Initial Conditions for mixed Element
Hello Everyone,
I would like to define Inital Conditions for a mixed Element Problem. I have found this post: https://fenicsproject.org/qa/13118/specifying-initial-values-for-mixed-vector-and-scalar-fields/
and tried to implement it in my Code, which runs without errors. But when I compare the results with the ones, were I dont have the Inital Conditions they are the same. (I used tkdiff and there was no singel diffrence in the files I looked at).
I would really appreciate it, if you could tell me what I did wrong.
Here is a running example: I hope its not to long
Elasticity parameters
E= 10010**6 # E in Pa
nu = 0.25 # Querkontraktionszahl
n_por = 0.01 # Porosität wird zu 0 gesetzt da sie bei ihnen garnicht erst vorkommt
k0= 1
10**(-14)
visk = 1 * 10**(-5)
k = k0/visk # Permeabilität in m^4/Ns
b = 1 # Biot Koefficent
M = 10**14 # Biot Modul
F = 1000 # Kraft welche auf die Platte wirkt
a = 1 # Länge des Plattenabschnitts
G = Constant(E/(2*(1 + nu))) # Schubmodul
K = Constant((1+nu)/(3*(1-nu))2G*(1-nu)/(1-2nu))
B_big = Constant(b
M/(K+pow(b,2)M))
nu_u = Constant((3
nu+bB_big(1-2nu))/(3-bB_big*(1-2*nu)))
Zeitvariablen
T = 1.0 # final time
num_steps = 1000 # number of time steps
#dt = 0.01
Create mesh and define function space
nx0 = 0
ny0 = 0
nx1 = 1
ny1 = 1
mesh = RectangleMesh(Point(nx0, ny0), Point(nx1, ny1), 30,30)
P2 = VectorElement(‘Lagrange’, mesh.ufl_cell(), 2) # für die Verschiebung quadratisch
P1 = FiniteElement(‘Lagrange’, mesh.ufl_cell(), 1) # für den Druck linear
Make a mixed space V.sub(0)- FiniteElement
V.sub(1) - VectorElement
TH = P2 * P1
V = FunctionSpace(mesh, TH)
Mark boundary subdomians
class rechts(SubDomain):
tol = 1E-14
return on_boundary and near(x[0],1,tol)
class links(SubDomain):
tol = 1E-14
return on_boundary and near(x[0],0,tol)
class oben(SubDomain):
tol = 1E-14
return on_boundary and near(x[1],1,tol)
class unten(SubDomain):
tol = 1E-14
return on_boundary and near(x[1],0,tol)
right = rechts()
left = links()
top = oben()
bottom = unten()
boundaries = MeshFunction(‘size_t’,mesh,mesh.topology().dim()-1)
boundaries.set_all(0)
left.mark(boundaries,1)
right.mark(boundaries,2)
top.mark(boundaries,3)
bottom.mark(boundaries,4)
Define functions
(u, p) = TrialFunctions(V)
(v, r) = TestFunctions(V)
du = Function(V)
u0, p0 = split(du)
Define Constants
n_por = Constant(n_por) # Porosität
k = Constant(k) # Permeabilität
nu = Constant(nu) # Querkontraktionszahl
b = Constant(b)
M = Constant(M)
F = Constant(F)
a = Constant(a)
mu = Constant(E/(2*(1 + nu)))
lam = Constant(E * nu/( (1+nu)(1-2 nu)))
Fluidfluss am Rand
q = 0 # -q_vektor*n= q
Kinematics
d = u.geometric_dimension()
I = Identity(d) # Identity tensor
linearer Spannungstensor
return sym(nabla_grad(u))
Spur des Spannungstensors
def tr_epsilon(u):
return tr(epsilon(u))
lineare Festkörperspannung
def sigma_s(u):
return lam* tr_epsilon(u)* Identity(d) + 2* mu * epsilon(u)
Spannungstensor aus Festkörper und Fluidanteil
def sigma(u,p):
return (1-n_por) * sigma_s(u) -n_por* p*I
ds_test = ds(domain=mesh, subdomain_data=boundaries)
Impulsbilanz + Darcy und Fluidmassenbilanz
T1 = Expression((“1000”, “0”),degree =2)
T2 = Expression((“-1000”, “0”),degree =2)
Imp =inner(sigma(u,p),nabla_grad(v)) * dx -inner(T1,v) * ds_test(3) -inner(T2,v) * ds_test(4)
Fl = qrds_test(3) +qrds_test(4) - k * inner(nabla_grad( p ),nabla_grad( r )) * dx -
(tr_epsilon(u) - tr_epsilon(u0))/dt *r *dx
eqn = Imp + Fl
Fluid +Verschiebungsrandbedingung - free-slip BC
bcu_B = DirichletBC(V.sub(0).sub(1), Constant((0)), bottom)
