Hi everybody!
I am using FEniCS 2019.1.0 running on MacOS. I am trying to solve a linear Maxwell viscoelasticity problem using a mixed formulation and following the approach of Rognes and Winther (2008), where stress is calculated using BDM elements, velocity and rotation DG.
I think I wrote the variational formulation correctly, but when I write the initial condition of zero stress, I have a problem in the assemble of the rhs. This is part of my code:
define functions
def asym(z):
return z[0,1] - z[1,0]
def AEsigma(s):
return 1./(2.mu)(s - lmbda/(2.mu + dlmbda)*tr(s)*Identity(d))
def AVsigma(s):
return (1./(2.*eta))*s
define function spaces
k = 1
BDM = VectorFunctionSpace(mesh, “BDM”, k) # stress
DGv = VectorFunctionSpace(mesh, “DG”, k - 1) # displacement
DGs = FunctionSpace(mesh, “DG”, k - 1) # rotation
mixed Function Space
Vh_element = MixedElement([BDM.ufl_element(), DGv.ufl_element(), DGs.ufl_element()])
Vh = FunctionSpace(mesh, Vh_element)
zero stress Dirichlet BCs
zero_tensor = Expression(((“0.0”, “0.0”), (“0.0”, “0.0”)), degree=1)
bc1 = DirichletBC(Vh.sub(0), zero_tensor, boundaries, topleft_id)
bc2 = DirichletBC(Vh.sub(0), zero_tensor, boundaries, topright_id)
bcs = [bc1, bc2]
initial condition
sigma0 = Function(BDM)
v0 = Function(DGv)
Dt = Constant(dt)
define trial and test functions
(sigma, v, gamma) = TrialFunctions(Vh)
(tau, w, q) = TestFunctions(Vh)
write the weak form: lhs and rhs
lhs = inner(AVsigma(sigma)*Dt, tau)*dx + inner(AEsigma(sigma), tau)dx + inner(div(tau), vDt)*dx
+ inner(asym(tau)*Dt, gamma)*dx
+ inner(div(sigma), w)*dx + inner(asym(sigma), q)*dx
rhs = inner(v0, tau*n)*ds(zerodispl_id)
+ inner(AEsigma(sigma0), tau)*dx
t = 0.
sol = Function(Vh)
while t < t_end:
apply prescribed displacement at t = dt (after first iteration)
if t == dt:
slip = -1
rhs += inner(slip, dot(tau('+')*n('+'), tangent(n)('+')))*dS(fault_id)
# Assemble the linear system
A = assemble(lhs)
b = assemble(rhs)
[bc.apply(A) for bc in bcs]
[bc.apply(b) for bc in bcs]
solve(A, sol.vector(), b)
(sigma, v, gamma) = sol.split(deepcopy=True)
# Update previous solutions
sigma0.assign(sigma)
If could anyone help me, I would appreciate it. Thank you so much in advance!
