Hello. If one runs the tutorial about subdomains in parallel (c9214c68438ab27d2fa8936307027c5209272162):
mpirun -np 2 python3 subdomains.py
The plots of the meshes are split (among processes)
Is there a way to do some sort of collect with MPI to show the whole mesh? I’m looking for a solution which works with Gmsh’s API for Python. Thanks!
For reference, the relevant (slightly modified) code of subdomains.py:
import pyvista
from dolfinx.fem import (
dirichletbc, Function, FunctionSpace, locate_dofs_geometrical,)
from dolfinx.mesh import create_unit_square, locate_entities
from dolfinx import io
from ufl import (TestFunction, TrialFunction)
bottom_marker = 1
top_marker = 2
left_marker = 1
proc = MPI.COMM_WORLD.rank
model = gmsh.model.occ
if proc == 0:
# Create one rectangle for each subdomain
model.add_rectangle(0, 0, 0, 1, 0.5, tag=1)
model.add_rectangle(0, 0.5, 0, 1, 0.5, tag=2)
# Fuse the two rectangles and keep their interface
model.fragment([(2, 1)], [(2, 2)])
model.synchronize()
# Mark the top (2) and bottom (1) rectangle (2D)
top, bottom = None, None
for surf_dimtag in gmsh.model.get_entities(dim=2):
com = model.get_center_of_mass(*surf_dimtag)
if np.allclose(com, [0.5, 0.25, 0]):
bottom = surf_dimtag[1]
top = surf_dimtag[1]
gmsh.model.add_physical_group(2, [bottom], bottom_marker)
gmsh.model.add_physical_group(2, [top], top_marker)
# Tag the left boundary (1D)
left = []
for line in gmsh.model.get_entities(dim=1):
com = model.get_center_of_mass(line[0], line[1])
if np.isclose(com[0], 0):
left.append(line[1])
gmsh.model.add_physical_group(1, left, left_marker)
gmsh.model.mesh.generate(2)
mesh_gmsh, ct, ft = io.gmshio.model_to_mesh(
gmsh.model, MPI.COMM_WORLD, 0, gdim=2)
cell_tags, facet_tags = ct, ft
gmsh.finalize()
domain = mesh_gmsh
Q = FunctionSpace(domain, ("DG", 0))
def Omega_0(x):
return x[1] <= 0.5
def Omega_1(x):
return x[1] >= 0.5
kappa = Function(Q)
cells_0 = locate_entities(domain, domain.topology.dim, Omega_0)
cells_1 = locate_entities(domain, domain.topology.dim, Omega_1)
kappa.x.array[cells_0] = np.full_like(cells_0, 1, dtype=ScalarType)
kappa.x.array[cells_1] = np.full_like(cells_1, 0.1, dtype=ScalarType)
V = FunctionSpace(domain, ("CG", 1))
dofs = locate_dofs_geometrical(V, lambda x: np.isclose(x[0], 0))
bcs = [dirichletbc(ScalarType(1), dofs, V)]
num_cells_local = domain.topology.index_map(domain.topology.dim).size_local
marker = np.zeros(num_cells_local, dtype=np.int32)
cells_0 = cells_0[cells_0<num_cells_local]
cells_1 = cells_1[cells_1<num_cells_local]
marker[cells_0] = 1
marker[cells_1] = 2
topology, cell_types, x = vtk_mesh(domain, domain.topology.dim, np.arange(num_cells_local, dtype=np.int32))
p = pyvista.Plotter(window_size=[800, 800])
grid = pyvista.UnstructuredGrid(topology, cell_types, x)
grid.cell_data["Marker"] = marker
grid.set_active_scalars("Marker")
p.add_mesh(grid, show_edges=True)
if not pyvista.OFF_SCREEN:
p.show()
My system
FEniCSx software
dolfinx: 0.7.0.dev0_r27554.cfeffe0-1
basix: 0.7.0.dev0_r945.1117a8d-1
ufl: 2023.2.0.dev0_r3562.77ae57c-1
ffcx: 0.7.0.dev0_r7077.1d27238-1 -
Dependencies
python: 3.11.5-2
python-numpy: 1.26.0-1
petsc: 3.19.5.1171.g37df9106526-1
hdf5-openmpi: 1.14.2-1
boost: 1.83.0-2
adios2: 2.8.3-5
scotch: 7.0.4-1
pybind11: 2.11.1-1
python-build: 1.0.1-1
python-cffi: 1.15.1-4
python-cppimport: 22.08.02.r6.g0849d17-1
python-installer: 0.7.0-3
python-mpi4py: 3.1.4-3
python-pytest: 7.4.2-1
python-scikit-build: 0.17.6-1
python-setuptools: 1:68.0.0-1
python-wheel: 0.40.0-3
xtensor: 0.24.0-2
xtensor-blas: 0.20.0-1 -
Operating system
Arch Linux: 6.5.4-arch2-1