bcu_L = DirichletBC(V.sub(0).sub(0), Constant((0)), left)
bcp_R = DirichletBC(V.sub(1), Constant((0)), right) >
bc_ges = [bcu_L, bcu_B, bcp_R]
Initial Conditions:
e_p0 = Expression(‘1/(3a) * B_big * (1+nu_u) * F’, degree =2, F=F, a=a, B_big=B_big,nu_u=nu_u)
e_u0 = Expression(('(F
nu_u/(2*G))x[0]/a’ , '-F(1-2 * nu_u)/(2 * G) * (x[1]/a)’), degree =2, F=F, a=a, G=G ,nu_u=nu_u)
p_0 = interpolate(e_p0, V.sub(1).collapse())
u_0 = interpolate(e_u0, V.sub(0).collapse())
w = Function(V)
assign(w, [u_0, p_0])
Aufteilen der Gleichung in linke und rechte Seite
l = lhs(eqn)
r = rhs(eqn)
Solve variational problem
Step in time
t = 0
for n in range(num_steps):
# Update current time
solve(l == r, w, bc_ges)
(u,p) = w.split(True)
assign(du.sub(0), u)
If I’m interpreting the variables correctly, the previous time step’s solution is du, so that is what should be set to the initial condition, not w, which does not appear in the problem eqn (and therefore does not affect its solution), and is simply over-written with the current solution after the solve.
Thank you so much for your quick and good answer!
I changed
to
assign(du, [u_0, p_0])
and now its working!
I’m trying to solve a different problem: I have a poromechanic Material and I’m pulling on the right side.
I’m not sure, if my implementation of the initial Condition is correct, because I define, that the pressure at
p0 = 10000
but the pressure of my next time step is in a range from 0 (because of my boundary Condition) to -100. I dont understand the big difference between t0 and t1. Is there a mistake in my implementation? Or do I have to implement an initial pressure differently?
Here is the section with the initial condition of my code (and at the bottom is a running example)
P2 = VectorElement('Lagrange', Netz.ufl_cell(), 2)      # displacement
P1 = FiniteElement('Lagrange', Netz.ufl_cell(), 1)      # pressure
# Make a mixed space
TH = P2 * P1
V = FunctionSpace(Netz, TH)
# Class representing the intial conditions
class InitialConditions(UserExpression):
    def eval(self, values, x):
        values[0] = 0.0                 # ux
        values[1] = 0.0                 # uy
        values[2] = 10000.0             # p
    def value_shape(self):
        return (3,)
# Define functions
(u, p) = TrialFunctions(V)		# new Timestep
du = Function(V)                # old Timestep
u0, p0 = split(du)
# Create intial conditions and interpolate
u_init = InitialConditions()
du.interpolate(u_init)
'''2D Poromechanik'''
from numpy import cos , pi
from ufl import nabla_div
# Elasticity parameters
E= 220*1000		# E in Pa
nu = 0.45 		# Querkontraktionszahl
b = 1                # Biot Koeffizient b = 1 für inkompr. Fluid + Solid (Castelletto)
k = 2.88*10**(-14)		# Permeabilität	in m^4/Ns
K_f = 3.3*10**9 #von Wasser in Pa Detournay S- 24
phi = 0.54 # Porosität
M = Constant(K_f/phi)
p_ini = 10000
# Timevariables
T = 10          # final time
num_steps = 100    # number of time steps
# Define Constants
b = Constant(b)		# Biot Koeff
lam = Constant(E*nu/( (1+nu)*(1-2*nu)))
K = Constant((1+nu)/(3*(1-nu))*2*G*(1-nu)/(1-2*nu))
B_big = Constant(b*M/(K+pow(b,2)*M))
nu_u = Constant((3*nu+b*B_big*(1-2*nu))/(3-b*B_big*(1-2*nu)))
#                                   Create mesh  Beginning                      #
nx0 = 0
ny0 = 0
nx1 = 0.090 # in m
ny1 = 0.030 # in m
#nx1 = 9*10^-3
#ny1 = 3*10^-3
def mesh(lx,ly, Nx,Ny):
    m = UnitSquareMesh(Nx, Ny)
    x = m.coordinates()
    #Refine on the left and right sides
    x[:,0] = (x[:,0] - 0.5) * 2.
