In this example code, after solving parallelly I am plotting displacement field for a submesh.
What is the best way to store the parallel mesh and solution so that I can get the required plots for any other submesh later on??
import sys
import pyvista
from dolfinx import mesh, fem, plot, io, default_scalar_type
comm = MPI.COMM_WORLD
rank = comm.Get_rank()
gmsh.option.setNumber("General.Verbosity", 0)
gmsh.model.add("square")
gmsh.model.occ.addRectangle(0, 0, 0, 1, 1, 1)
gmsh.model.occ.addRectangle(1, 0, 0, 1, 1, 2)
gmsh.model.occ.addRectangle(0, 1, 0, 1, 1, 3)
gmsh.model.occ.addRectangle(1, 1, 0, 1, 1, 4)
gmsh.model.occ.fragment(
[(2, 1)], [(2, 2), (2, 3), (2, 4)], removeObject=True, removeTool=True
gmsh.model.occ.synchronize()
lines = gmsh.model.getEntities(1)
surf = gmsh.model.getEntities(2)
for i in lines:
gmsh.model.mesh.setTransfiniteCurve(i[1], 20)
for i in surf:
gmsh.model.mesh.setTransfiniteSurface(i[1])
gmsh.model.mesh.setRecombine(i[0], i[1])
gmsh.model.addPhysicalGroup(2, [1], 101)
gmsh.model.setPhysicalName(2, 101, "d1")
gmsh.model.addPhysicalGroup(2, [2], 102)
gmsh.model.setPhysicalName(2, 102, "d2")
gmsh.model.addPhysicalGroup(2, [3], 103)
gmsh.model.setPhysicalName(2, 103, "d3")
gmsh.model.addPhysicalGroup(2, [4], 104)
gmsh.model.setPhysicalName(2, 104, "d4")
gmsh.model.mesh.generate(2)
# if '-nopopup' not in sys.argv:
# gmsh.fltk.run()
# gmsh.write("mesh.msh")
domain, markers, facets = io.gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, 0, gdim=2)
gmsh.finalize()
V = fem.functionspace(domain, ("Lagrange", 1))
uD = fem.Function(V)
uD.interpolate(lambda x: 1 + x[0] ** 2 + 2 * x[1] ** 2)
# Create facet to cell connectivity required to determine boundary facets
tdim = domain.topology.dim
fdim = tdim - 1
boundary_dofs = fem.locate_dofs_topological(V, fdim, boundary_facets)
bc = fem.dirichletbc(uD, boundary_dofs)
Q = fem.functionspace(domain, ("DG", 0))
kappa = fem.Function(Q)
mA_cells = np.concatenate((markers.find(101), markers.find(102)))
kappa.x.array[mA_cells] = np.full_like(mA_cells, 1, dtype=default_scalar_type)
mB_cells = np.concatenate((markers.find(103), markers.find(104)))
kappa.x.array[mB_cells] = np.full_like(mB_cells, 0.1, dtype=default_scalar_type)
u = ufl.TrialFunction(V)
f = fem.Constant(domain, default_scalar_type(-6))
a = ufl.inner(kappa * ufl.grad(u), ufl.grad(v)) * ufl.dx
L = f * v * ufl.dx
problem = LinearProblem(
a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"}
uh = problem.solve()
combined_indices = []
for tag in [101, 104]:
combined_indices.append(markers.find(tag))
combined_indices = np.sort(np.hstack(combined_indices))
submesh, entity_map, vertex_map, geom_map = mesh.create_submesh(
domain, domain.topology.dim, combined_indices
Vs = fem.functionspace(submesh, ("Lagrange", 1))
uDs = fem.Function(Vs)
uDs.interpolate(
uh, cells0=entity_map, cells1=np.arange(len(entity_map), dtype=np.int32)
# Create local VTK mesh data structures
topology, cell_types, geometry = plot.vtk_mesh(Vs)
num_cells_local = domain.topology.index_map(domain.topology.dim).size_local
num_dofs_local = Vs.dofmap.index_map.size_local * Vs.dofmap.index_map_bs
if topology.shape[0] > 0:
num_dofs_per_cell = topology[0]
num_dofs_per_cell = 0
# Get only dof indices
topology_dofs = (np.arange(len(topology)) % (num_dofs_per_cell + 1)) != 0
# Map to global dof indices
global_dofs = Vs.dofmap.index_map.local_to_global(topology[topology_dofs].copy())
# Overwrite topology
topology[topology_dofs] = global_dofs
# Gather data
global_topology = domain.comm.gather(
topology[: (num_dofs_per_cell + 1) * num_cells_local], root=0
global_geometry = domain.comm.gather(
geometry[: Vs.dofmap.index_map.size_local, :], root=0
global_ct = domain.comm.gather(cell_types[:num_cells_local])
global_def = domain.comm.gather(uDs.x.array[:num_dofs_local])
if rank == 0:
# Stack data
root_geom = np.vstack(global_geometry)
root_top = np.concatenate(global_topology)
root_ct = np.concatenate(global_ct)
root_def = np.concatenate(global_def)
u_grid = pyvista.UnstructuredGrid(root_top, root_ct, root_geom)
u_grid.point_data["u"] = root_def
pyvista.start_xvfb()
u_plotter = pyvista.Plotter(off_screen=True)
u_plotter.add_mesh(u_grid, show_edges=True)
u_plotter.show()
u_plotter.screenshot(f"u_{domain.comm.rank}_{domain.comm.size}.png")
I came across this where I can store the serialized data which can then be used to generate plots later on but this is not recommended.
