Import tet mesh in dolfinx
Error ehile loading 3D tet mesh in dolfinx.
 mesh, subdomains, boundaries = gmshio.read_from_msh("tet_3D.msh", MPI.COMM_WORLD,0, gdim=3)
Cell In[8], line 1
----> 1 mesh, subdomains, boundaries = gmshio.read_from_msh("tet_3D.msh", MPI.COMM_WORLD,0, gdim=3)
File /usr/lib/petsc/lib/python3/dist-packages/dolfinx/io/gmshio.py:373, in read_from_msh(filename, comm, rank, gdim, partitioner)
    371 gmsh.model.add("Mesh from file")
    372 gmsh.merge(filename)
--> 373 msh = model_to_mesh(gmsh.model, comm, rank, gdim=gdim, partitioner=partitioner)
    374 gmsh.finalize()
    375 return msh
File /usr/lib/petsc/lib/python3/dist-packages/dolfinx/io/gmshio.py:290, in model_to_mesh(model, comm, rank, gdim, partitioner, dtype)
    287         facet_values = np.empty((0,), dtype=np.int32)
    289 # Create distributed mesh
--> 290 ufl_domain = ufl_mesh(cell_id, gdim, dtype=dtype)
    291 gmsh_cell_perm = cell_perm_array(_cpp.mesh.to_type(str(ufl_domain.ufl_cell())), num_nodes)
    292 cells = cells[:, gmsh_cell_perm].copy()
File /usr/lib/petsc/lib/python3/dist-packages/dolfinx/io/gmshio.py:76, in ufl_mesh(gmsh_cell, gdim, dtype)
     74     raise e
     75 cell = ufl.Cell(shape)
---> 76 element = basix.ufl.element(
     77     basix.ElementFamily.P,
     78     cell.cellname(),
     79     degree,
     80     basix.LagrangeVariant.equispaced,
     81     shape=(gdim,),
     82     dtype=dtype,  # type: ignore[arg-type]
     83 )
     84 return ufl.Mesh(element)
File /usr/lib/python3/dist-packages/basix/ufl.py:2006, in element(family, cell, degree, lagrange_variant, dpc_variant, discontinuous, shape, symmetry, dtype)
   2003     elif family == EF.DPC:
   2004         dpc_variant = _basix.DPCVariant.diagonal_gll
-> 2006 e = _basix.create_element(
   2007     family, cell, degree, lagrange_variant, dpc_variant, discontinuous, dtype=dtype
   2008 )
   2009 ufl_e = _BasixElement(e)
   2011 if shape is None or shape == tuple(e.value_shape):
File /usr/lib/python3/dist-packages/basix/finite_element.py:606, in create_element(family, celltype, degree, lagrange_variant, dpc_variant, discontinuous, dof_ordering, dtype)
    577 def create_element(
    578     family: ElementFamily,
    579     celltype: CellType,
    585     dtype: npt.DTypeLike = np.float64,
    586 ) -> FiniteElement:
    587     """Create a finite element.
    588
    589     Args:
    603         A finite element.
    604     """
    605     return FiniteElement(
--> 606         _create_element(
    607             family.value,
    608             celltype.value,
    609             degree,
    610             lagrange_variant.value,
    611             dpc_variant.value,
    612             discontinuous,
    613             dof_ordering if dof_ordering is not None else [],
    614             np.dtype(dtype).char,
    615         )
    616     )
RuntimeError: Cannot pass a DPC variant to this element.
The .msh data:
$MeshFormat
2.2 0 8
$EndMeshFormat
$Nodes
9
1    -2.2299981443473595 0.49374912834507845 10.344827586206897
2    -2.056342014934421 0.42234502598529555 10.544827586206896
3    -2.062486500247639 0.4089720553352334 10.544827586206896
4    -2.0568290303717087 0.4199458559101729 10.744827586206895
5    -2.0573160458089967 0.4175466858350502 10.944827586206895
6    -2.0627328421274402 0.40675703452746365 10.744827586206895
7    -2.234752320279737 0.4861608460276258 10.744827586206895
8    -2.232375232313548 0.48995498718635216 10.544827586206896
9    -2.062240158367838 0.4111870761430031 10.344827586206897
$EndNodes
$Elements
4
1    4    2    0    1 1 2 3 9
2    4    2    0    1 8 4 3 2
3    4    2    2    1 8 4 6 3
4    4    2    2    1 7 5 6 4
$EndElements
The 4th column is for subdomain data and 5th to 8th column is for element connectivity.
Looks like your upgrade is incomplete. Which ubuntu are you using?
I completed the upgrade and install fenicx again. The ubuntu is 22.04.3. dolfinx is now working, however, I am getting error in loading .msh file using gmshio.
@dparsons
I am getting following error after updation.
from dolfinx.fem import VectorFunctionSpace, form, petsc, Function, FunctionSpace
ImportError                               Traceback (most recent call last)
Cell In[2], line 2
      1 import dolfinx
----> 2 from dolfinx.fem import VectorFunctionSpace, form, petsc, Function, FunctionSpace
ImportError: cannot import name 'VectorFunctionSpace' from 'dolfinx.fem' (/usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/__init__.py)
It was working previously, but, after updating, it has error.
That still looks like an incomplete upgrade. Are you sure you ran sudo apt update before installing or upgrading?
Or you mean it fails when you import VectorFunctionSpace? The API changed in v0.8.
See further discussion for instance at Automatic update to Fenicsx 0.8 broke ufl.FiniteElement
@dparsons . Thanks for identifying the issue. With new syntax, it works.
import basix
V = dolfinx.fem.functionspace(mesh, basix.ufl.element(
    "CG", mesh.topology.cell_name(), 1, shape=(3, )))