    x[:,0] = 0.5 * (cos(pi * (x[:,0] - 1.) / 2.) + 1.)
    #Scale
    x[:,0] = x[:,0]*lx
    x[:,1] = x[:,1]*ly
    return m
Netz = mesh(nx1,ny1, 40,40)
nCells = Netz.num_cells()
print('Das Netz besteht aus', nCells,'Elementen')
#                                   Create mesh  Ende                      #
TH = P2 * P1
#                                Boundary Stuff: Anfang                      #
# Mark boundary subdomians
def boundary(x, on_boundary):   # fuer Druck-RB
    return on_boundary
        tol = 1E-14
        return on_boundary and near(x[0],nx1,tol)
        tol = 1E-14
        return on_boundary and near(x[0],nx0,tol)
        tol = 1E-14
        return on_boundary and near(x[1],ny1,tol)
        tol = 1E-14
        return on_boundary and near(x[1],ny0,tol)
right = rechts()
left = links()
top = oben()
bottom = unten()
boundaries = MeshFunction('size_t',Netz,Netz.topology().dim()-1)
ds_test = ds(domain=Netz, subdomain_data=boundaries)
n   = FacetNormal(Netz)
# Boundary Conditions
bcp_O  = DirichletBC(V.sub(1), Constant(0), top)
bcp_U  = DirichletBC(V.sub(1), Constant(0), bottom)
bcu_L  = DirichletBC(V.sub(0), Constant((0, 0)), left)
# pulling on the right side
Dehnrate = 1*10**(-3)
u_RB_lin = Expression(("Dehnrate*t"), degree=2, Dehnrate=Dehnrate, t=0)
RB = DirichletBC(V.sub(0).sub(0),  u_RB_lin, right)
bc_ges = [bcu_L, bcp_U, bcp_O, RB]
        return (3,)
#                                Boundary Stuff: Ende                        #
# Define functions
Tensor_grad = 2
u0, p0 = split(du)
theta = 0.5     # 1 -> Euler Rückwärts, 0.5 -> Crank Nicolson
p_mid = (1-theta)*p0+ theta*p
# Kinematics
# linearer strain tensor
#    return 0.5*(nabla_grad(u) + nabla_grad(u).T)
def tr_epsilon(u):
# Stress tensor
def sigma(u,p):
	return 2*G* epsilon(u) + 2*G * nu/(1-2*nu) *(nabla_div(u))*I - b*p*I
# Momentum balance + Darcy und Fluidmassbalance
Imp =inner(sigma(u,p),nabla_grad(v))*dx
Fl = b*(tr_epsilon(u) - tr_epsilon(u0))/dt *r *dx + 1/M * (p-p0)/dt *r*dx +\
     k*inner(nabla_grad((p_mid)),nabla_grad(r))*dx
F = Imp + Fl
l = lhs(F)
r = rhs(F)
t = 0
#                               Lösungsschleife                        #
    u_RB_lin.t=t
    w = Function(V)
    if n ==0:
        w.interpolate(u_init)
    du.assign(w)
as far as I can tell, you are not updating du (u0, p0) with the previous solution in your loop. You should do du.assign(w)
ah, Iam sorry I deleted the whole saving of data lines after the splitting to make the code shorter and also deleted the line:
du.assign(w)
but it is in my code, so unfortunatly, its not that, but thank you for your quick answer.
