Hello, I was surprised when running my code on a new machine and my unit tests failed.
Here is a MWE reproducing my error:
The code solves a singular traction test with pure neuman traction BCs.
Since the problem is singular, I enforce that the solution is orthogonal to the operator nullspace through krylov solver options, by setting the nullspace in the PETSc matrix. As usual I solve the problem with algebraic multigrid with a jacobi coarse solver to avoid messing up the nullspace during coarse solves.
import dolfinx.mesh, dolfinx.fem as fem, dolfinx.geometry
from contextlib import ExitStack
from numpy.testing import assert_almost_equal
def nullspace_elasticity_2D(V: fem.FunctionSpace):
"""Build nullspace for 2D linear elasticity."""
# Create list of vectors for null space
index_map = V.dofmap.index_map
nullspace_basis = [
dolfinx.la.create_petsc_vector(index_map, V.dofmap.index_map_bs)
for i in range(3)
with ExitStack() as stack:
vec_local = [stack.enter_context(x.localForm()) for x in nullspace_basis]
basis = [np.asarray(x) for x in vec_local]
# Dof indices for each subspace (x and y dofs)
dofs = [V.sub(i).dofmap.list.array for i in range(2)]
# Build translational null space basis
for i in range(2):
basis[i][dofs[i]] = 1.0
# Build rotational null space basis
dofs_block = V.dofmap.list.array
x0, x1 = x[dofs_block, 0], x[dofs_block, 1]
basis[2][dofs[0]] = -x1
basis[2][dofs[1]] = x0
# Create vector space basis and orthogonalize
dolfinx.la.orthonormalize(nullspace_basis)
nsp = PETSc.NullSpace().create(vectors=nullspace_basis)
return nsp
if __name__ == "__main__":
mesh = dolfinx.mesh.create_unit_square(MPI.COMM_SELF, 5, 5)
V = fem.VectorFunctionSpace(mesh, ("CG", 1))
u = ufl.TrialFunction(V)
E = 10
nu = 0.3
C = ufl.inv(1/ E * ufl.as_matrix([
[1, -nu, 0],
[-nu, 1, 0],
[0, 0, (2 * (1 + nu))],
strain2voigt = lambda eps: ufl.as_vector([eps[0, 0], eps[1, 1], 2 * eps[0, 1]])
voigt2stress = lambda sigma: ufl.as_vector([[sigma[0], sigma[2]], [sigma[2], sigma[1]]])
strain = lambda u: ufl.sym(ufl.grad(u))
stress = lambda u, C: voigt2stress(ufl.dot(C, strain2voigt(strain(u))))
a = ufl.inner(stress(u, C), strain(v)) * ufl.dx
n = ufl.FacetNormal(mesh)
sigma0 = ufl.as_matrix([[1.0, 0], [0.0, 0.0]])
L = ufl.dot(ufl.dot(sigma0, n), v) * ufl.ds
gamg_options = {
"ksp_type": "cgs",
"ksp_rtol": 1.0e-12,
"pc_type": "gamg",
"mg_levels_ksp_type": "chebyshev",
"mg_levels_pc_type": "jacobi",
"mg_levels_esteig_ksp_type": "cgs",
"mg_levels_ksp_chebyshev_esteig_steps": 20,
"mg_coarse_pc_type": "jacobi", # jacobi coarse solver for singular problem
nullspace = nullspace_elasticity_2D(V)
problem = fem.petsc.LinearProblem(a, L, bcs=[], petsc_options=gamg_options)
problem.A.setNullSpace(nullspace)
problem.A.setNearNullSpace(nullspace)
u_sol = problem.solve()
# check if solution is orthogonal to RBM modes
u0 = fem.Function(V) # [1, 0]
u1 = fem.Function(V) # [0, 1]
u2 = fem.Function(V) # [-x[1], x[0]]
u0.interpolate(lambda x: np.stack([np.ones_like(x[0]), np.zeros_like(x[0])]))
u1.interpolate(lambda x: np.stack([np.zeros_like(x[0]), np.ones_like(x[0])]))
u2.interpolate(lambda x: np.stack([-x[1], x[0]]))
res0 = fem.assemble_scalar(fem.form(ufl.dot(u_sol, u0) * ufl.dx))
res1 = fem.assemble_scalar(fem.form(ufl.dot(u_sol, u1) * ufl.dx))
res2 = fem.assemble_scalar(fem.form(ufl.dot(u_sol, u2) * ufl.dx))
assert_almost_equal(res0, 0)
assert_almost_equal(res1, 0)
assert_almost_equal(res2, 0)
At the end of the code I check that the solution is in fact orthogonal to the nullspace.
Here is my problem: on the latest docker image, the assertions are passing and the solution is correct.
However I tried running that exact same code on a fresh ubuntu 22 install with the dolfinx ppa, and the assertions are failing, and also the solution looks completely messed up:
One thing I’ve noticed is that the ubuntu version of dolfinx uses PETSc 3.15 whereas the docker version uses version 3.17.
Is there something I am doing wrong here? I’ve been using these GAMG options for quite a while now and never ran into such issues.
