = e
            if best_edge != -1:
            raise ValueError("Facet not found in side cell")
        tab_phi_trace = elem_phi.tabulate(0, xi_eta)
            w = w_f[q]
            phi_F = phi_F_vals[q, :]
            phi_phi = phi_phi_trace[q, :]
            for i in range(nF):
                for j in range(nF):
                    M_FF_loc[i, j] += w * phi_F[i] * phi_F[j]
                for j in range(nphi_side):
                    M_F_phi_loc[i, j] += w * phi_F[i] * phi_phi[j]
        try:
            projFd_loc = np.linalg.solve(M_FF_loc, M_F_phi_loc)
            projFd_loc = np.zeros((nF, nphi_side))
            for j, gj in enumerate(dofs_phi_side):
                projFd[gi, gj] = projFd_loc[i, j]
    # 6. Build reduced system
    projT = projT.tocsc()
    projFd = projFd.tocsc()
    potT = potT.tocsc()
    potF = potF.tocsc()
    M_TT_facet = M_TT_facet.tocsc()
    M_TF_facet = M_TF_facet.tocsc()
    M_FF_facet = M_FF_facet.tocsc()
    I_T = sp.eye(N_T, format='csc')
    I_F = sp.eye(N_F, format='csc')
    CTT = projT * potT - I_T
    CTF = projT * potF
    CFT = projFd * potT
    CFF = projFd * potF - I_F
    C = sp.bmat([[CTT, CTF],
                 [CFT, CFF]], format='csc')
    M_facet = sp.bmat([[M_TT_facet, M_TF_facet],
                       [M_TF_facet.T, M_FF_facet]], format='csc')
    K_facet = C.T * M_facet * C
    A_TT = potT.T * S_phi * potT
    A_TF = potT.T * S_phi * potF
    A_FF = potF.T * S_phi * potF
    A_top = sp.bmat([[A_TT, A_TF],
                     [A_TF.T, A_FF]], format='csc')
    A = A_top + K_facet
    # 7. Right-hand side and BCs
    uT_trial = ufl.TrialFunction(V_T)
    vT_test = ufl.TestFunction(V_T)
    x = ufl.SpatialCoordinate(mesh_)
    f = 2.0 * ufl.pi**2 * ufl.sin(ufl.pi * x[0]) * ufl.sin(ufl.pi * x[1])
    bT_form = ufl.inner(f, vT_test) * ufl.dx
    bT_vec = fem.assemble_vector(fem.form(bT_form))
    bT = bT_vec.array[:N_T]
    bF = np.zeros(N_F)
    b = np.concatenate([bT, bF])
    def on_boundary(x):
        return np.logical_or.reduce([np.isclose(x[0], 0.0),
                                     np.isclose(x[0], 1.0),
                                     np.isclose(x[1], 0.0),
                                     np.isclose(x[1], 1.0)])
    bndry_facets = mesh.locate_entities_boundary(mesh_, mesh_.topology.dim-1, on_boundary)
    bndry_F_dofs = []
    for f in bndry_facets:
        dofs = map_F.cell_dofs(f_mesh_cell)
        bndry_F_dofs.extend(dofs)
    bndry_F_dofs = np.unique(bndry_F_dofs)
    A = A.tolil()
    for i in bndry_F_dofs:
        idx = N_T + i
        A[idx, :] = 0
        A[:, idx] = 0
        A[idx, idx] = 1.0
        b[idx] = 0.0
    A = A.tocsc()
    # 8. Solve and recover fields
    reg = 1e-12
    A_reg = A + reg * sp.eye(A.shape[0], format='csc')
    sol = spsolve(A_reg, b)
    print(f"  sol norm: {np.linalg.norm(sol):.2e}, residual norm: {np.linalg.norm(A_reg*sol - b):.2e}")
    uT_vec = sol[:N_T]
    uF_vec = sol[N_T:]
    phiu_vec = potT * uT_vec + potF * uF_vec
    uT_func = fem.Function(V_T)
    uT_func.x.array[:] = uT_vec
    uF_func = fem.Function(V_F)
    uF_func.x.array[:] = uF_vec
    phiu_func = fem.Function(V_phi)
    phiu_func.x.array[:] = phiu_vec
    # 9. Errors
    u_exact_func = fem.Function(V_phi)
    u_exact_func.interpolate(u_exact)
    L2 = fem.assemble_scalar(fem.form((phiu_func - u_exact_func)**2 * ufl.dx))
    L2error[n] = np.sqrt(L2)
    grad_phi = ufl.grad(phiu_func)
    grad_exact = ufl.grad(u_exact_func)
    energy_cell = (grad_phi - grad_exact)**2 * ufl.dx
    DG_cell = np.sqrt(fem.assemble_scalar(fem.form(energy_cell)))
    dS = ufl.Measure("dS", domain=mesh_)
    jump = (phiu_func - u_exact_func)('+') - (phiu_func - u_exact_func)('-')
    jump_form = (jump**2) / h * dS
    DG_jump = np.sqrt(fem.assemble_scalar(fem.form(jump_form)))
    DGerror[n] = np.sqrt(DG_cell**2 + DG_jump**2)
    grad_uT = ufl.grad(uT_func)
    grad_u_exact = ufl.grad(u_exact_func)
    RG_cell = (grad_uT - grad_u_exact)**2 * ufl.dx
    RG_cell_val = np.sqrt(fem.assemble_scalar(fem.form(RG_cell)))
    RGerror[n] = RG_cell_val
    print(f"  L2error = {L2error[n]:.5e}, DGerror = {DGerror[n]:.5e}, RGerror = {RGerror[n]:.5e}")
# 10. Convergence rates and plot
print("\nConvergence rates:")
for n in range(1, n_ref):
    rate_L2 = np.log(L2error[n-1]/L2error[n]) / np.log(Dx[n-1]/Dx[n])
    rate_DG = np.log(DGerror[n-1]/DGerror[n]) / np.log(Dx[n-1]/Dx[n])
    rate_RG = np.log(RGerror[n-1]/RGerror[n]) / np.log(Dx[n-1]/Dx[n])
    print(f"Level {n}: L2 rate = {rate_L2:.3f}, DG rate = {rate_DG:.3f}, RG rate = {rate_RG:.3f}")
plt.figure()
plt.loglog(Dx, L2error, 'o-', label='L2')
plt.loglog(Dx, DGerror, 's-', label='DG')
plt.loglog(Dx, RGerror, 'd-', label='RG')
plt.xlabel('h')
plt.ylabel('Error')
plt.legend()
plt.grid(True)
Please help!. I would greatly appreciate any help or guidance on how to achieve superconvergence.
Thanks in advance!.
Dear Monis, this is unfortunately not my field of expertise, so hope someone else from the community.
To be able to help, it would be great if you try to split this into pieces:
As you are trying to assemble local kernels by hand, start by verifying that each kernel is assembled correctly.
The code that you have now is a bit daunting on most people as there are a lot of assumptions internally that I would need to look at carefully.
Thanks, Sir, for your kind support.
