Pass Function to C++ expression
Hi everyone,
I would like to speed up my code and I have the following problem: I want to create a more complicated Expression based on a finite element function. I can create the functionality I need with an UserExpression, which looks like this:
class profile(fenics.UserExpression):
def __init__(self, u, *arg, **kwargs):
    super().__init__(*arg, **kwargs)
    self.u = u
def eval(self, values, x):
    x_local = np.mod(x[0], 1.5e-3)
    values[0] = 0
    values[1] = self.u(x_local)
def value_shape(self):
    return (2,)
where u is just a solution of a (either 1 or 2 dimensional) PDE computed in fenics.
I am not an Expert for C++, but I thought that I can also generate this result using a C++ Expression, which should be way faster to interpolate. I know that I can use the std::fmod command in order to do the modulus operation I need, but I am not sure how to pass a fenics function to C++ code, and how to evaluate it there.
So far I tried the following:
cpp_code = """
#include <pybind11/eigen.h>
namespace py = pybind11;
#include <dolfin/function/Expression.h>
#include <dolfin/function/Function.h>
class Profile : public dolfin::Expression
public:
 Profile() : dolfin::Expression(2) {}
  void eval(Eigen::Ref<Eigen::VectorXd> values, Eigen::Ref<const Eigen::VectorXd> x) const override
    u->eval(values, x);
    const double val = values[0];
    values[0] = 0.0;
    values[1] = val;
  std::shared_ptr<dolfin::Function> u;
PYBIND11_MODULE(SIGNATURE, m)
  py::class_<Profile, std::shared_ptr<Profile>, dolfin::Expression>
    (m, "Profile")
    .def(py::init<>())
    .def_readwrite("u", &Profile::u);
which I can also compile using
profile = fenics.compile_cpp_code(cpp_code)
However, once I try passing the function to the expression, or compiling it, with
expr = fenics.CompiledExpression(profile.Profile(), degree=1, u=u)
I get the following error:
TypeError: (): incompatible function arguments. The following argument types are supported:
1. (self: dolfin_cpp_module_d2657709e7d4b986fae5165a8cc3b358.Profile, arg0: dolfin.cpp.function.Function) -> None
Invoked with: <dolfin_cpp_module_d2657709e7d4b986fae5165a8cc3b358.Profile object at 0x7fe56413bae8>, Coefficient(FunctionSpace(Mesh(VectorElement(FiniteElement(‘Lagrange’, interval, 1), dim=1), 140), FiniteElement(‘Lagrange’, interval, 2)), 147)
Any help for this would be really appreciated, thank you very much.
The following modified version appears to work:
cpp_code = """
public:
  Profile(std::shared_ptr<dolfin::Function> u_) : dolfin::Expression(2){
    u = u_;
    u->eval(values, x);
    values[0] = 0.0;
    values[1] = val;
    (m, "Profile")
    .def(py::init<std::shared_ptr<dolfin::Function> >())
mesh = UnitSquareMesh(10,10)
V = FunctionSpace(mesh,"CG",1)
profile = compile_cpp_code(cpp_code)
expr = CompiledExpression(profile.Profile(u.cpp_object()), degree=1)
u.interpolate(Constant(7.0))
values = np.zeros(2)
x = np.array([0.5,0.5])
expr.eval(values,x)
print(values)
Thanks a lot, it works
Hey, David!
It seems like your code is not reproducible in the latest dolfin version. Some import errors appear.
I am currently doing things closely related to this topic: passing python list of Functions to c++ function. However, I get TypeError: incompatible function arguments on a simple example with just one Function:
# P1.ufl
# lies in ./cutils/tests/
element = FiniteElement("Lagrange", triangle, 1)
u = Coefficient(element)
M = u*dx
forms = [M]
# MWE
cpp_code = """
#include <dolfin.h>
#include "P1.h"
using namespace dolfin;
double simple(std::shared_ptr<Function> u) {
  auto V = u->function_space();
  P1::Form_M mass_form(V->mesh(), u);
  return assemble(mass_form);
PYBIND11_MODULE(SIGNATURE, m) {
    m.def("simple", &simple, py::arg("u"));
module = compile_cpp_code(cpp_code, include_dirs=['cutils/tests'])
# ./cutils/tests - is the location of P1.h compiled with `ffc -l dolfin P1.ufl`
mesh = UnitSquareMesh(32, 32)
module.simple(u.cpp_object())
Execution of the last piece of code raises:
TypeError: simple(): incompatible function arguments. The following argument types are supported:
    1. (u: dolfin::Function) -> float
Invoked with: <dolfin.cpp.function.Function object at 0x7f79885703b0>
I tried to follow David’s reply, but it didn’t help me.
Does anyone know how to handle this?
Yep, the problem is in the dolfin’s version. In 2018.1.0 it works, in the latest docker image of 2019.1.0, it doesn’t
Were you able to figure this out? I am having the same problem.
For anyone reading this later: You have to includesome header files :slight_smile:
This worked for me. This code simply reads the values from the function/Expression/MeshFunction and adds the values. Hope this helps anyone :slight_smile: :upside_down_face:
#include <dolfin/function/Expression.h> // for expressions
#include <dolfin/mesh/MeshFunction.h> //  for MeshFunctions
#include <dolfin/function/Function.h> // for functions
class your_Function_Name : public dolfin::Expression
   public:
       your_Function_Name() : dolfin::Expression(3){} // 3 Dimensional vector as output, use Expression() for scalar
       void eval(Eigen::Ref<Eigen::VectorXd> values, Eigen::Ref<const Eigen::VectorXd> x, const ufc::cell& cell) const override
           func1->eval(values, x);
           const double val1 = values[0];
           const double val2 = values[0];
           values[0] = val1 + val2; // do your stuff here
           exp1->eval(values, x);
           const double val3 = values[0];
           exp2->eval(values, x);
           const double val4 = values[0];
           values[1] = val3 + val4; // do your stuff here
           const uint cell_index = cell.index;
           values[2] = (*MshFunc1)[cell_index] + (*MshFunc2)[cell_index]; // do your stuff here
       std::shared_ptr<dolfin::Function> func1;
       std::shared_ptr<dolfin::Function> func2;
       std::shared_ptr<dolfin::Expression> exp1;
       std::shared_ptr<dolfin::Expression> exp2;
       std::shared_ptr<dolfin::MeshFunction<size_t>> MshFunc1;
       std::shared_ptr<dolfin::MeshFunction<size_t>> MshFunc2;
   py::class_<your_Function_Name, std::shared_ptr<your_Function_Name>, dolfin::Expression>(m, "your_Function_Name")
   .def(py::init<>())
   .def_readwrite("func1", &your_Function_Name::func1)
   .def_readwrite("func2", &your_Function_Name::func2)
   .def_readwrite("exp1", &your_Function_Name::exp1)
   .def_readwrite("exp2", &your_Function_Name::exp2)
   .def_readwrite("MshFunc1", &your_Function_Name::MshFunc1)
   .def_readwrite("MshFunc2", &your_Function_Name::MshFunc2);
