Hi all.
I have doubts on how to impose Neumann boundary conditions in my problem. I have an energy functional of \mathbf m(r,\theta) given by
F[\mathbf m]=\int_{\Omega} dx\, J(r,\theta) f_B(\mathbf m) + \int_{\partial\Omega_1} ds_1\, J(r,\theta) f_S(\mathbf m,\mathbf m_1) + \int_{\partial\Omega_2} ds_2\, J(r,\theta) f_S(\mathbf m,\mathbf m_2) \,,
where J(r,\theta)=r^2 \sin\theta is the Jacobian of the transformation to spherical coordinates, \mathbf m_1 and \mathbf m_2 are simply constant vectors and the surface integrals are performed in (different) regions 1 and 2 of the boundary.
As can be seen in the MWE below, I do dF = ufl.derivative(F, m, phi)
to find the weak form and then define the non-linear problem fem.petsc.NonlinearProblem(dF, m, J=JF)
which automatically includes Robin BCs in boundaries 1 and 2.
In this context, I would like to impose also Neumann BCs in the region 0 of the boundary, such that \partial_r\mathbf{m}=0 and \partial_{\theta}\mathbf{m}=0 for r=0. How can I incorporate this to my formulation of the problem?
Thanks in advance!
from dolfinx import mesh, fem, nls, log, plot, geometry
mesh_comm = MPI.COMM_WORLD
OPdim = 3 # dimension of the OP
gdim = 2 # dimension of the geometry
Rbase = 1 # radius of the base (sphere)
def boundaryMeasure():
boundaries = [(0, lambda x: np.isclose(x[0], 0)), # origin
(1, lambda x: np.isclose(x[0], Rbase)), # base
(2, lambda x: np.isclose(x[1], minq)), # flat cap
(3, lambda x: np.isclose(x[1], np.pi))]
tdim = domain.topology.dim; fdim = tdim - 1
facets = mesh.locate_entities(domain, fdim, locator)
facet_indices.append(facets)
facet_tag = mesh.meshtags(domain, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
return ufl.measure.Measure("ds", domain=domain, subdomain_data=facet_tag)
def Jacob(x):
xr, xq = x
return xr**2*ufl.sin(xq)
def curl_sph(A, x):
"""Curl of a vector field depending only on r and theta in spherical coordinates."""
xr, xq = x; jr, jq = 0, 1
Ar, Aq, Af = A
curl_r = (ufl.Dx(Af*ufl.sin(xq),jq))/(xr*ufl.sin(xq))
curl_q = (-ufl.Dx(xr*Af,jr))/xr
curl_f = (ufl.Dx(xr*Aq,jr)-ufl.Dx(Ar,jq))/xr
return ufl.as_vector([curl_r, curl_q, curl_f])
def div_sph(A, x):
"""Divergence of a vector field depending only on r and theta in spherical coordinates."""
Ar, Aq, Af = A
div_r = ufl.Dx(xr**2*Ar,jr)/xr**2
div_q = ufl.Dx(Aq*ufl.sin(xq),jq)/(xr*ufl.sin(xq))
div_f = 0
return div_r + div_q + div_f
def fB(u, x):
fT = a/2.*ufl.dot(u,u) + c/4.*ufl.dot(u,u)**2
fD = d*( (div_sph(u,x))**2 + (ufl.dot(u,curl_sph(u,x)))**2 + (ufl.cross(u,curl_sph(u,x)))**2 )
return fT + fD
def fS(u, u0):
u0 = ufl.as_vector(u0)
return w/2*ufl.dot(u-u0,u-u0)
def ET(u, x):
u0base, u0cap = [1,0,0], [1,0,0]
ds = boundaryMeasure() # custom integration measure over the boundaries
return fB(u,x)*Jacob(x)*ufl.dx + fS(u,u0base)*Jacob(x)*ds(1) + fS(u,u0cap)*Jacob(x)*ds(2)
def solveProblem(prob):
solver = nls.petsc.NewtonSolver(mesh_comm, prob)
#solver.ksp_type = "preonly"
solver.rtol = 1e-12
solver.max_it = 100
solver.report = True
minit = [1,0,0] # initial guess for the unknown function
minit = ufl.as_vector([fem.Constant(domain, ScalarType(minit[0])),fem.Constant(domain, ScalarType(minit[1])),
fem.Constant(domain, ScalarType(minit[2]))])
expr = fem.Expression(minit, V.element.interpolation_points())
m.interpolate(expr)
solver.nonzero_initial_guess = True
#log.set_log_level(log.LogLevel.INFO)
n, converged = solver.solve(m)
assert(converged)
print(f"Number of iterations: {n:d}")
#### physical parameters
a = 0.1; c = 0.01
d = 0.01
w = 1
#### define the domain of integration
minq = np.pi/2; bins = 10
domain = mesh.create_rectangle(mesh_comm, np.array([[0,minq],[Rbase,np.pi]]),[bins,int(bins*(np.pi-minq))])
#### define the space of funtions and the functions that we will use
element = ufl.VectorElement("CG", domain.ufl_cell(), 1, OPdim)
V = fem.FunctionSpace(domain, element) # space of vector functions with gdim components
m = fem.Function(V, name='m') # OPdim-dimensional vector OP
dm = ufl.TrialFunction(V) # variation of the OP
phi = ufl.TestFunction(V) # test function
#### derive the weak formulation directly from the energy functional
F = ET(m, x) # total energy
dF = ufl.derivative(F, m, phi) # variation of the energy
JF = ufl.derivative(dF, m, dm) # Jacobian of the energy
#### define and solve the problem
problem = fem.petsc.NonlinearProblem(dF, m, J=JF)
solveProblem(problem)
