It is not so different from a steady state nonlinear problem or a linear time dependent problem. Here is a 1D heat equation with phase change very inspired from this tutorial with a custom NR solver:
from scipy.optimize import fsolve
from scipy.special import erf, erfc
import dolfinx.fem.petsc
plot = False
writepos = False
if plot:
comm = MPI.COMM_WORLD
rank = comm.Get_rank()
def transcendental_fun(x):
return np.sqrt(np.pi)*x - \
(stl / np.exp(np.pow(x,2)) / erf(x) ) + \
(sts / np.exp(np.pow(x,2)) / erfc(x) )
def locate_phase_change_interface(t):
return 2*lamma*np.sqrt(diffusivity*t);
def exact_sol(x,t):
interface_pos = locate_phase_change_interface(t);
sol = np.zeros(x.shape[1],dtype=x.dtype)
liquid_indices = x[0]<=interface_pos
solid_indices = x[0]>interface_pos
sol[liquid_indices] = T_l - (T_l - T_m)*erf(x[0,liquid_indices]/(2*np.sqrt(diffusivity*t)))/erf(lamma)
sol[solid_indices] = T_s + (T_m - T_s)*erfc(x[0,solid_indices]/(2*np.sqrt(diffusivity*t)))/erfc(lamma)
return sol
## PARAMETERS
x_left = 0.0
x_right = 0.1
cross_section = 1.0
rho = 4510*cross_section
c_p = 520
k = 16*cross_section
diffusivity = k / rho / c_p
l = 325000
T_m = 1750
T_l = 2000
T_s = 1500
T_0 = T_s
stl = c_p*(T_l - T_m) / l
sts = c_p*(T_m - T_s) / l
lamma = fsolve(transcendental_fun, 0.388150542167233)
time = 0.0
S = 40
max_nr_iters = 20
dt = 1.0
num_time_steps = 20
Tsl_av = (T_s + T_l)/2.0;
cte = S*2/(T_l - T_s);
# Liquid fraction and derivatives
fl_ufl = lambda tem : 1/2*(ufl.tanh(cte*(tem - Tsl_av))+1.0)
flp_ufl = lambda tem : cte/2.0*(1 - ufl.tanh(cte*(tem - Tsl_av))**2)
flpp_ufl = lambda tem : -cte**2 * ufl.tanh(cte*(tem-Tsl_av)) / (ufl.cosh(cte*(tem-Tsl_av)))**2
nelems = 1000
def main():
domain = mesh.create_interval(comm,nelems,(x_left,x_right))
ufl_coeffs = dict()
for var in ["rho", "c_p", "k", "l", "dt"]:
ufl_coeffs[var] = fem.Constant(domain,float(globals()[var]))
tdim = 1
V = fem.functionspace(domain, ("Lagrange", 1))
f_exact = fem.Function(V, name="exact")
u_np1 = fem.Function(V, name="uh")# Solution
u_n = fem.Function(V, name="uh_n")# Previous time iter
u_i = fem.Function(V, name="uh_i")# Previous non-linear iter
du = fem.Function(V, name="delta_u")# Non-linear increment
# IC
u_np1.x.array[:] = T_s
# Dirichlet BC
bfacets = mesh.locate_entities_boundary(domain, tdim-1, lambda x: np.full(x.shape[1], True, dtype=bool))
bc = fem.dirichletbc(f_exact, fem.locate_dofs_topological(V, tdim-1, bfacets))
# Forms
(delta_u, v) = (ufl.TrialFunction(V), ufl.TestFunction(V))
dx = ufl.dx(metadata={"quadrature_degree": 5})
F = ufl_coeffs["rho"]*ufl_coeffs["c_p"]/ufl_coeffs["dt"]*u_n*v*dx
F += ufl_coeffs["rho"]*ufl_coeffs["l"]*flp_ufl(u_np1)/ufl_coeffs["dt"]*u_n*v*dx
F += -ufl_coeffs["rho"]*ufl_coeffs["c_p"]/ufl_coeffs["dt"]*u_np1*v*dx
F += -ufl_coeffs["rho"]*ufl_coeffs["l"]*flp_ufl(u_np1)/ufl_coeffs["dt"]*u_np1*v*dx
F += -ufl_coeffs["k"]*ufl.dot(ufl.grad(u_np1),ufl.grad(v))*dx
J = ufl.derivative(F,u_np1)
mresidual = fem.form(-F)# minus residual
jacobian = fem.form(J)
A = fem.petsc.create_matrix(jacobian)
L = fem.petsc.create_vector(mresidual)
solver.setOperators(A)
# TIME-LOOP
time = 0.0
for titer in range(num_time_steps):
time += dt
u_n.x.array[:] = u_np1.x.array[:]
lamma_exact_sol = lambda x : exact_sol(x,time)
f_exact.interpolate(lamma_exact_sol)
nriter = 0
while nriter < max_nr_iters:
nriter += 1
u_i.x.array[:] = u_np1.x.array[:]
with L.localForm() as loc_L:
loc_L.set(0)
A.zeroEntries()
fem.petsc.assemble_matrix(A,jacobian, bcs=[bc])
fem.petsc.assemble_vector(L, mresidual)
# Compute b - J(u_D-u_(i-1))
fem.petsc.apply_lifting(L, [jacobian], [[bc]], x0=[u_i.x.petsc_vec])
L.ghostUpdate(addv=PETSc.InsertMode.ADD_VALUES, mode=PETSc.ScatterMode.REVERSE)
fem.petsc.set_bc(L, [bc], u_i.x.petsc_vec)
# Solve
solver.solve(L, du.x.petsc_vec)
du.x.scatter_forward()
u_np1.x.array[:] += du.x.array[:]
correction_norm = du.x.petsc_vec.norm(0)
print(f"Time-step {titer}, NR iter {nriter}: correction norm {correction_norm}")
if correction_norm < 1e-10:
break
if plot:
# PLOT
plt.figure(figsize=(8, 6))
plt.plot(domain.geometry.x[:,0], f_exact.x.array, label='exact_sol', color='r')
plt.plot(domain.geometry.x[:,0], u_np1.x.array, label='uh', color='b')
plt.title('T field')
plt.xlabel('x')
plt.ylabel('T')
plt.legend()
plt.savefig(f"time_iter{titer}.png",dpi=300)
plt.close()
if writepos:
with io.VTKFile(domain.comm, "post/demo_phase_change.pvd", "w") as pf:
pf.write_function([u_np1, f_exact], t=time)
if __name__=="__main__":
main()
This runs with the latest dolfinx version. There is a plot flag at the beginning of the script that will write PNGs if set to true. It will only work properly in serial. There is a writepos flag that will write pvtu files if set to true.
Regarding 2, I am no expert but I would recommend relying on PETSc non-linear solvers (SNES) or the dolfinx NonLinearProblem class.
