In which cases should we consider non-zero traction term?
Supposing I have this variational form of the linear elasticity problem to solve:
\int\limits_\Omega (\sigma:∇v) dx = \int\limits_{\delta\Omega} (\sigma.n.v) ds + \int\limits_\Omega f.v dx, where T = \sigma.n
In this tutorial, the traction T is set to 0. But I guess, this is not always the case for elastic equation, is not it?
Here are my questions:
  • What is the physical sense of the traction term? Is it an external constraint imposed on the boundary (like external forces) or rather an internal-behaviour term due to the equation itself?
  • In which cases should I consider and leave the traction term in the variational form? For instance, I read non-zero traction was “artificially” used to avoid simulation divergence when potential fluid backflow, but it was in the case of Navier-Stokes equation → So what about elastic equation?
  • In the examples I read on non-zero traction boundaries, it was proposed an imposed value for the traction (e.g. Constant((1.0, 1.0)). But is it possible/what happens if I leave the theoretical expression of traction as it is: \int\limits_{\delta\Omega} (\sigma.n.v) ds ? (I tried to do so but it seems to crash and I had to put it at T=0)
Many thanks for your help,
Anne
Hi Anne,
Some clarification: in your first equation you should write T \cdot v in the RHS, and as a natural result you will have \sigma \cdot n = T.
  1. From the Cauchy theorem t(x, n) = \sigma(x) \cdot n , where x is the position.
  2. If you forget traction terms in a primal formulation, it means zero-traction, i.e., free-boundary.
  3. It does not work since your \sigma(u) and in the RHS you should only have v, i.e., no trials, only test functions.
Hope that it helps.
Felipe
Many thanks for your answer @Felipe_Rocha,
  • I made some other researches. From what I understood, that are the different steps required to formulate the variational form which lead to then “inject” traction T into the equation (as in https://fenicsproject.org/pub/tutorial/html/._ftut1011.html):
    • Problem:
      \left\{ \begin{array} &-Δ\sigma(u) = f&\\ u=uD& \mbox{on} &\Gamma_D& \mbox{(Dirichlet boundary conditions)}\\ \sigma(u).n =T& \mbox{on} &\Gamma_N& \mbox{(Neumann/"traction" boundary conditions)}\\ \end{array} \right.
    • Variational form (using integration by part):
      \int_{\Omega}(\sigma:\nabla v) dx = \int_{\Omega}(f. v) dx + \int_{\delta\Omega}(\sigma(u).n. v) ds , \mbox{∀v∈V}
    • Boundary conditions:
      \int_{\delta\Omega}(\sigma.n. v) ds = \int_{\Gamma_D}(\sigma(u_D).n. v) ds + \int_{\Gamma_N}(T. v) ds
    • Taking v=0 on \Gamma_D and injecting the traction boundary condition:
      \int_{\Omega}(\sigma:\nabla v) dx = \int_{\Omega}(f. v) dx + \int_{\Gamma_N}(T. v) ds , \mbox{∀v∈V}
  • As a matter of fact, T can be “choosen” as a external surface loading force, which is physicially equivalent to internal stresses at boundary (\sigma(u)). Is that correct?
  • So to conclude, here are my refined questions:
    1. I can choose the traction term expression:
    • either T = non-zero fenics.Constant (homogeneous traction loading)
    • either T = f(x,y,z) (heterogenous traction loading)
    • either T = 0 traction-free)
      Is that correct?
    1. I don’t need to write the term \int_{\delta\Omega}(\sigma(u).n. v) ds in the fenics variational form (LHS in that case), but I replace it by \int_{\Gamma_N}(T. v) ds with the imposed traction T in RHS, isn’t it?
    2. I can consider non-zero traction term if I want to consider external surface loading in my model. Isn’t it?
Anne
Hi Anne,
For your middle question: Traction is equivalent to \sigma \cdot n.
Yes for your 3 refined questions. In your initial problem I suppose you wanted to write the divergence instead of the Laplacian.
Cheers,
Felipe
Hi Felipe,
Many thanks for your feedback.
You are rigtht about σ⋅n and the divergence! It’s a mistake.
Kind regards,
Anne
