Incompatible constructor arguments for inner product
Hello community,
I’m working on elastic deformation of rotational symmetric cases. Therefore somebody gave me an example which I try to adapt.
The code of this example is:
#get_ipython().run_line_magic('matplotlib', 'notebook')
Re = 11.
Ri = 9.
rect = Rectangle(Point(0., 0.), Point(Re, Re))
domain = Circle(Point(0., 0.), Re, 100) - Circle(Point(0., 0.), Ri, 100)
domain = domain - Rectangle(Point(0., -Re), Point(-Re, Re))                 - Rectangle(Point(0., 0.), Point(Re, -Re))
mesh = generate_mesh(domain, 40)
plot(mesh)
class Bottom(SubDomain):
        return near(x[1], 0) and on_boundary
class Left(SubDomain):
        return near(x[0], 0) and on_boundary
class Outer(SubDomain):
        return near(sqrt(x[0]**2+x[1]**2), Re, 1e-1) and on_boundary
facets = MeshFunction("size_t", mesh, 1)
facets.set_all(0)
Bottom().mark(facets, 1)
Left().mark(facets, 2)
Outer().mark(facets, 3)
ds = Measure("ds", subdomain_data=facets)
x = SpatialCoordinate(mesh)
def eps(v):
    return sym(as_tensor([[v[0].dx(0), 0, v[0].dx(1)],
                          [0, v[0]/x[0], 0],
                          [v[1].dx(0), 0, v[1].dx(1)]]))
E = Constant(1e5)
nu = Constant(0.3)
mu = E/2/(1+nu)
lmbda = E*nu/(1+nu)/(1-2*nu)
def sigma(v):
    return lmbda*tr(eps(v))*Identity(3) + 2.0*mu*eps(v)
p = Constant(10.)
V = VectorFunctionSpace(mesh, 'CG', degree=1)
du = TrialFunction(V)
u_ = TestFunction(V)
a = inner(sigma(du), eps(u_))*x[0]*dx
At first I tried to change the geometry and run the script until that point is reached.
Ra=11
Ri=9
lz=2
#-----------------------------------------------------------------------------2D-domain and mesh
domain= Rectangle(Point(Ri, 0), Point(Ra, lz))
mesh = generate_mesh(domain, 10)
#-----------------------------------------------------------------------------2D-Boundarydefinition
class house(SubDomain):
        return near(x[0], Ra, 1e-1) and on_boundary
class rod(SubDomain):
        return near(x[0], Ri, 1e-1) and on_boundary
class outer(SubDomain):
        return near(x[1], lz, 1e-1) and on_boundary
class inner(SubDomain):
        return near(x[1], 0, 1e-1) and on_boundary
facets.set_all(0)
inner().mark(facets, 1)
house().mark(facets, 2)
outer().mark(facets, 3)
rod().mark(facets, 4)
def eps(v):
    return sym(as_tensor([[v[0].dx(0), 0, 0.5*(v[1].dx(0)+v[0].dx(1))],
                          [0, v[0]/x[0], 0],
			   [0.5*(v[1].dx(0)+v[0].dx(1)), 0, v[1].dx(1)]]))
E = Constant(1e5)
nu = Constant(0.3)
mu = E/2/(1+nu)
lmbda = E * nu/(1+nu)/(1-2 * nu)
def sigma(v):
return lmbda * tr(eps(v)) * Identity(3) + 2.0 * mu * eps(v)
p = Constant(10.)
Now, I get the error, that eps and sigma are not compatible for the inner product. And exactly, by printing both, there is a clear difference between them. But I don’t get why. Sigma is computed from eps in exactly the same way in both codes? Or not?
Thank you very much for any help.
Florian
Please reformat the code such that indentation is preserved.
This should be the case if you encapsulate your code with 3x` after copy pasting it from a text editor
what do you mean with that? β€œ3x`” and β€œ```” both do not work.
3x` as in ``` should render code as follows:
def test(x):
    return x[0]
:slight_smile: :slight_smile: like that? :slight_smile: :slight_smile:
This is because you have overloaded the function inner with this class. Change the name of this class.
