Dear all,
I am working on solving a non-linear PDE with a coefficient depending on the solution in a complex way. So far, I have used UserExpression to define the coefficient. For example, I have a coefficient q like below with UserExpression in Python (the detail of the variational form does not matter).
N = 100
X = 1.0
mesh = dl.IntervalMesh(N, 0, X)
degree = 1 # linear basis functions
Vh = dl.FunctionSpace(mesh, "Lagrange", degree)
u = dl.interpolate(dl.Expression("x[0]", degree = 1), Vh)
alpha = 2.0
class user_expr(dl.UserExpression):
def set_alpha(self, u, alpha): # in the user_expr class
self.u = u
self.alpha = alpha
def eval(self, value, x): # in the user_expr class
if self.u(x) > 0.5:
value[0] = 0.5
value[0] = self.alpha * self.u(x)* self.u(x)
def value_shape(self):
return ()
user_expr2 = user_expr(degree = 0)
user_expr2.set_alpha(u, alpha)
q = dl.interpolate(user_expr2, dl.FunctionSpace(mesh, "Lagrange", 1))
print(assemble((q*dl.dx))
However, to solve the PDE using the Newton method, it might be better to implement the variational form without using UserExpression (well, the Newton can be implemented with UserExpression, but mathematically a bit different from what I expected). If the coeffcient q is simple, such as
def q(u):
return 1 + u**2
, then there is no problem in implementing it in Python like above and evaluate the variational form
print(assemble((q(u)*dl.dx))
However, my coefficient is very long and complex (includes conditional statements), so implementing it in Python leaded to unacceptable computational time. So, I want to implement the variational form in C++ to speed up the calculation. Is there any good ways?
Thank you for all the help from the community, I really appreciate that.