(I will edit my previous post to put it in there)
Can I also assign a value to a TrialFunction, like I do it for a “normal” function like I do it here:
du.interpolate(u_init) ?
Because something like p.assign(…) failed.
A trial function can’t be assigned values
Hi, I have 2 questions.
For example in my problem:
P3 = FiniteElement('P', mesh.ufl_cell(), 2)
ele = MixedElement([P3,P3,P3])
VV = FunctionSpace(mesh, ele)
#Define test functions
vv1,vv2,vv3 = TestFunction(VV)
#Define problem to solve
uu = Function(VV)
phi,bound_s,bound_ns = split(uu)
#Define initial and boundary conditions
u_n = Function(VV) #Automatically sets to zero
phi_n,bound_s_n,bound_ns_n = split(u_n)
1) How do I assign an inital value to phi_n?
Given that I have the defined various boundaries and regions within my mesh as follows:
mesh = Mesh()
with XDMFFile(output_folder_name+model+".xdmf") as infile:
    infile.read(mesh) #Feeds data from xdmf to mesh variable
mvc = MeshValueCollection("size_t", mesh, 1) #Container for mesh values
with XDMFFile(output_folder_name+"mf"+model+".xdmf") as infile:
    infile.read(mvc, "name_to_read") #Feeds boundary data to mvc
mvc2 = MeshValueCollection("size_t", mesh, 1)
with XDMFFile(output_folder_name+"cf"+model+".xdmf") as infile:
    infile.read(mvc2, "name_to_read")
boundaries = MeshFunction("size_t", mesh, mvc)
regions = MeshFunction("size_t", mesh, mvc2)
2) How do I assign an inital value to phi_n only for a specific region or boundary?
Please advise, thanks
For the first question, see: Access function in time dependent XDMFFile which will refer you to the FunctionAssigner-function.
For the second question, consider this minimal example:
mesh = UnitSquareMesh(2,1)
mf = MeshFunction("size_t", mesh, mesh.topology().dim()-1, 0)
class left(SubDomain):
        return x[0]<1e-10 and on_boundary
left().mark(mf, 1)
uu = Function(VV)
V0,V1,V2 = VV.split()
V0 = V0.collapse()
v0 = Function(V0)
v0.interpolate(Expression("1-x[0]+x[1]",degree=1))
# Setting values for part of boundy of subspace_vector
init_bc = DirichletBC(VV.sub(0), v0, mf, 1)
init_bc.apply(u_n.vector())
print("u_n", u_n.vector().get_local())
print("sub-vector:", u_n.split(deepcopy=True)[0].vector().get_local())
# Setting bc for whole boundary
full_bc = DirichletBC(VV, Expression(("1-x[0]","1-x[0]","1-x[0]"),degree=1), "on_boundary")
full_bc.apply(u_n.vector())
print("Full space", u_n.vector().get_local())
Hi thanks for getting back to me. Sorry but I don’t think I was clear with my question. I don’t mean to apply a Dirichlet boundary condition but rather an initial condition.
Essentially, I want to assign a value to phi_n for a specific edge which is defined in boundaries at time = 0.
Where
phi_n, bound_s_n, bound_ns_n = split(u_n)
and
such that for time > 0 the values at this edge changes according to the diffusivity of the material.
That is what i have done here. I am just using the Dirichlet BC to apply the specific condition to the vector at the given edges.
After applying the BC to u_n, you can use it as an initial condition in the variational form.
Oh I see. Thank you very much! :slight_smile:
