Integrating function over internal marked boundary
Hello everyone,
I am solving simple linear elasticity problem, I want to calculate traction over the internal marked boundary, I am always getting a value zero, but I am successful in calculating over the external boundary. Also, I am unable to calculate the length of any internal marked line.
Scaled variables
L = 1; W = 1
mu = 7.6923e10
rho = 1
delta = W/L
gamma = 0.4*delta**2
beta = 11.53846e10
lambda_ = beta
g = gamma
Create mesh and define function space
mesh = RectangleMesh(Point(0,0), Point(1, 1), 50, 50, “left”)#UnitSquareMesh(25, 25)
V = VectorFunctionSpace(mesh, ‘P’, 1)
Define boundary condition
class bottom(SubDomain):
def inside(self,x, on_boundary):
tol = 1e-14
return (near(x[1],0.00)) and on_boundary
class top(SubDomain):
tol = 1e-10
return near(x[1],1.00) and on_boundary
class Marked(SubDomain):
tol = 1e-10
return near(x[0]+x[1],0.5,0.002)
boundaries = MeshFunction(“size_t”,mesh,mesh.topology().dim()-1)
boundaries.set_all(0)
bottom= bottom()
top = top()
bottom.mark(boundaries,1)
top.mark(boundaries,2)
Marked=Marked()
Marked.mark(boundaries,3)
meshfile=File(‘mesh.pvd’)
meshfile<<boundaries
bc_bottom = DirichletBC(V.sub(1),Constant((0)),bottom)
bc = [bc_bottom]
ds = Measure(‘ds’, domain=mesh, subdomain_data=boundaries)
Define strain and stress
#return sym(nabla_grad(u))
def sigma(u):
return lambda_nabla_div(u)Identity(d) + 2muepsilon(u)
ex = Constant((1.0, 0.0))
ey = Constant((0.0, 1.0))
Define variational problem
d = u.geometric_dimension() # space dimension
f = Constant((0,0))
T = Constant((0, 100000))
L = dot(f, v)*dx + dot(T, v)*ds(2)
Compute solution
solve(a == L, u, bc)
L1 = assemble(1*ds(2)) #Length of Top Marked Boundary
print L1 #Calculating correct
L2 = assemble(1*ds(3)) ##Length of Interior Marked Boundary
print L2 #Alwayz giving Zero for any interior length
#Want to calculate Traction
Tx = assemble(dot(dot(sigma(u), n),ex)*ds(3))
print Tx #It always gives zero
Ty = assemble(dot(dot(sigma(u), n),ey)*ds(3))
print Ty #It always gives zero
Thanks in advance for your time
The facets you mark with 3 are interior facets of the mesh hence the measure to be used for surface itengration over them is dS, cf. ds for exterior facet integrals. The following post could be useful.
Your suggestion worked. Thank you MiroK!!
